| » Whirlpool won't spin with clothes, agitates fine... |
Model Number: LSB6500PW0 Brand: Whirlpool Age: 5 - 10 years
Found my clothes sopping wet and a burning smell at end of washing cycle.
Checked and found that it is still agitating, draining, and spinning (only when there is NO CLOTHING). When I put it on spin cycle with clothes, you can hear the motor? trying to run, but nothing is happening (I am assuming where the burning smell is coming from). When I take the clothes out, and try spinning, it seems to get going fine. I checked underneath and did not see any "rubber shavings" as I have seen on other a "coupling" problem. PLEASE HELP! I am a teacher and am barely surviving month to month, I can't afford buying a new one or costly repairs. Ads By Google Related Models |
Hi.
Check two things first. Remove the agitator and check if the drive block still has the grooves and engaging the spin tube. The drive block Part number: 389140 Next, if the drive block is good - replace the clutch Part number: 285785 Use the video clip for the instructions. Here are the breakdown diagrams and Agitator, Basket and Tub parts for Whirlpool LSB6500PW0 - AppliancePartsPros.com Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Maytag MATV446AWW Agitates but won't spin - clothes wet | lbale | Washer Repair | 0 | 09-19-2012 10:21 AM |
| Whirlpool washer agitates only one direction, won't spin | longbow002 | Washer Repair | 1 | 12-15-2011 12:46 PM |
| Agitates, won't spin.. makes loud belt noise.. every other cycle works fine. | dolfan4764 | Washer Repair | 1 | 11-19-2011 09:30 AM |
| washing machine while in spin cycle also agitates causing the clothes to get jammed. | phamm60 | Washer Repair | 1 | 10-23-2011 07:21 AM |
| Whirlpool Agitates During Spin Cycle | ttl | Washer Repair | 2 | 02-22-2010 01:42 PM |
