Discuss
Whirlpool Washer Is Not Turning On
 in
Washer Repair
I have a roughly five to six year old whirlpool stack washer and dryer, the dryer powers up just fine,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Washer Is Not Turning On
  #1 (permalink)
Old 03-03-2013, 07:44 PM
Junior Member
xipo269 is on a distinguished road
Thumbs up Whirlpool Washer Is Not Turning On
Model Number: LTG6234DQ2   Brand: Whirlpool   Age: 1 - 5 years
I have a roughly five to six year old whirlpool stack washer and dryer, the dryer powers up just fine, works as it should. Dryer is gas, and both washer and dryer use the same 120 volt circuit for power. My problem is that the washer does not start when you pull the timer knob out. My lid switch is good, checked that already. Not sure how to check for continuity with any other vital parts to see if they are good. Could it simply be the timer? With the timer knob pulled out to actuate the washer, I have no power coming down to the contacts where the lid switch molex plug attaches to the housing. Any help would be greatly appreciated!
Related Models
Whirlpool LTG6234DQ2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DQ3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DQ4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DQ5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DT1 LAUNDRY CENTER
Whirlpool LTG6234DT2 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DT3 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DT4 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DT5 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG6234DZ0
Whirlpool LTG6234DZ1 WASHER/DRYER LAUNDRY SYSTEM
Whirlpool LTG7245AN0 WASHER/DRYER
Whirlpool LTG7245AW0 WASHER/DRYER
 LTM9000ST Microwave Oven
 LTM9000W Microwave Oven
 LTM9020B Microwave Oven
Whirlpool LUD2100X0 Dishwasher
Whirlpool LUD2100X1 Dishwasher
Whirlpool LUD2100X3 Dishwasher
Whirlpool LUD2100X4 Dishwasher
Whirlpool LUD2100X5 Dishwasher
Whirlpool LUD2100X6 Dishwasher
Whirlpool LUD2100X7 Dishwasher
General Electric LUD3100V57WB Dishwasher
General Electric LUD3100V60WB Dishwasher
General Electric LUD3100V64WB Dishwasher
General Electric LUD3100X66WB Dishwasher
Bosch LV010-000
General Electric LVM132K01 Counter top microwave
General Electric LVM132K02 Counter top microwave
General Electric LVM1335BW01 Counter top microwave
General Electric LVM1335BW02 Counter top microwave
General Electric LVM1335BW03 Counter top microwave
General Electric LVM1335WW01 Counter top microwave
General Electric LVM1335WW02 Counter top microwave
General Electric LVM1335WW03 Counter top microwave
General Electric LVM135J01 Counter top microwave
General Electric LVM135J02 Counter top microwave
General Electric LVM135K02 Counter top microwave
General Electric LVM135K03 Counter top microwave
General Electric LVM135K04 Counter top microwave
General Electric LVM1420BA01 Counter top microwave
General Electric LVM1420BA02 Counter top microwave
General Electric LVM1420BA03 Counter top microwave
General Electric LVM1420WA01 Counter top microwave
General Electric LVM1420WA02 Counter top microwave
General Electric LVM1420WA03 Counter top microwave
General Electric LVM150G01 Electric range
General Electric LVM150H01 Counter top microwave
General Electric LVM1540DN1BB MICROWAVE
General Electric LVM1540DN1WW MICROWAVE
General Electric LVM1540LN1CS MICROWAVE
General Electric LVM1540SN1SS MICROWAVE
General Electric LVM1750DM1BB Counter top microwave
General Electric LVM1750DM1WW Counter top microwave
General Electric LVM1750DM2BB MICROWAVE
General Electric LVM1750DM2WW MICROWAVE
General Electric LVM1750DP1BB MICROWAVE
General Electric LVM1750DP1WW MICROWAVE
General Electric LVM1750SM1SS Counter top microwave
General Electric LVM1750SM2SS MICROWAVE
General Electric LVM1750SP1SS MICROWAVE
General Electric LVM235BL01 Counter top microwave
General Electric LVM235BL02 Counter top microwave
General Electric LVM235WL01 Counter top microwave
General Electric LVM235WL02 Counter top microwave
 LW1000ER Air Conditioner
 LW1000PR Air Conditioner
Amana LW1000W WASHER-TOP LOADING
Amana LW1200 WASHER-TOP LOADING
 LW1200ER Air Conditioner
 LW1200PR Air Conditioner
Amana LW1201 WASHER-TOP LOADING
Amana LW1501 WASHER-TOP LOADING
Amana LW1502 WASHER-TOP LOADING
Amana LW1503 WASHER-TOP LOADING
 LW1800ER Air Conditioner
 LW1800PR Air Conditioner
Amana LW2001W WASHER-TOP LOADING
Amana LW2001W2 WASHER-TOP LOADING
Amana LW2201G WASHER-TOP LOADING
Amana LW2201L WASHER-TOP LOADING
Amana LW2201W WASHER-TOP LOADING
Amana LW2300 WASHER-TOP LOADING
Amana LW2302 WASHER-TOP LOADING
Amana LW2303 WASHER-TOP LOADING
Amana LW2400 WASHER-TOP LOADING
Amana LW2402 WASHER-TOP LOADING
Amana LW2403 WASHER-TOP LOADING
Amana LW2500 WASHER-TOP LOADING
Amana LW2501G WASHER-TOP LOADING
Amana LW2501L WASHER-TOP LOADING
Amana LW2501L2 WASHER-TOP LOADING
  #2 (permalink)
Old 03-04-2013, 06:39 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
The lid switch will only have power to it if you are in spin mode or the tub is full of water. Does it fill with water? I assume not. You need to check continuity between the hot (small blade) of the AC cord plug and the gray/yellow wire on the timer with timer knob pulled out. If open, check hot to black wire on timer. If open, you need to trace that wire to find where the fault is. There may be a quick disconnect connection in that run. If these checks are good, check the neutral (wide blade) of the cord plug to the white/black wire on the timer. I'm using an older wiring diagram for this style washer so there may be differences. I do not have the exact diagram for your model. If you could provide a clear photo of the diagram and timer chart, that would be helpful.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool dryer not turning off Tommy68 Dryer Repair 0 08-18-2012 02:27 PM
Whirlpool washer will not spin without me manually turning the drum anc6802 Washer Repair 1 12-21-2011 04:53 PM
Whirlpool dryer not turning madge Dryer Repair 1 01-15-2011 09:44 AM
Whirlpool Washer knob not turning lmcantar Washer Repair 2 10-21-2010 11:22 AM
Whirlpool dishwasher...not turning on ebgeorge Dishwasher Repair 1 11-11-2008 02:03 PM
