Discuss
Whirlpool Washer will not drain unless open and close lid
 in
Washer Repair
My whirlpool washer will fill and agitate just fine. When it comes time to drain, the drain cycle does not
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Washer will not drain unless open and close lid
  #1 (permalink)
Old 02-28-2013, 09:16 AM
Junior Member
twhistle is on a distinguished road
Default Whirlpool Washer will not drain unless open and close lid
Model Number: LLR8233BQ1   Brand: Whirlpool   Age: 5 - 10 years
My whirlpool washer will fill and agitate just fine. When it comes time to drain, the drain cycle does not kick in. If I open and close the lid at the time when the drain cycle should kick in, then it will drain. This happens for the initial drain cycle and the drain cycle after rinse. Any idea what this could be? My problems started after I washed a fairly heavy rug one night (that I should not have in hind sight) and woke up the next morning with washer full of water and the timer was on off.
Related Models
Whirlpool LLR8233BQ1 AUTOMATIC WASHER
Whirlpool LLR8233BW0 AUTOMATIC WASHER
Whirlpool LLR8233BW1 AUTOMATIC WASHER
Whirlpool LLR8233DQ0 AUTOMATIC WASHER
Whirlpool LLR8233DW0 AUTOMATIC WASHER
Whirlpool LLR8233DZ0 AUTOMATIC WASHER
Whirlpool LLR8233EQ0 AUTOMATIC WASHER
Whirlpool LLR8233EQ1 DIRECT-DRIVE WASHER
Whirlpool LLR8233EZ0 AUTOMATIC WASHER
Whirlpool LLR8233EZ1 DIRECT-DRIVE WASHER
Whirlpool LLR8245AW0 Washers
Whirlpool LLR8245BN0 AUTOMATIC WASHER
Whirlpool LLR8245BN1 AUTOMATIC WASHER
Whirlpool LLR8245BW0 AUTOMATIC WASHER
Whirlpool LLR8245BW1 AUTOMATIC WASHER
Whirlpool LLR8245DQ0 AUTOMATIC WASHER
Whirlpool LLR8245DZ0 AUTOMATIC WASHER
Whirlpool LLR9245AQ0
Whirlpool LLR9245BQ0
Whirlpool LLR9245BQ1 WASHERS DIRECT-DRIVE
Whirlpool LLR9245DQ0
Whirlpool LLR9245DQO WHIRLPOOL WASHER
Whirlpool LLR9245DZ0
Whirlpool LLR9245DZO WHIRLPOOL WASHER
Whirlpool LLT7144AN0 Washers*
Whirlpool LLT7144BN0
Whirlpool LLT7144BQ0
Whirlpool LLT7144BQ1
Whirlpool LLT7144BW0
Whirlpool LLT7144DQ0
Whirlpool LLT8233AN0
Whirlpool LLT8233AQ0
Whirlpool LLT8233AW0
Whirlpool LLT8233AW1 AUTOMATIC WASHER
Whirlpool LLT8233AW2
Whirlpool LLT8233DQ0
Whirlpool LLT8233DZ0
Whirlpool LLT8244AN0
Whirlpool LLT8244AQ0
Whirlpool LLT8244AW0
Whirlpool LLT8244AZ0
Whirlpool LLT8244BQ0
Whirlpool LLT8244BQ1
Whirlpool LLT8244BZ0
Whirlpool LLT8244BZ1
Whirlpool LLT8244DQ0
Whirlpool LLT8244DZ0
Whirlpool LLV6144AG0
Whirlpool LLV6144AN0
Whirlpool LLV6144AW0
Whirlpool LLV6144BN0
Whirlpool LLV6144BW0
Whirlpool LLV7233AW0
Whirlpool LLV7244AG0
Whirlpool LLV7244AN0
Whirlpool LLV7244AW0
Whirlpool LLV8233BN0
Whirlpool LLV8233BQ0
Whirlpool LLV8233BW0
Whirlpool LLV8245AG0
Whirlpool LLV8245AN0
Whirlpool LLV8245AW0
Whirlpool LLV8245BN0
Whirlpool LLV8245BW0
Whirlpool LLV8245DQ0
Whirlpool LLV8245DZ0
 LM-1830C2L Air Conditioner
 LM-2430C2L Air Conditioner
 LM-2430H2L Air Conditioner
 LM360CE Air Conditioner
Whirlpool LMA1053LQ0
Whirlpool LMA1053LT0
 LMA1150SV Microwave Oven
 LMA1560SB Microwave Oven
 LMA2111ST Microwave Oven
 LMAN090CNS.ANCAEUS Air Conditioner
 LMAN090HNS Air Conditioner
 LMAN120CNS Air Conditioner
 LMAN120HNS Air Conditioner
 LMAN121CNM Air Conditioner
 LMAN121HNM Air Conditioner
 LMH1017CVST Microwave Oven
 LMN090CE.AWHAEUS Air Conditioner
 LMN090HE Air Conditioner
 LMN120EC.AWHAEUS Air Conditioner
 LMN120HE Air Conditioner
 LMN2430H2L Air Conditioner
Whirlpool LMR4131AN0
Whirlpool LMR4131AW0
Whirlpool LMR4132BW0
Whirlpool LMR4232AN0
Whirlpool LMR4232AW0
Whirlpool LMR5243AN0
Whirlpool LMR5243AN1
Whirlpool LMR5243AW0
Whirlpool LMR5243AW1
 LMU180HE Air Conditioner
 LMU1830C2L Air Conditioner
 LMU240CE.AWGAEUS Air Conditioner
 LMU240HE Air Conditioner
 LMU2430C2L Air Conditioner
 LMU360CE Air Conditioner
 LMU360HE Air Conditioner
 LMV-1975ST Microwave Oven
 LMV1314B Microwave Oven
 LMV1314SV Microwave Oven
 LMV1314W Microwave Oven
 LMV1625B Microwave Oven
 LMV1625W Microwave Oven
 LMV1630BB Microwave Oven
 LMV1630ST Microwave Oven
 LMV1630WW Microwave Oven
 LMV1635SB Microwave Oven
 LMV1635SBQ Microwave Oven
 LMV1635SW Microwave Oven
 LMV1680ST Microwave Oven
 LMV1680WW Microwave Oven
  #2 (permalink)
Old 02-28-2013, 09:42 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
After agitation stops, if the motor doesn't start again for drain and the timer doesn't advance, it sounds like the lid switch is faulty.
Eric
  #3 (permalink)
Old 02-28-2013, 09:45 AM
Junior Member
Default
Thanks Eric.
The agitation never stops until the dial gets to the off position. Because the drain doesn't kick in, the agitation just keeps on going until off position. The timer dial does advance and I can see when it advances to the point where the drain should happen but it doesn't until I open and close the lid.
  #4 (permalink)
Old 02-28-2013, 10:23 AM
Expert
APP Volunteer
Default
That's a new one on me. The only thing I can think of is the timer. Opening/closing the lid cycles power to the timer but that doesn't explain why it's doing what it's doing. If you get the timer from here and it doesn't work, you can return it.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer wont spin unless u open and close lid mttconway Washer Repair 10 02-21-2015 12:32 PM
Whirlpool washer will agitate and drain, but won't spin unless open/close lid bnavarre Washer Repair 11 12-04-2012 05:57 PM
washer wont spin unless i open then close lid idrinkalone Washer Repair 3 08-22-2011 01:57 AM
Washer won't drain, door won't open Tom Samo Washer Repair 1 01-19-2010 05:48 PM
Maytag Washing won't spin & drain unless open & close lid hull98 Washer Repair 1 09-19-2009 04:15 PM
