| » drains but doesn't always spin |
Model Number: WTW5310SQ0 Brand: Whirlpool Age: 1 - 5 years
About every 3rd load machine won't spin while draining. If you open and close the lid it will start spining. Everything works fine maybe 2 out of 3 times.
This washer has a neutral drain transmission. This means that directly after agitation, it should drain without spinning. After draining, the motor should pause for a few seconds which releases neutral drain. When the motor starts again, it should spin while continuing to drain. If the motor doesn't pause after draining, the timer is bad. By opening/closing the lid, you are pausing the motor. If the motor pauses but the basket doesn't start spinning when it starts again, you would need to remove the cabinet, jump out the lid switch and observe the clutch to determine if the clutch is slipping or if there is a problem with the transmissions neutral drain mechanism.
Eric Eric |
| Display Modes | |
| Spin cycle drains, but doesn't spin (Frigidaire Affinity) | tsteinruck | Washer Repair | 5 | 04-23-2012 02:34 PM |
| Drains, but won't spin without help | bsmall | Washer Repair | 1 | 06-29-2011 05:31 PM |
| washer drains but will not spin | tedpuhl | Washer Repair | 0 | 01-31-2010 09:59 AM |
| spin cycle drains but will not spin | dionnem1 | Washer Repair | 1 | 12-22-2009 04:24 PM |
| Spin Dry Cycle - Washer drains but tub doesn't spin | JARG | Washer Repair | 3 | 11-23-2009 09:22 AM |
