Discuss
no spin on GE -- 4 flash error code, test with ohm reading?
 in
Washer Repair
GE error code flashes 4 times means the mode shifter (clutch) needs repair. Testing with an ohm meter gives a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » no spin on GE -- 4 flash error code, test with ohm reading?
  #1 (permalink)
Old 02-25-2013, 12:05 PM
Junior Member
Jim1010 is on a distinguished road
Default no spin on GE -- 4 flash error code, test with ohm reading?
Model Number: WH38X10017   Brand: GE   Age: Less than 1 year
Testing with an ohm meter gives a reading of 66, which means it is closed and good.
Is this a discrepancy? What part needs repair?
Ads By Google
Related Models
General Electric WHDRE526E1WW Washer
General Electric WHDRE526E6WW Washer
General Electric WHDRR418E1WW Washer
General Electric WHDRR418E3WW Washer
General Electric WHDRR418E4WW Washer
General Electric WHDRR418E5WW Washer
General Electric WHDRR418E6WW Washer
General Electric WHDRR418G0WW Washer
General Electric WHDSE820C0WW Washer
General Electric WHDSE820C1WW Washer
General Electric WHDSE820C9WW Washer
General Electric WHDSR209D0WW Washer
General Electric WHDSR209D1WW Washer
General Electric WHDSR209D3WW Washer
General Electric WHDSR209D4WW Washer
General Electric WHDSR209D5WW Washer
General Electric WHDSR209D6WW Washer
General Electric WHDSR209D7WW Washer
General Electric WHDSR209DAWW Washer
General Electric WHDSR209DBWW Washer
General Electric WHDSR209DCWW Washer
General Electric WHDSR209DDWW Washer
General Electric WHDSR209G0WW Washer
General Electric WHDSR209G2WW Washer
General Electric WHDSR315D0WW Washer
General Electric WHDSR315D5WW Washer
General Electric WHDSR315DAWW Washer
General Electric WHDSR315DBWW Washer
General Electric WHDSR315DCWW Washer
General Electric WHDSR316G0WW Washer
General Electric WHDSR417D0WW Washer
General Electric WHDSR417D5WW Washer
General Electric WHDVH626F0GG Washer
General Electric WHDVH626F0WW Washer
General Electric WHDVH660H0BB Washer
General Electric WHDVH660H0GG Washer
General Electric WHDVH660H0WW Washer
Whirlpool WHE33311 30" Electric Range
Whirlpool WHP1000SB1 Pedestal
Whirlpool WHP1000SK0 Pedestal
Whirlpool WHP1000SK1 Pedestal
Whirlpool WHP1000SL0 Pedestal
Whirlpool WHP1000SL1 Pedestal
Whirlpool WHP1000SQ0 Pedestal
Whirlpool WHP1000SQ1 Pedestal
Whirlpool WHP1000ST0 Pedestal
Whirlpool WHP1000ST1 Pedestal
Whirlpool WHP1000SU1 Pedestal
Whirlpool WHP1500SA0 Pedestal
Whirlpool WHP1500SA1 Pedestal
Maytag WHP1500SA1 Pedestal
Whirlpool WHP1500SB0 Pedestal
Whirlpool WHP1500SB1 Pedestal
Maytag WHP1500SB1 Pedestal
Whirlpool WHP1500SC0 Pedestal
Whirlpool WHP1500SC1 Pedestal
Maytag WHP1500SC1 Pedestal
Whirlpool WHP1500SL0 Pedestal
Whirlpool WHP1500SL1 Pedestal
Maytag WHP1500SL1 Pedestal
Whirlpool WHP1500SQ0 Pedestal
Whirlpool WHP1500SQ1 Pedestal
Maytag WHP1500SQ1 Pedestal
Whirlpool WHP1500ST0 Pedestal
Whirlpool WHP1500ST1 Pedestal
Maytag WHP1500ST1 Pedestal
Whirlpool WHP1500SU0 Pedestal
Whirlpool WHP1500SU1 Pedestal
Maytag WHP1500SU1 Pedestal
Whirlpool WHP32812 30" Electric Range Self Clean Oven
Whirlpool WHP54802 30" Electric Range Self Clean Oven
Whirlpool WHP54803 30" Electric Range Self Clean Oven
Whirlpool WHP83812 30" Electric Range Ceran Cooktop Self Clean
General Electric WHRE5260E0CC Washer
General Electric WHRE5260E0WW Washer
General Electric WHRE5260E1CC Washer
General Electric WHRE5260E1WW Washer
General Electric WHRE5260E6CC Washer
General Electric WHRE5260E6WW Washer
General Electric WHSB8000B0CC Washer
General Electric WHSB8000B0WW Washer
General Electric WHSB8000B1CC Washer
General Electric WHSB8000B1WW Washer
General Electric WHSB9000B0CC Washer
General Electric WHSB9000B0WC Washer
General Electric WHSB9000B0WW Washer
General Electric WHSE3100A0WB Washer
General Electric WHSE3100A2WB Washer
General Electric WHSE5240D0CC Washer
General Electric WHSE5240D0WW Washer
General Electric WHSE5240D1CC Washer
General Electric WHSE5240D1WW Washer
General Electric WHSE5240DCCC Washer
General Electric WHSE5240DCWW Washer
General Electric WHSR2070V2WB Washer
General Electric WHSR2070V3WB Washer
General Electric WICB103CV1WC Washer
Frigidaire WIDH3 Frg(v18) / Top Loading Washer
Frigidaire WIDH4 Frg(v3) / Top Load Washer
Frigidaire WIDL3 Frg(v19) / Top Loading Washer
Frigidaire WIDL4 Frg(v2) / Top Load Washer
Frigidaire WIDW3 Frg(v20) / Top Loading Washer
Frigidaire WIDW4 Frg(v1) / Top Load Washer
Frigidaire WILH1 Frg(v2) / 27 " Washer
Frigidaire WILL0 Frg(v2) / 27 " Washer
Frigidaire WILL1 Frg(v3) / 27 " Washer
Frigidaire WILW0 Frg(v1) / 27 " Washer
Frigidaire WILW1 Frg(v1) / 27 " Washer
Frigidaire WIMA1 Frg(v16) / Washer
Frigidaire WIMA2 Frg(v17) / Washer
Frigidaire WIMA3 Frg(v15) / Washer
Frigidaire WIMF1 Frg(v18) / Washer
Frigidaire WIMF2 Frg(v19) / Washer
Frigidaire WIMF3 Frg(v16) / Washer
Frigidaire WIMH1 Frg(v20) / Washer
Frigidaire WIMH2 Frg(v21) / Washer
Frigidaire WIMH3 Frg(v17) / Washer
Frigidaire WIML1 Frg(v22) / Washer
Frigidaire WIML2 Frg(v23) / Washer
Frigidaire WIML3 Frg(v18) / Washer
  #2 (permalink)
Old 02-25-2013, 01:20 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Need model number of washer, not the mode shifter. If it's less than a year old, it should be under warranty? Can you rotate the basket by hand?
Eric
  #3 (permalink)
Old 02-25-2013, 04:23 PM
Junior Member
Default
Model GE WHRE5550k1WW--the washer is about 4 years old.
Basket spins freely by hand.
  #4 (permalink)
Old 02-25-2013, 08:22 PM
Expert
APP Volunteer
Default
I assume it is agitating ok? The mode shifter is only energized during agitation so if it won't spin and is giving a mode shifter error, it sounds like the motor/inverter is bad. Try clearing the error code by unplugging the washer for 1 minute, then plug back in and open/close the lid 6 times within 12 seconds.
Eric
  #5 (permalink)
Old 02-26-2013, 06:56 AM
Junior Member
Default
OK, after the reset procedure the code changed. Now its 9. It looks like the best next step is to replace the motor.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Neptune will not spin but no error code bigmontana Washer Repair 1 10-14-2011 05:16 AM
Error Code reading Tonilyn Oven Repair (including Ranges and Cooktops) 3 09-23-2011 06:59 AM
How to test for F10 error code biscuit141 Oven Repair (including Ranges and Cooktops) 0 07-20-2010 08:28 PM
Ge Microwave Reading Code F 4 kimo Microwave Repair 0 02-08-2010 02:36 PM
Washer lights flash; code e41 mebebrb Washer Repair 4 04-28-2009 08:44 AM
