Discuss
GE Top Loading washer
 in
Washer Repair
Cold water fills fine, but Hot water will not fill at all but its trying (pump is pumping?). I have
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Top Loading washer
  #1 (permalink)
Old 02-04-2008, 05:17 PM
Junior Member
Mike Miller is on a distinguished road
Default GE Top Loading washer
Model Number: WWA5800GALAD   Brand: GE   Age: 5 - 10 years
Cold water fills fine, but Hot water will not fill at all but its trying (pump is pumping?). I have cleaned hoses and the screen at the water inlet valve. Still won't fill. What should be my next step?
Related Models
General Electric WWA5800GBL Washer
General Electric WWA5800MAL Washer
General Electric WWA5800RBL Washer
General Electric WWA5800VCL Washer
General Electric WWA5809RBL Washer
General Electric WWA5826MAL Washer
General Electric WWA5826RBL Washer
General Electric WWA5857RBL Washer
General Electric WWA6007MAL Washer
General Electric WWA6407LBL Washer
General Electric WWA6600MAL Washer
General Electric WWA6600RBL Washer
General Electric WWA6600SALAA Washer
General Electric WWA6600SALWW Washer
General Electric WWA6600SBLAA Washer
General Electric WWA6600SBLWW Washer
General Electric WWA6800SALAD Washer
General Electric WWA6800SALHA Washer
General Electric WWA6800SALWH Washer
General Electric WWA7010GAL Washer
General Electric WWA7010GBL Washer
General Electric WWA7050BAL Washer
General Electric WWA7050GAL Washer
General Electric WWA7050GBL Washer
General Electric WWA7059VCL Washer
General Electric WWA7060VCL Washer
General Electric WWA7070BAL Washer
General Electric WWA7070GAL Washer
General Electric WWA7070GBL Washer
General Electric WWA7070VCL Washer
General Electric WWA7079VCL Washer
General Electric WWA7304PML Washer
General Electric WWA7304VKL Washer
General Electric WWA7304VLL Washer
General Electric WWA7600RBL Washer
General Electric WWA7600SALAA Washer
General Electric WWA7600SALWW Washer
General Electric WWA7600SBLAA Washer
General Electric WWA7600SBLWW Washer
General Electric WWA7619MAL Washer
General Electric WWA7640SALAA Washer
General Electric WWA7640SALWW Washer
General Electric WWA7640SBLAA Washer
General Electric WWA7640SBLWW Washer
General Electric WWA7646MAL Washer
General Electric WWA7650SALAA Washer
General Electric WWA7650SALWW Washer
General Electric WWA7650SBLAA Washer
General Electric WWA7650SBLWW Washer
General Electric WWA7678MAL Washer
General Electric WWA7680SALAA Washer
General Electric WWA7680SALWW Washer
General Electric WWA7680SBLAA Washer
General Electric WWA7680SBLWW Washer
General Electric WWA7690SALAA Washer
General Electric WWA7690SALWW Washer
General Electric WWA7690SBLAA Washer
General Electric WWA7690SBLWW Washer
General Electric WWA7800MAL Washer
General Electric WWA7800RBL Washer
General Electric WWA7826MAL Washer
General Electric WWA8062BAL Washer
General Electric WWA8062VEL Washer
General Electric WWA8072BAL Washer
General Electric WWA8072GAL Washer
General Electric WWA8072VEL Washer
General Electric WWA8300BAL Washer
General Electric WWA8300GAL Washer
General Electric WWA8300GBL Washer
General Electric WWA8300VCL Washer
General Electric WWA8301MAL Washer
General Electric WWA8306LAL Washer
General Electric WWA8306LBL Washer
General Electric WWA8307LAL Washer
General Electric WWA8307LBL Washer
General Electric WWA8310BAL Washer
General Electric WWA8310GAL Washer
General Electric WWA8310GBL Washer
General Electric WWA8314PML Washer
General Electric WWA8314VKL Washer
General Electric WWA8314VLL Washer
General Electric WWA8318LAL Washer
General Electric WWA8318LBL Washer
General Electric WWA8319VCL Washer
General Electric WWA8320BAL Washer
General Electric WWA8320GAL Washer
General Electric WWA8320GBL Washer
General Electric WWA8320VCL Washer
General Electric WWA8324BAL Washer
General Electric WWA8324GAL Washer
General Electric WWA8324GBL Washer
General Electric WWA8326LAL Washer
General Electric WWA8326LBL Washer
General Electric WWA8330BAL Washer
General Electric WWA8330GAL Washer
General Electric WWA8330GBL Washer
General Electric WWA8340BAL Washer
General Electric WWA8340GAL Washer
General Electric WWA8340GBL Washer
General Electric WWA8340VCL Washer
General Electric WWA8344BAL Washer
General Electric WWA8344VCL Washer
General Electric WWA8344VKL Washer
General Electric WWA8344VLL Washer
General Electric WWA8350BAL Washer
General Electric WWA8350GAL Washer
General Electric WWA8350GBL Washer
General Electric WWA8354VLL Washer
General Electric WWA8354VML Washer
General Electric WWA8354VNL Washer
General Electric WWA8355BAL Washer
General Electric WWA8355GAL Washer
General Electric WWA8359VCL Washer
General Electric WWA8360BAL Washer
General Electric WWA8360GAL Washer
General Electric WWA8360GBL Washer
General Electric WWA8364VKL Washer
General Electric WWA8364VLL Washer
General Electric WWA8366LAL Washer
General Electric WWA8366LBL Washer
  #2 (permalink)
Old 02-05-2008, 01:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If there is nothing wrong with the hot water supply to the washer, then the problem is the water inlet valve (#805 on the cabinet break down diagram) or power to this valve.
Locate which of the coils is responsible for the hot water and check for 120V to this coil when the timer calls for hot water.
If there is 120V - replace the water inlet valve.
If there is no 120V - replace the timer.
- The part number for the water inlet valve is AP2618763
- The part number for the timer is AP2045768
Here are the break down diagrams for the GE washer Model WWA5800GAL
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-05-2008, 04:49 PM
Junior Member
Default Thank you, Gene
The diagnosis is clear and I should be able to fix it. Thanks again.
  #4 (permalink)
Old 02-05-2008, 05:57 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Mike,
Keep me updated, please.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Front Loading Washer rvincentiv Washer Repair 3 01-16-2010 04:25 PM
Whirlpool top loading washer . Jim's wife Washer Repair 1 08-31-2009 01:35 PM
top loading GE washer faststart Washer Repair 1 07-01-2009 06:21 AM
GE top loading washer not draining cpope24 Washer Repair 2 07-21-2008 08:15 AM
Agitater -Top Loading Washer Kooch Washer Repair 0 04-16-2008 09:19 AM
