Register | FAQ's | New Posts | Today's Posts | Extras |
» Agitator only works when empty |
![]() Model Number: lsq9010LW0 Brand: Whirlpool Age: 5 - 10 years
![]() My washer seems to run through the cycles of filling and draining ok, but it does not agitate. I can get it to agitate when there are no clothes in it, but even a small load causes the agitator to not move. There have been a couple times when the pump ran on the spin cycle, but the agitator didn't spin until I opened and closed the lid, but I'm wondering if this is a different issue than the main one above. Thanks for any help. Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Hello,
It looks like there are two separate problems. In order to diagnose the first problem you may want to check the motor drive coupling. Click on the part number bellow to watch the repair video. The second problem most likely caused by a bad timer. - The motor drive coupling Part number: 285753A - The timer Part number: 3951702 Here are the breakdown diagrams and Parts for Whirlpool LSQ9010LW0 Washer - AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
![]() Quote:
Eric |
![]() You are welcome. Keep us posted.
__________________
![]() Is it the lower half of the agitator that isn't working or the upper half? Does it spin ok? If it's just that the upper agitator isn't working, it probably just needs a new set of dogs. With the machine off, you should only be able to rotate the upper agitator in the clockwise direction. If you can freely rotate in both directions with the lower agitator fixed, the teeth on the dogs are probably stripped.
Eric Last edited by fairbank56 : 03-02-2013 at 10:21 AM. |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Washer works ok but won't do final spin unless empty | falsales | Washer Repair | 0 | 01-07-2013 08:08 AM |
Slow agitator and pump won't completely empty basin | Iwantcleanclothes | Washer Repair | 0 | 08-14-2012 05:36 AM |
GE washer works when empty, but..... | karlchap | Washer Repair | 3 | 06-18-2012 10:01 AM |
Agitator sometimes works | Waterman10 | Washer Repair | 1 | 02-15-2012 03:58 PM |
Kenmore 500: spin cycle works when empty, does not work when full | silv50 | Washer Repair | 15 | 08-27-2010 12:52 PM |
