Discuss
Old Washing Machine Water Temp Question
 in
Washer Repair
Everything in my laundry room is at least 20 years old or older. Boiler is going 55. In doing some
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Old Washing Machine Water Temp Question
  #1 (permalink)
Old 02-26-2013, 01:56 PM
Junior Member
jasesun23 is on a distinguished road
Default Old Washing Machine Water Temp Question
Model Number: LLR8223BW0   Brand: Whirlpool   Age: More than 10 years
Everything in my laundry room is at least 20 years old or older. Boiler is going 55. In doing some minor updates (new laundry sink, new hoses for washing machine, new vent for dryer, some new plumbing) I decided to test the water temperature of my washing machine. It has a 3 temp turn knob switch.
The choices are (wash/rinse)
Cold/Cold
Warm/Cold
Hot/Cold
When choosing cold the temperature (using a thermapen/accurate thermometer) it comes into the washing machine at tap water temperature of 45-48 degrees. The warm mixes about 50/50 and comes in around 85-88 degrees. The hot uses just hot water and since it is close to the boiler it comes in at 130-134 degrees.
Reading the manual it says hot should be 130 or above (that right on) , warm should be 90-110 (i'm a little on the low side) and cold should be 70-90 (i'm alot on the low side).
The next line also says in wash water temperatures colder than 70 degrees:
*detergents do not dissolve well
*soils are difficult to remove
*fabrics retain wrinkles and have increase pilling
This leads me to believe that the coldest this washing machine should go is 70 degrees yet its cold setting is at tap waters temperature
Does anyone know what is the issue? Is a part broken or is this maybe the way it is supposed to work.
I'm thinking on the cold/cold setting it should let mostly cold water in and a little hot water to get it up to 70. And at the warm it should let more hot than cold in to get it around 100, and finally at the hot it should just let hot water in (which it is doing correctly)
The only parts I can see that might affect this are
water inlet valve:
Whirlpool 285805 Water Inlet Valve - AppliancePartsPros.com
I looked at mine and it seems to be working well. I took it apart and clean it out. It looks like a solenoid that would either allow water in or stop it. It gets its signal from the temperature switch I believe
Whirlpool W10168256 Temperature Switch - AppliancePartsPros.com
This seems to be working well on mine as well. If i turn it to cold, cold water comes out, if i turn it to warm both cold and hot water come out, and if I turn it to hot than hot water comes out. Does this little switch have the ability to tell the cold setting to let mostly cold and some hot in, and for warm to let mostly hot with a little cold in? Could mine be broken . Tested it with a multimeter. When switch is at cold the wires to the cold inlet show 122 volts and the hot shows zero. Warm both show 122 volts. And when the switch is at hot- cold shows zero and hot shows 122.
Any advice would be appreciated. I've been washing darks in cold for year now at 45 degrees. Which from what i'm reading is pointless. Worst case senario I'll just move the switch back and forth from cold to hot to get the water temp I want but I'd like this to do it automatically if it could
thanks
Jay
Related Models
Whirlpool LLR8233BN0 AUTOMATIC WASHER
Whirlpool LLR8233BN1 AUTOMATIC WASHER
Whirlpool LLR8233BQ0 AUTOMATIC WASHER
Whirlpool LLR8233BQ1 AUTOMATIC WASHER
Whirlpool LLR8233BW0 AUTOMATIC WASHER
Whirlpool LLR8233BW1 AUTOMATIC WASHER
Whirlpool LLR8233DQ0 AUTOMATIC WASHER
Whirlpool LLR8233DW0 AUTOMATIC WASHER
Whirlpool LLR8233DZ0 AUTOMATIC WASHER
Whirlpool LLR8233EQ0 AUTOMATIC WASHER
Whirlpool LLR8233EQ1 DIRECT-DRIVE WASHER
Whirlpool LLR8233EZ0 AUTOMATIC WASHER
Whirlpool LLR8233EZ1 DIRECT-DRIVE WASHER
Whirlpool LLR8245AW0 Washers
Whirlpool LLR8245BN0 AUTOMATIC WASHER
Whirlpool LLR8245BN1 AUTOMATIC WASHER
Whirlpool LLR8245BW0 AUTOMATIC WASHER
Whirlpool LLR8245BW1 AUTOMATIC WASHER
Whirlpool LLR8245DQ0 AUTOMATIC WASHER
Whirlpool LLR8245DZ0 AUTOMATIC WASHER
Whirlpool LLR9245AQ0
Whirlpool LLR9245BQ0
Whirlpool LLR9245BQ1 WASHERS DIRECT-DRIVE
Whirlpool LLR9245DQ0
Whirlpool LLR9245DQO WHIRLPOOL WASHER
Whirlpool LLR9245DZ0
Whirlpool LLR9245DZO WHIRLPOOL WASHER
Whirlpool LLT7144AN0 Washers*
Whirlpool LLT7144BN0
Whirlpool LLT7144BQ0
Whirlpool LLT7144BQ1
Whirlpool LLT7144BW0
Whirlpool LLT7144DQ0
Whirlpool LLT8233AN0
Whirlpool LLT8233AQ0
Whirlpool LLT8233AW0
Whirlpool LLT8233AW1 AUTOMATIC WASHER
Whirlpool LLT8233AW2
Whirlpool LLT8233DQ0
Whirlpool LLT8233DZ0
Whirlpool LLT8244AN0
Whirlpool LLT8244AQ0
Whirlpool LLT8244AW0
Whirlpool LLT8244AZ0
Whirlpool LLT8244BQ0
Whirlpool LLT8244BQ1
Whirlpool LLT8244BZ0
Whirlpool LLT8244BZ1
Whirlpool LLT8244DQ0
Whirlpool LLT8244DZ0
Whirlpool LLV6144AG0
Whirlpool LLV6144AN0
Whirlpool LLV6144AW0
Whirlpool LLV6144BN0
Whirlpool LLV6144BW0
Whirlpool LLV7233AW0
Whirlpool LLV7244AG0
Whirlpool LLV7244AN0
Whirlpool LLV7244AW0
Whirlpool LLV8233BN0
Whirlpool LLV8233BQ0
Whirlpool LLV8233BW0
Whirlpool LLV8245AG0
Whirlpool LLV8245AN0
Whirlpool LLV8245AW0
Whirlpool LLV8245BN0
Whirlpool LLV8245BW0
Whirlpool LLV8245DQ0
Whirlpool LLV8245DZ0
 LM-1830C2L Air Conditioner
 LM-2430C2L Air Conditioner
 LM-2430H2L Air Conditioner
 LM360CE Air Conditioner
Whirlpool LMA1053LQ0
Whirlpool LMA1053LT0
 LMA1150SV Microwave Oven
 LMA1560SB Microwave Oven
 LMA2111ST Microwave Oven
 LMAN090CNS.ANCAEUS Air Conditioner
 LMAN090HNS Air Conditioner
 LMAN120CNS Air Conditioner
 LMAN120HNS Air Conditioner
 LMAN121CNM Air Conditioner
 LMAN121HNM Air Conditioner
 LMH1017CVST Microwave Oven
 LMN090CE.AWHAEUS Air Conditioner
 LMN090HE Air Conditioner
 LMN120EC.AWHAEUS Air Conditioner
 LMN120HE Air Conditioner
 LMN2430H2L Air Conditioner
Whirlpool LMR4131AN0
Whirlpool LMR4131AW0
Whirlpool LMR4132BW0
Whirlpool LMR4232AN0
Whirlpool LMR4232AW0
Whirlpool LMR5243AN0
Whirlpool LMR5243AN1
Whirlpool LMR5243AW0
Whirlpool LMR5243AW1
 LMU180HE Air Conditioner
 LMU1830C2L Air Conditioner
 LMU240CE.AWGAEUS Air Conditioner
 LMU240HE Air Conditioner
 LMU2430C2L Air Conditioner
 LMU360CE Air Conditioner
 LMU360HE Air Conditioner
 LMV-1975ST Microwave Oven
 LMV1314B Microwave Oven
 LMV1314SV Microwave Oven
 LMV1314W Microwave Oven
 LMV1625B Microwave Oven
 LMV1625W Microwave Oven
 LMV1630BB Microwave Oven
 LMV1630ST Microwave Oven
 LMV1630WW Microwave Oven
 LMV1635SB Microwave Oven
 LMV1635SBQ Microwave Oven
  #2 (permalink)
Old 02-26-2013, 02:38 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Your washer does not have automatic temperature control. Many do, many don't. The ones that do have a temperature sensor inside the water valve assembly and an electronic control board to adjust the valves accordingly. About all you can do is switch it manually like you said or set it to warm and adjust the water valves at the wall spigot to your liking as you would at the sink faucet.
Eric
  #3 (permalink)
Old 02-26-2013, 03:01 PM
Junior Member
Default
Thanks for the quick reply Eric. I though that might be what was happening however I was hoping it was a broken part.
Was thinking about closing the ball valves a little but it would only benefit me on the warm setting like you mentioned. And as far as the rinse temp I can't do anything about that. It just kind of annoys me that they would mention those temperatures in the book. For example don't go below 70 yet the cold setting on this machine is well below 70, kind of odd.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washing machine won't hold water 619javiero Washer Repair 1 11-19-2012 04:49 PM
Washing Machine water drio doner6 Washer Repair 2 09-11-2012 01:08 AM
hot water and fuse for washing machine James chris Washer Repair 4 01-28-2012 04:47 AM
water dripping in washing machine jennifer34 Washer Repair 1 10-14-2010 10:47 AM
washing machine not stopping to take water in Akram Washer Repair 1 09-23-2010 07:42 PM
