Discuss
Roper washing machine
 in
Washer Repair
I have a Roper washer. The cold is not working. It does hum. Warm and Hot both do work. Thank
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Roper washing machine
  #1 (permalink)
Old 03-03-2013, 06:29 AM
Junior Member
Jwatts807 is on a distinguished road
Default Roper washing machine
Brand: Roper   Age: 5 - 10 years
I have a Roper washer. The cold is not working. It does hum. Warm and Hot both do work. Thank you.
  #2 (permalink)
Old 03-04-2013, 10:31 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Your warm is probably not working either, since it is a mixture of hot and cold and you are probably just getting the hot.
You should use a meter to see if you are getting voltage to the cold solenoid. An easy way to do this is to take off the cabinet and switch the connectors on the hot and cold water valve. If in this case you get cold but do not get hot, then the valve assembly is okay and the problem can be in the timer or the water temp selector.
If you don't get cold when you call for hot then the problem is likely with the valve assembly.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
roper washing machine RICHARDH43X Washer Repair 2 09-02-2012 08:36 AM
Roper Washing Machine Phillip D Webb Washer Repair 1 05-27-2009 09:56 AM
roper washing machine brandysimon Washer Repair 1 05-19-2009 08:40 PM
Roper washing machine dbishoff Washer Repair 0 04-05-2009 08:15 PM
Roper Washing Machine mjt240 Washer Repair 1 11-26-2007 06:50 PM
