So I got the e47 code saying the door lock wasnt being recognised during the spin cycle. I replaced the lock mechanism and now im getting error code e00 which I cant find a description for anywhere. Any help would be much appreciated.
When getting false codes on this model it may mean the control unit is bad. However, given that you replace the door lock assembly there may be a problem with the wiring between it and the control unit, or the connections at the control unit so check that out before trying a replacement on the control unit.
