| » Whirlpool Washer only operates in Extra Rinse |
Model Number: WTW57ESVW0 Brand: Whirlpool Age: 1 - 5 years
Our whirlpool washer will only work in the extra rinse cycle. I have replaced both the timer and the auto load sensing switch.
The washer fills correctly, agitates, and rinses all in the extra rinse cycle but will not in any other cycle. Any ideas? Ads By Google Related Models |
Hi.
Did you replace the W10292584? Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Yes, I replaced the load sensing switch (W10292584, replacement for W10177795) and the timer (W10177827).
Other forums I'd read across the web pointed to the load sensing switch first, then the timer second. I have replaced both and the machine's behavior has not changed; it still only operates in "Extra Rinse" cycle. Some posts have suggested the lid switch, but when the machine is running in the "Extra Rinse" cycle and the lid is opening, the lid switch shuts down the machine as intended. Any thoughts would be greatly appreciated. |
On which water temperature it was set? Set it for cold water only and give it a try. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| Maytag Stops at Extra Rinse | chasepawpaw | Washer Repair | 2 | 07-28-2012 12:16 AM |
| Maytag Top Load Won't Final Spin on Extra Rinse | jdomke1 | Washer Repair | 0 | 06-18-2012 11:44 AM |
| whirlpool extra care system stops at rinse cycle | mattyjohn | Washer Repair | 5 | 12-09-2011 03:54 PM |
| washer continues to fill when extra rinse buton is depressed | dpinka | Washer Repair | 1 | 01-24-2011 05:14 PM |
| Extra rinse problems/Soapy stains on clothes | Pankaj101 | Washer Repair | 0 | 08-21-2008 06:30 PM |
