Discuss
Broken Tub Shell - worth repairing???
 in
Washer Repair
I have a front load washer that made a loud noise and started leaking water during the spin cycle. I
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Broken Tub Shell - worth repairing???
  #1 (permalink)
Old 02-19-2013, 01:33 PM
Junior Member
PhoneManJay is on a distinguished road
Default Broken Tub Shell - worth repairing???
Model Number: FTF530ES0   Brand: Frigidaire   Age: 5 - 10 years
I have a front load washer that made a loud noise and started leaking water during the spin cycle. I have found that it has a broken tub shell and the drum seems to be sitting lower than usual inside of the tub shell. The drum also seems to have become disconnected from the large round rubber seal at the door. I believe the machine was overloaded and loaded unevenly, causing the drum to hit the tub shell hard enough to break it. I do not see any other obvious visible damage.. the springs and shocks seem to be in good working order and the drum still seems to rotate freely. I believe the tub shell runs somewhere between $150 and $200..
Does this sound like a straightforward shell replacement? Are there most likely more broken parts? Is the shell replacement as difficult as it looks?
I guess bottom line is: Is it worth having a tech attempt to repair the machine or will I be approaching the cost of a new machine anyway?
Thanks in advance for your time and advice! It is greatly appreciated!!
Ads By Google
Related Models
Frigidaire FTF530ES0 Frigidaire/washer
Frigidaire FTF530ES1 Frigidaire/washer
Frigidaire FTF530FS0 Frigidaire/washer
Frigidaire FTF630AS0 Frtld Washer - Frigidaire
Frigidaire FTFB2940FE0 Frigidaire/washer
Frigidaire FTFB4000FS0 Frigidaire/washer
Frigidaire FTFB4000FS1 Frigidaire/washer
Frigidaire FTFB4000GS0 Frigidaire/washer
Frigidaire FTR630AS0 Frtld Washer - Frigidaire
Frigidaire FU017RRW1 Wwh(v2) / Upright Freezer
Frigidaire FU018TRW1 Wwh(v3) / Upright Freezer
Frigidaire FU019ARW5 Wwh(v3) / Upright Freezer
Frigidaire FU054ERD1 Wwh(v1) / Upright Freezer
Frigidaire FU054ERD2 Wwh(v2) / Upright Freezer
Frigidaire FU054ERD3 Wwh(v3) / Upright Freezer
Frigidaire FU054ERW1 Wwh(v4) / Upright Freezer
Frigidaire FU054ERW2 Wwh(v5) / Upright Freezer
Frigidaire FU100JRW1 Wwh(v1) / Upright Freezer
Frigidaire FU100JRW2 Wwh(v2) / Upright Freezer
Frigidaire FU100JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU100JRW4 Wwh(v1) / Upright Freezer
Frigidaire FU100JRW5 Wwh(v1) / Upright Freezer
Frigidaire FU100LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU100LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU100LRW3 Wwh(v3) / Upright Freezer
Frigidaire FU100LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU100LRW5 Wwh(v2) / Upright Freezer
Frigidaire FU134ERW1 Wwh(v1) / Upright Freezer
Frigidaire FU134ERW2 Wwh(v2) / Upright Freezer
Frigidaire FU134ERW3 Wwh(v3) / Upright Freezer
Frigidaire FU134ERW4 Wwh(v4) / Upright Freezer
Frigidaire FU134JRW1 Wwh(v1) / Upright Freezer
Frigidaire FU134JRW2 Wwh(v2) / Upright Freezer
Frigidaire FU134JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU134JRW4 Wwh(v2) / Upright Freezer
Frigidaire FU134JRW5 Wwh(v1) / Upright Freezer
Frigidaire FU134LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU134LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU134LRW3 Wwh(v3) / Upright Freezer
Frigidaire FU134LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU134LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU161ERW1 Wwh(v1) / Upright Freezer
Frigidaire FU161ERW2 Wwh(v2) / Upright Freezer
Frigidaire FU161ERW3 Wwh(v3) / Upright Freezer
Frigidaire FU161ERW4 Wwh(v4) / Upright Freezer
Frigidaire FU161ERW5 Wwh(v5) / Upright Freezer
Frigidaire FU161ERW6 Wwh(v6) / Upright Freezer
Frigidaire FU161JRW1 Wwh(v0) / Upright Freezer
Frigidaire FU161JRW2 Wwh(v0) / Upright Freezer
Frigidaire FU161JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU161LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU161LRW3 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU161LRW6 Wwh(v1) / Upright Freezer
Frigidaire FU166ERW1 Wwh(v7) / Upright Freezer
Frigidaire FU166ERW2 Wwh(v8) / Upright Freezer
Frigidaire FU166ERW3 Wwh(v9) / Upright Freezer
Frigidaire FU166ERW4 Wwh(v10) / Upright Freezer
Frigidaire FU166HRD1 Wwh(v1) / Upright Freezer
Frigidaire FU166HRD2 Wwh(v2) / Upright Freezer
Frigidaire FU166HRW1 Wwh(v3) / Upright Freezer
Frigidaire FU166HRW2 Wwh(v4) / Upright Freezer
Frigidaire FU166HRW3 Wwh(v5) / Upright Freezer
Frigidaire FU168JRD1 Wwh(v1) / Upright Freezer
Frigidaire FU168JRD2 Wwh(v2) / Upright Freezer
Frigidaire FU168JRD3 Wwh(v1) / Upright Freezer
Frigidaire FU168JRW1 Wwh(v3) / Upright Freezer
Frigidaire FU168JRW2 Wwh(v4) / Upright Freezer
Frigidaire FU168JRW3 Wwh(v2) / Upright Freezer
Frigidaire FU168LRW1 Wwh(v2) / Upright Freezer
Frigidaire FU168LRW2 Wwh(v4) / Upright Freezer
Frigidaire FU169ERD1 Wwh(v1) / Upright Freezer
Frigidaire FU169ERD2 Wwh(v2) / Upright Freezer
Frigidaire FU169ERW1 Wwh(v3) / Upright Freezer
Frigidaire FU169ERW2 Wwh(v4) / Upright Freezer
Frigidaire FU169JRD1 Wwh(v1) / Upright Freezer
Frigidaire FU169JRD2 Wwh(v2) / Upright Freezer
Frigidaire FU169JRD3 Wwh(v4) / Upright Freezer
Frigidaire FU169JRW1 Wwh(v2) / Upright Freezer
Frigidaire FU169JRW2 Wwh(v1) / Upright Freezer
Frigidaire FU169JRW3 Wwh(v3) / Upright Freezer
Frigidaire FU169LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU169LRW2 Wwh(v1) / Upright Freezer
Frigidaire FU169LRW3 Wwh(v2) / Upright Freezer
Frigidaire FU169LRW4 Wwh(v3) / Upright Freezer
Frigidaire FU169LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU169LRW6 Wwh(v1) / Upright Freezer
Frigidaire FU196ERW1 Wwh(v1) / Upright Freezer
Frigidaire FU196ERW2 Wwh(v2) / Upright Freezer
Frigidaire FU196ERW3 Wwh(v3) / Upright Freezer
Frigidaire FU196JRW1 Wwh(v0) / Upright Freezer
Frigidaire FU196JRW2 Wwh(v4) / Upright Freezer
Frigidaire FU196JRW3 Wwh(v1) / Upright Freezer
Frigidaire FU196LRW1 Wwh(v1) / Upright Freezer
Frigidaire FU196LRW2 Wwh(v2) / Upright Freezer
Frigidaire FU196LRW3 Wwh(v3) / Upright Freezer
Frigidaire FU196LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU196LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU196LRW6 Wwh(v1) / Upright Freezer
Frigidaire FU199ERD1 Wwh(v5) / Upright Freezer
Frigidaire FU199ERD2 Wwh(v6) / Upright Freezer
Frigidaire FU199ERW1 Wwh(v7) / Upright Freezer
Frigidaire FU199ERW2 Wwh(v8) / Upright Freezer
Frigidaire FU199JRD1 Wwh(v0) / Upright Freezer
Frigidaire FU199JRD2 Wwh(v1) / Upright Freezer
Frigidaire FU199JRW1 Wwh(v0) / Upright Freezer
Frigidaire FU199JRW2 Wwh(v2) / Upright Freezer
Frigidaire FU199JRW4 Wwh(v1) / Upright Freezer
Frigidaire FU199LRW1 Wwh(v2) / Upright Freezer
Frigidaire FU199LRW2 Wwh(v3) / Upright Freezer
Frigidaire FU199LRW3 Wwh(v1) / Upright Freezer
Frigidaire FU199LRW4 Wwh(v1) / Upright Freezer
Frigidaire FU199LRW5 Wwh(v1) / Upright Freezer
Frigidaire FU211ERW1 Wwh(v4) / Upright Freezer
Frigidaire FU211ERW2 Wwh(v5) / Upright Freezer
Frigidaire FU211ERW3 Wwh(v6) / Upright Freezer
Frigidaire FU211ERW4 Wwh(v7) / Upright Freezer
Frigidaire FU211JRW1 Wwh(v1) / Upright Freezer
  #2 (permalink)
Old 02-20-2013, 06:00 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
No, sorry, you will need to get a new machine as it is not worth the cost to fix this one.
__________________
  #3 (permalink)
Old 02-22-2013, 09:12 AM
Junior Member
Default
Bummer! Kind of what I figured though.. Thank you very much for your response!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Is it worth Repairing? JVM140001 manager3 Microwave Repair 28 12-06-2011 03:05 PM
Worth Repairing? Beaver Washer Repair 2 06-18-2009 05:43 PM
Is this GE Microwave worth repairing? amkells Microwave Repair 3 10-21-2008 11:05 PM
is it worth repairing an 18 year old Whirlpool vb663 Washer Repair 1 07-14-2008 03:41 AM
is it worth repairing an 18 year old Whirlpool vb663 Dishwasher Repair 0 07-13-2008 10:12 AM
