Discuss
drum removal for whirlpool
 in
Washer Repair
I have removed the agitator and the spanner nut shaken pulled , pushed and hit the center post with a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » drum removal for whirlpool
  #1 (permalink)
Old 02-21-2013, 01:56 PM
Junior Member
hnsberk is on a distinguished road
Default drum removal for whirlpool
Model Number: LSR7233EZO   Brand: Whirlpool   Age: More than 10 years
I have removed the agitator and the spanner nut shaken pulled , pushed and hit the center post with a rubber mallet but still the drum will not lift up. Also, I have put W40 however no result. Anybody can give me some suggestions?
hnsberk
Ads By Google
Related Models
Whirlpool LSR7233HQ0
Whirlpool LSR7233HZ0
Whirlpool LSR7300PQ0 Automatic Washer
Whirlpool LSR7300PQ1 Automatic Washer
Whirlpool LSR7300PQ2 Automatic Washer
Whirlpool LSR7333PQ0 Automatic Washer
Whirlpool LSR7333PQ1 Automatic Washer
Whirlpool LSR7333PQ3 Automatic Washer
Whirlpool LSR7333PQ4 Automatic Washer
Whirlpool LSR8010PQ0 Automatic Washer
Whirlpool LSR8010PQ1 Automatic Washer
Whirlpool LSR8010PQ2 Automatic Washer
Whirlpool LSR8010PT0 Automatic Washer
Whirlpool LSR8010PT1 Automatic Washer
Whirlpool LSR8010PT2 Automatic Washer
Whirlpool LSR8133HQ0
Whirlpool LSR8133HZ0
Whirlpool LSR8200EQ0
Whirlpool LSR8200EZ0
Whirlpool LSR8233EQ0
Whirlpool LSR8233EQ1
Whirlpool LSR8233EZ0
Whirlpool LSR8233EZ1
Whirlpool LSR8233JQ0
Whirlpool LSR8233JQ1
Whirlpool LSR8233JT0
Whirlpool LSR8233JT1
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0
Whirlpool LSR8433KQ1 Automatic Washer
Whirlpool LSR8433KQ2 Automatic Washer
Whirlpool LSR8433KT0
Whirlpool LSR8433KT1 Automatic Washer
Whirlpool LSR8433KT2 Automatic Washer
Whirlpool LSR8444LQ0
Whirlpool LSR8444LQ1 Automatic Washer
Whirlpool LSR8444LT0
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Whirlpool LSR9434PQ0 Automatic Washer
Whirlpool LSR9434PQ1 Automatic Washer
Whirlpool LSR9434PQ3 Automatic Washer
Whirlpool LSR9434PQ4 Automatic Washer
Whirlpool LSR9434PT0 Automatic Washer
Whirlpool LSR9434PT1 Automatic Washer
Whirlpool LSR9434PT3 Automatic Washer
Whirlpool LSR9434PT4 Automatic Washer
General Electric LSS25XGTABB Refrigerator
General Electric LSS25XGTAWW Refrigerator
General Electric LSS25XGTBBB Refrigerator
General Electric LSS25XGTBWW Refrigerator
General Electric LSS25XGTEBB Refrigerator
General Electric LSS25XGTEWW Refrigerator
General Electric LSS25XSTASS Refrigerator
General Electric LSS25XSTBSS Refrigerator
General Electric LSS25XSTESS Refrigerator
Whirlpool LSS7233AN0
Whirlpool LSS7233AN1
Whirlpool LSS7233AW0
Whirlpool LSS7233AW1
Whirlpool LSS7233DQ0
Whirlpool LSS8244AQ0
Whirlpool LSS8244AW0
Whirlpool LSS8244AZ0
Whirlpool LSS9244EQ0
Whirlpool LSS9244EZ0
Whirlpool LST6132AG0
Whirlpool LST6132AN0
Whirlpool LST6132AW0
Whirlpool LST6132BN0
Whirlpool LST6132BW0
Whirlpool LST6132BW1
Whirlpool LST6132DQ0
Whirlpool LST7233AG0
Whirlpool LST7233AN0
Whirlpool LST7233AN1
Whirlpool LST7233AQ0
Whirlpool LST7233AQ1
Whirlpool LST7233AW0
Whirlpool LST7233AW1
Whirlpool LST7233AZ0
Whirlpool LST7233AZ1
Whirlpool LST7233DQ0
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
Whirlpool LST8244AZ0
Whirlpool LST8244BQ0
Whirlpool LST8244BQ1
Whirlpool LST8244BW0
Whirlpool LST8244BZ0
Whirlpool LST8244BZ1
Whirlpool LST8244DQ0
Whirlpool LST8244DZ0
Whirlpool LST9245AN0
Whirlpool LST9245AW0
Whirlpool LST9245BN1
Whirlpool LST9245BQ0
Whirlpool LST9245BQ2
Whirlpool LST9245BW1
Whirlpool LST9245BZ0
Whirlpool LST9245BZ2
  #2 (permalink)
Old 02-21-2013, 03:43 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Rock the basket side to side real hard to break off the scam.
Worked for me.
Here are the breakdown diagrams and Agitator, Basket and Tub parts for Whirlpool LSR7233EZ0 - AppliancePartsPros.com
Post the results.
Simon.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 02-22-2013, 05:51 AM
Junior Member
Default drum removal for LSR7233EZO whirlpool washer
As I mantioned before I rocked the drum, someone lifted the drum while I hit the shaft no movement.
  #4 (permalink)
Old 02-22-2013, 06:27 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
I do not advise striking down on the agitator shaft. That shaft sits on top of a metal disk with a ball bearing under it inside the gearcase which could be damaged. The best method is to grab one side of the tub with both hands and really rock it up and down like your trying to break it to work it loose. The tub, drive block and spin tube have corroded together. Sometimes they just won't come apart without cutting. If you have to resort to banging on the drive block, I would advise removing the gearcase first which will also remove the agitator shaft.
Eric
  #5 (permalink)
Old 02-22-2013, 12:37 PM
Junior Member
I did takeout the shaft andhitthe centerpart whilesomeone else waspullin on the drum after it soaked overnight with w4o. I do need to take the drum out because the old style filter causes me to have alot of lint and want to replace it with the new style plugs. In order to do this I need to remove the drum. I am just about rocket out since that doesn't seem to work. Any other suggestions?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Drum removal aaron2011 Washer Repair 1 03-18-2011 02:05 PM
Whirlpool drum support roller removal? tdk Dryer Repair 1 11-05-2009 05:30 AM
Drum Removal Help HARRY HEN Washer Repair 1 10-20-2009 07:06 PM
Drum Removal Help HARRY HEN Washer Repair 1 10-20-2009 11:56 AM
Washer drum removal ianos Washer Repair 2 10-12-2008 03:59 PM
