Discuss
Kenmore 90 Series Not Spinning?
 in
Washer Repair
Hi, Our Kenmore 90 Series Washer just stopped spinning. I thought it was the motor coupling but I took it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 90 Series Not Spinning?
  #1 (permalink)
Old 03-02-2013, 01:32 PM
Junior Member
kenmorenoob is on a distinguished road
Default Kenmore 90 Series Not Spinning?
Model Number: 11026912691   Brand: Kenmore   Age: 5 - 10 years
Our Kenmore 90 Series Washer just stopped spinning. I thought it was the motor coupling but I took it apart and it's not broken at all. When we go to the spin cycle, it just makes noise, the pump spins but the actual tub doesn't spin. Any advice?
Related Models
Kenmore 11026912691 AUTOMATIC WASHER
Kenmore 11026914690 WASHER
Kenmore 11026914691 AUTOMATIC WASHER
Kenmore 11026922500 WASHER
Kenmore 11026922501 WASHER
Kenmore 11026922502 WASHER
Kenmore 11026922503 RESIDENTIAL WASHERS
Kenmore 11026924500 WASHER
Kenmore 11026924501 WASHER
Kenmore 11026924502 WASHER
Kenmore 11026924503 RESIDENTIAL WASHERS
Kenmore 11026932690 Residential Washers
Kenmore 11026932691 Residential Washers
Kenmore 11026934690 Residential Washers
Kenmore 11026934691 Residential Washers
Kenmore 11026942500 WASHER
Kenmore 11026942501 WASHER
Kenmore 11026942502 WASHER
Kenmore 11026942503 RESIDENTIAL WASHERS
Kenmore 11026944500 WASHER
Kenmore 11026944501 WASHER
Kenmore 11026944502 WASHER
Kenmore 11026944503 RESIDENTIAL WASHERS
Kenmore 11026952690 AUTOMATIC WASHER
Kenmore 11026952691 AUTOMATIC WASHER
Kenmore 11026954690 AUTOMATIC WASHER
Kenmore 11026954691 AUTOMATIC WASHER
Kenmore 11026955690 AUTOMATIC WASHER
Kenmore 11026955691 AUTOMATIC WASHER
Kenmore 11026962500 WASHER
Kenmore 11026962501 WASHER
Kenmore 11026962502 WASHER
Kenmore 11026962503 RESIDENTIAL WASHERS
Kenmore 11026964500 WASHER
Kenmore 11026964501 RESIDENTIAL WASHER
Kenmore 11026964502 WASHER
Kenmore 11026964503 RESIDENTIAL WASHERS
Kenmore 11026966500 RESIDENTIAL WASHER
Kenmore 11027032600 WASHER
Kenmore 11027032601 AUTOMATIC WASHER
Kenmore 11027032602 RESIDENTIAL WASHER
Kenmore 11027032603 RESIDENTIAL WASHER
Kenmore 11027042600 WASHER
Kenmore 11027042601 RESIDENTIAL WASHERS
Kenmore 11027042602 RESIDENTIAL WASHER
Kenmore 11027042603 RESIDENTIAL WASHER
Kenmore 11027052600 RESIDENTIAL WASHERS
Kenmore 11027052601 RESIDENTIAL WASHER
Kenmore 11027052602 RESIDENTIAL WASHER
Kenmore 11027062600 WASHER
Kenmore 11027062601 RESIDENTIAL WASHER
Kenmore 11027062602 RESIDENTIAL WASHER
Kenmore 11027062603 RESIDENTIAL WASHER
Kenmore 11027062604 RESIDENTIAL WASHER
Kenmore 11027072600 WASHER
Kenmore 11027072601 RESIDENTIAL WASHER
Kenmore 11027072602 RESIDENTIAL WASHER
Kenmore 11027072603 RESIDENTIAL WASHER
Kenmore 11027072604 RESIDENTIAL WASHER
Kenmore 11027082600 RESIDENTIAL WASHER
Kenmore 11027082601 RESIDENTIAL WASHER
Kenmore 11027082602 RESIDENTIAL WASHER
Kenmore 11027082603 WASHER
Kenmore 11027082604 RESIDENTIAL WASHER
Kenmore 11027082605 RESIDENTIAL WASHER
Kenmore 11027086601 RESIDENTIAL WASHER
Kenmore 11027086602 RESIDENTIAL WASHER
Kenmore 11027086603 RESIDENTIAL WASHER
Kenmore 11027086604 RESIDENTIAL WASHER
Kenmore 11027086605 RESIDENTIAL WASHER
Kenmore 11027087600 RESIDENTIAL WASHER
Kenmore 11027087601 RESIDENTIAL WASHER
Kenmore 11027087602 RESIDENTIAL WASHER
Kenmore 11027087603 RESIDENTIAL WASHER
Kenmore 11027087604 RESIDENTIAL WASHER
Kenmore 11027087605 RESIDENTIAL WASHER
Kenmore 11027092600 WASHER
Kenmore 11027092601 RESIDENTIAL WASHER
Kenmore 11027092602 RESIDENTIAL WASHER
Kenmore 11027092603 RESIDENTIAL WASHER
Kenmore 11027112600 WASHER
Kenmore 11027152600 AUTOMATIC WASHER
Kenmore 11027152601 RESIDENTIAL WASHER
Kenmore 11027152602 RESIDENTIAL WASHER
Kenmore 11027172600 WASHER
Kenmore 11027222600 RESIDENTIAL WASHERS
Kenmore 11027224600 RESIDENTIAL WASHERS
Kenmore 11027272600 WASHER
Kenmore 11027322600 RESIDENTIAL WASHERS
Kenmore 11027332600 RESIDENTIAL WASHERS
Kenmore 11027342600 RESIDENTIAL WASHERS
Kenmore 11027422600 RESIDENTIAL WASHERS
Kenmore 11027432600 RESIDENTIAL WASHERS
Kenmore 11027442600 RESIDENTIAL WASHER
Kenmore 11027522600 RESIDENTIAL WASHERS
Kenmore 11027532600 RESIDENTIAL WASHERS
Kenmore 11027542600 RESIDENTIAL WASHER
Kenmore 11027612600 RESIDENTIAL WASHERS
Kenmore 11027622790 AUTOMATIC WASHER
Kenmore 11027622791 AUTOMATIC WASHER
Kenmore 11027632600 RESIDENTIAL WASHERS
Kenmore 11027642600 RESIDENTIAL WASHERS
Kenmore 11027721600 RESIDENTIAL WASHER
Kenmore 11027731600 RESIDENTIAL WASHERS
Kenmore 11027741600 RESIDENTIAL WASHERS
Kenmore 11027751700 RESIDENTIAL WASHER
Kenmore 11027761700 RESIDENTIAL WASHER
Kenmore 11027782700 RESIDENTIAL WASHER
Kenmore 11027802690 AUTOMATIC WASHER
Kenmore 11027802691 AUTOMATIC WASHER
Kenmore 11027812690 AUTOMATIC WASHER
Kenmore 11027812691 AUTOMATIC WASHER
Kenmore 11027812692 AUTOMATIC WASHER
Kenmore 11027822790 AUTOMATIC WASHER
Kenmore 11027824790 AUTOMATIC WASHER
Kenmore 11027831600 RESIDENTIAL WASHER
Kenmore 11027841600 RESIDENTIAL WASHERS
Kenmore 11027852790 AUTOMATIC WASHER
Kenmore 11027852791 AUTOMATIC WASHER
Kenmore 11027862790 AUTOMATIC WASHER
  #2 (permalink)
Old 03-02-2013, 01:44 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Run it with the cabinet off (lid switch bypassed) so that you can observe the clutch hub. When in spin mode, the clutch hub should be spinning. If it isn't, there's a problem with the gearcase. If it is, it could be a slipping clutch, broken brake cam driver or worn out drive block. Just remember that the normal sequence of operation is that directly after agitation, it should drain without spinning. After drain, the motor should pause for a few seconds. When it starts again, it will spin while continuing to drain.
Eric
  #3 (permalink)
Old 03-03-2013, 06:52 AM
Junior Member
Default
Thanks Eric, I'll check it out and get back to this thread. I am assuming the gearcase is expensive? Would it be about the same to buy another washer?
  #4 (permalink)
Old 03-03-2013, 07:23 AM
Junior Member
Default
Well the clutch is definitely not spinning but the motor in front is...looks like its new washer time or are those things "fixable"?
  #5 (permalink)
Old 03-03-2013, 07:47 AM
Expert
APP Volunteer
Default
Are you sure the coupler is ok? You can turn the gearcase input shaft by hand while observing the clutch hub to make sure it's the gearcase. Turn it CW for spin mode. The gearcase is repairable, depending on the problem. A new one is around $180. If this washer is in good shape otherwise, clean, not rusting out, and was working fine before this problem, I think you are better off fixing it rather than buying new. This is a Whirlpool direct drive design. A proven (30 years) widely used design that unfortunately is no longer produced, thanks to government standards.
http://www.lewrockwell.com/decoster/decoster197.html
Eric
  #6 (permalink)
Old 03-15-2013, 02:08 PM
Junior Member
S Arens is on a distinguished road
Default
Hi
I replaced the coupling last week and everything worked fine until today.
It stopped spinning again.
I took it apart again and checked the coupling..... everything is oK
What is my next step, put it back together again and try it once more.
It that is not it, what next
  #7 (permalink)
Old 03-15-2013, 03:17 PM
Expert
APP Volunteer
Default
Again, you need to check the clutch hub to determine where the problem is.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 80 Series not agitating or spinning alane720 Washer Repair 3 01-23-2013 11:09 AM
Kenmore 600 series washer not spinning thehawdis Washer Repair 3 07-27-2011 07:29 AM
kenmore 60 series not spinning after motor coupling replacement orion359 Washer Repair 1 03-31-2010 04:42 PM
Kenmore 80 series bangs sides when spinning kevin03079 Washer Repair 0 12-31-2009 07:21 AM
Kenmore Series 90 Washer Auger not spinning howiey@yahoo.com Washer Repair 20 01-02-2009 07:38 PM
