Discuss
Maytag Wsher Problem
 in
Washer Repair
Sorry I do not have the Model number at hand. The problem i am having is this. It will go
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Wsher Problem
  #1 (permalink)
Old 03-04-2013, 01:15 PM
Junior Member
proteus is on a distinguished road
Default Maytag Wsher Problem
Brand: Signature   Age: 1 - 5 years
Sorry I do not have the Model number at hand. The problem i am having is this. It will go through a full cycle of wash and rinse and when finished instead of stopping it will start to fill again like it is going to start another load.
Ads By Google
  #2 (permalink)
Old 03-04-2013, 02:14 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
We must have the full model number to be able to help you.
Eric
  #3 (permalink)
Old 03-05-2013, 06:02 AM
Junior Member
Default
I was able to get the model number last night.
MTW5830TW0
  #4 (permalink)
Old 03-05-2013, 07:07 AM
Expert
APP Volunteer
Default
Sounds like options is set for extra rinse cycle? If extra rinse is not set, will it do this continously? You have to turn it off to make it stop? If that is the case, I'd say you have a bad timer. If it just seems to be running an extra rinse cycle with the extra rinse function off, it could be the options switch.
Eric
  #5 (permalink)
Old 03-05-2013, 07:46 AM
Junior Member
Default
To determine wether it is the timer or switch, I need to let it fill and see if it goes to another rinse cycle or goes into a full wash cycle?
  #6 (permalink)
Old 03-05-2013, 08:26 AM
Expert
APP Volunteer
Default
Just disconnect the extra rinse cycle switch, put the timer near the end of the normal rinse cycle and see what happens.
Eric
  #7 (permalink)
Old 03-05-2013, 08:50 AM
Junior Member
Default
Will do. Thanks for all of the help.
  #8 (permalink)
Old 03-06-2013, 10:41 AM
Junior Member
Default
problem solved. my wife had it set on the extra rinse option
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wsher gremlins shelhammer4@yahoo.com Washer Repair 1 02-01-2012 01:34 PM
maytag wsher is making noise Needhelp247 Washer Repair 1 07-14-2011 06:22 PM
Ge Wsher KAPED262 Washer Repair 0 12-19-2010 12:16 PM
wsher error codes don14 Washer Repair 0 01-06-2010 01:03 PM
Roper wsher-no cold water srose Washer Repair 1 12-12-2009 05:03 PM
