Discuss
washer fills with cold water
 in
Washer Repair
When I select the hot water temp, washer usually fills mostly with water that is cold to the touch. While
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer fills with cold water
  #1 (permalink)
Old 02-19-2013, 03:40 PM
Junior Member
mlbraz is on a distinguished road
Default washer fills with cold water
Model Number: 11021102011   Brand: Kenmore   Age: 1 - 5 years
When I select the hot water temp, washer usually fills mostly with water that is cold to the touch. While the water inside tub is cold, there appears to be water flow through the hot water hose and hose feels warm-to-hot to the touch.
Professional repair tech has checked washer on 2-separate visits. When repair tech is here can't reproduce the problem--washer fills with warm-to-hot water when hot water is selected. However, when the repair tech isn't here and I try using the washer with the hot water temp selected, again the tub fills with water that is cold to the touch.
Have paid fees for 2 visits by repair tech. If troubleshooting and repair is relatively easy, I'd like to give it a shot. Can you help?
Ads By Google
Related Models
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
Kenmore 11022032101 WASHER
Kenmore 11022032102 AUTOMATIC WASHER
Kenmore 11022036100 WASHER
Kenmore 11022036101 WASHER
Kenmore 11022036102 AUTOMATIC WASHER
Kenmore 11022042100 WASHER
Kenmore 11022042101 WASHER
Kenmore 11022042102 AUTOMATIC
Kenmore 11022052100 WASHER
Kenmore 11022052101 WASHER
Kenmore 11022052102 AUTOMATIC WASHER
Kenmore 11022054100 WASHER
Kenmore 11022054101 WASHER
Kenmore 11022054102 AUTOMATIC WASHER
Kenmore 11022056100 WASHER
Kenmore 11022056101 WASHER
Kenmore 11022056102 AUTOMATIC WASHER
Kenmore 11022062100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022062101 WASHER
Kenmore 11022062102 AUTOMATIC WASHER
Kenmore 11022064100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022064101 WASHER
Kenmore 11022064102 AUTOMATIC WASHER
Kenmore 11022066100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022066101 WASHER
Kenmore 11022066102 AUTOMATIC WASHER
Kenmore 11022082100 WASHER
Kenmore 11022082101 AUTOMATIC WASHER
Kenmore 11022082102 AUTOMATIC
Kenmore 11022084100 WASHER
Kenmore 11022084101 AUTOMATIC WASHER
Kenmore 11022084102 AUTOMATIC
Kenmore 11022086100 WASHER
Kenmore 11022086101 AUTOMATIC WASHER
Kenmore 11022086102 AUTOMATIC
Kenmore 11022292100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022294100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022422100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022432100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022442100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022622100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022632100 WASHER
Kenmore 11022642100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022652100 COMPACT WASHER
Kenmore 11022662100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022692101 AUTOMATIC WASHER
Kenmore 11023012100 AUTOMATIC WASHER
Kenmore 11023012101 AUTOMATIC WASHER
Kenmore 11023012102 AUTOMATIC WASHER
Kenmore 11023014100 AUTOMATIC WASHER
Kenmore 11023014101 AUTOMATIC WASHER
Kenmore 11023014102 AUTOMATIC WASHER
Kenmore 11023022100 AUTOMATIC WASHER
Kenmore 11023022101 AUTOMATIC WASHER
Kenmore 11023022102 AUTOMATIC WASHER
Kenmore 11023024100 AUTOMATIC WASHER
Kenmore 11023024101 AUTOMATIC WASHER
Kenmore 11023024102 AUTOMATIC WASHER
Kenmore 11023032100 WASHER
Kenmore 11023032101 AUTOMATIC WASHER
Kenmore 11023032102 AUTOMATIC WASHER
Kenmore 11023034100 WASHER
Kenmore 11023034101 AUTOMATIC WASHER
Kenmore 11023034102 AUTOMATIC WASHER
Kenmore 11023036100 WASHER
Kenmore 11023036101 AUTOMATIC WASHER
Kenmore 11023036102 AUTOMATIC WASHER
Kenmore 11023652200 AUTOMATIC WASHER
Kenmore 11023662200 AUTOMATIC WASHER
Kenmore 11023692200 AUTOMATIC WASHER
Kenmore 11023712200 AUTOMATIC WASHER
Kenmore 11023722200 AUTOMATIC WASHER
Kenmore 11023732200 AUTOMATIC WASHER
Kenmore 11023812100 AUTOMATIC WASHER
Kenmore 11023822100 AUTOMATIC WASHER
Kenmore 11023832100 AUTOMATIC WASHER
Kenmore 11023902200 AUTOMATIC WASHER
Kenmore 11023902201 AUTOMATIC WASHER
Kenmore 11023904200 AUTOMATIC WASHER
Kenmore 11023904201 AUTOMATIC WASHER
Kenmore 11023912100 AUTOMATIC WASHER
Kenmore 11023912101 AUTOMATIC WASHER
Kenmore 11023912102 AUTOMATIC WASHER
Kenmore 11023922200 AUTOMATIC WASHER
Kenmore 11023922201 AUTOMATIC WASHER
Kenmore 11023924200 AUTOMATIC WASHER
Kenmore 11023924201 AUTOMATIC WASHER
Kenmore 11023932200 WASHER
Kenmore 11023934200 WASHER
Kenmore 11024082200 AUTOMATIC WASHER
Kenmore 11024084200 AUTOMATIC WASHER
Kenmore 11024086200 AUTOMATIC WASHER
Kenmore 11024422300 AUTOMATIC WASHER
Kenmore 11024432300 AUTOMATIC WASHER
Kenmore 11024442300 AUTOMATIC WASHER
Kenmore 11024622300 AUTOMATIC WASHER
Kenmore 11024632300 AUTOMATIC WASHER
Kenmore 11024642300 AUTOMATIC WASHER
Kenmore 11024652300 AUTOMATIC WASHER
Kenmore 11024692300 AUTOMATIC WASHER
Kenmore 11024812200 AUTOMATIC WASHER
Kenmore 11024812201 AUTOMATIC WASHER
Kenmore 11024822200 AUTOMATIC WASHER
Kenmore 11024822201 AUTOMATIC WASHER
Kenmore 11024832200 AUTOMATIC WASHER
Kenmore 11024832201 AUTOMATIC WASHER
Kenmore 11024892300 AUTOMATIC
Kenmore 11024894300 AUTOMATIC
Kenmore 11024902200 AUTOMATIC WASHER
Kenmore 11024902201 AUTOMATIC WASHER
Kenmore 11024904200 AUTOMATIC WASHER
Kenmore 11024904201 AUTOMATIC WASHER
  #2 (permalink)
Old 02-20-2013, 05:59 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Well I don't understand how hot water can be flowing in but it is cold once it is inside the tub, there is no way that the water can get cold quickly.
This model does appear to have an electronic control unit. That could be your problem and I would try changing it out. If you buy from this site and the part doe not fix the problem you can return it.
I sympathize with your two repair costs, it is really frustrating not to have the problem when a tech visit. But the fact that it is intermittent is one reason to suspect the control unit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
My washer fills so slowly with cold water & stops before rinse cycle JennH Washer Repair 6 07-29-2012 10:20 AM
Whirlpool combo washer cold water fills slow TammyJJ Washer Repair 3 04-26-2011 02:38 PM
Maytag washer fills cold water continually Kilikina Washer Repair 1 03-17-2011 06:22 AM
washer only fills up with cold water dancergirl Washer Repair 1 02-25-2011 03:02 PM
Cold water fills very slow dreyn Washer Repair 1 07-13-2009 03:58 PM
