| » Not going thru Cycles |
Model Number: 417.98702891 Brand: Kenmore Age: More than 10 years
Hi there, my washer just started to give me a problem today, It will not go thru its cycle, it will fill up and spin , but will not do the final spin without putting it on a different wash like delicates(but u have to do it manually) i also noticed its leaking out of the rim of the drum. Im thinking its the timer and its leaking due to the timer not allowing it to drain? Any help would be much appreciated.
Thanks, Bryan Ads By Google Related Models |
Inside the lower service panel should be some tech notes. This is a Frigidaire made front loader and the speed/motor control board often goes on these.
Given the leaking and this problem and the age of the machine, you may want to count yourself lucky to have gotten 10+ years out of the model and think about replacement. You deserve it.
__________________
| Display Modes | |
| spins 3 cycles one way, 3 cycles the other way, then will not spin after that | huntly | Washer Repair | 2 | 09-26-2011 04:10 AM |
| No Cycles | mkilcoin@san.rr.com | Dishwasher Repair | 0 | 09-12-2011 02:14 PM |
| Fan cycles on and off | Rickfromchurch | Refrigerator & Freezer Repair | 1 | 08-25-2010 03:25 AM |
| GE Wont advance cycles... Have to manually turn knob to advance cycles at 2 points | nickf829 | Washer Repair | 1 | 12-20-2009 04:43 PM |
| Won't run thru cycles | ilamb5 | Dishwasher Repair | 0 | 08-01-2009 10:50 AM |
