Discuss
Direct drive washer how to get brake shoe spring back in place
 in
Washer Repair
I replaced the brake shoes and am unable to get the spring that fits between the shoes back in place.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Direct drive washer how to get brake shoe spring back in place
  #1 (permalink)
Old 02-22-2013, 09:18 AM
Junior Member
OrvD is on a distinguished road
Unhappy Direct drive washer how to get brake shoe spring back in place
Brand: Whirlpool   Age: 1 - 5 years
I replaced the brake shoes and am unable to get the spring that fits between the shoes back in place. It is very difficult to compress the spring and push into position... help... is ther an eas way?
Ads By Google
  #2 (permalink)
Old 02-22-2013, 11:29 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Put the spring on before you place the cam release on. This allows the shoes to spread further apart making it easier to get the spring on. Then place the cam release over the tube and compress the shoes together with your hands so the cam drops in place.
Eric
  #3 (permalink)
Old 02-22-2013, 11:39 AM
Junior Member
Default
Thanks Eric... I did part of that and ended up putting the spring on first, then using a wide jaw pliers and my fingers, I aligned the holes of the brake pads and pushed them onto their post. It was awkward and required a few tries, but it worked. Then I put on the cam as you suggested.
... Orv D
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing direct drive washer brake shoes richappy Washer Repair 38 03-06-2013 03:11 PM
replacing drive coupleing on Whirlpool direct drive washer bbuck222 Washer Repair 2 08-06-2009 07:34 AM
Direct drive washer brake yurman Washer Repair 1 08-02-2009 04:35 AM
Replacing direct drive washer brake shoes richappy Forum Announcements 0 02-28-2009 07:38 AM
Direct Drive Washer JNOLES Washer Repair 1 09-19-2007 04:24 PM
