Discuss
jsfarm1
 in
Washer Repair
I have a Frigidaire Front Load Model GLTF1670AS0 that does not spin. During the spin cycle the rinse and spin
Appliance Repair Forum > Appliance Repair Help > Washer Repair » jsfarm1
  #1 (permalink)
Old 02-26-2013, 10:25 PM
Junior Member
jsfarm1 is on a distinguished road
Question jsfarm1
I have a Frigidaire Front Load Model GLTF1670AS0 that does not spin. During the spin cycle the rinse and spin lights are on, the pump starts and the drum rotates slowly CW for a min or so, then CCW for a minute or so and repeats throughout the cycle. The pump stops running sometime during the cycle as the drum continues slowly alternating direction until the cycle is complete. Per the troubleshooting tips on the Tech Sheet for a drum motor that does not run at all, it directs you to check resistance on the motor windings. No problem there. Then remove the 6 pin connector from the speed control board and check resistance between pins 1-2, 2-3 & 3-1. Replace the speed control board if the resistance is not 3 Meg ohms +/- 10%. This one checks approx. 180 K on all three checks. Since motor does run slowly during the cycle even though the resistance checks are low, would you still consider the speed control board as the most likely culprit for this problem?
  #2 (permalink)
Old 02-27-2013, 07:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
Very likely the speed control board is the culprit. You can run another test to verify it. The instructions are attached to the post.
- The speed control board Part number: 134149220
Here are the breakdown diagrams and Parts for Frigidaire GLTF1670AS0 Washer - AppliancePartsPros.com
File Type: doc Drive motor tumbles but does not spin.doc (92.5 KB, 7 views)
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-27-2013, 09:27 PM
Junior Member
Smile jsfarm1
So sorry for posting in the Ref section rather than the Washer section?? Thanks so much for the feedback. I have ordered the speed control board, but the testing you provided is greatly appreciated. Thanks again Gene for your feedback! I will post the results hopefully on Thurs-Fri!! John
  #4 (permalink)
Old 02-27-2013, 09:30 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. This thread probably can be moved to the washer repair forum.
__________________
  #5 (permalink)
Old 02-28-2013, 02:27 PM
Junior Member
Default Problem Solved
I ran the test using the chart, but the results did not exactly match either scenario.
6 pin 10 pin
5 to 6 = 28v
5 to 9 = 31v
5 to 1 = 28v
5 to 2 = 120v
5 to 10 = 29v
However:
Just replaced the speed control board and it spins fine now. Thanks for your assistance!
  #6 (permalink)
Old 02-28-2013, 08:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. I'm glad it's up and running.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
