Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   replace speed knob (http://forum.appliancepartspros.com/washer-repair/518969-replace-speed-knob.html)
roy bradshaw 03-01-2013 01:20 PM
replace speed knob
i would like to know how to remove that speed control knob out of the control board of a kenmore elite washing machine without breaking it,,thanks, Roy
Joe / APP Team 03-01-2013 02:08 PM
Quote:
Roy, Most, if not all, control knobs are "slip on" type fits. They can be hard to pull off especially on older units, so you need to be careful.
fairbank56 03-01-2013 02:08 PM
The knob should just pull straight off. To remove the switch, lift up on the locking tab and rotate the switch about 30 and pull out.
Eric
roy bradshaw 03-01-2013 09:45 PM
Great info, no problem pulling knob off, now I just got to remove switch and I believe I can handle that. Thanks very much.:)
Joe / APP Team 03-02-2013 06:48 AM
Quote:
Roy, You're welcome. You didn't supply a model number, but as Fairbanks posted, Once you get into the control console, release the locking tab and turn the switch assembly counter clockwise to remove it. Just make sure you remove power to the washer before you do anything. Thanks Again
roy bradshaw 03-04-2013 01:11 PM
Yes sir, i asked about this knob switch because the machine will only operate on the heavy duty speed, if you move it to regular the washer just makes a skipping tap noise and nothing works. I have not tried it on the delicate or handwash/casual speeds. This is a kenmore 80 series mod 110.20852991. I was just wondering if the switch is my problem.? what do you think?
roy bradshaw 03-04-2013 01:18 PM
Quote:
thanks:) I hope this is enough info.
fairbank56 03-04-2013 02:17 PM
It could be the speed switch, the motor, or connection issue. Check the 2-wire motor connection at the motor. This motor has the standard 10-pin connector as well as the extra 2-pin for the two low speeds.
Eric
