| » Maytag Bravos MCT: reservoirs don't drain |
Model Number: MVWB750WQ Brand: Maytag Age: 1 - 5 years
Have 3 yo Bravos MCT.....problems from the beginning but this pertains to the bleach and softener reservoirs not draining after going through complete cycles.
Frequently they will still be full when the load is done and over time the softener liquid will become gel-like. I have run hot water through them to clean out, i have somewhat removed them (cannot seem to dislocate the tube from the reservoir) out of their pocket to clean, but the problem seems to persist Thank you Mark Ads By Google Related Models |
On this model you have multiple electrically control valves which open up to divert water to the various reservoirs when called for. If one was a problem I would think it was the valve assembly, with two as a problem, not so sure.
Here is what you might try. 1. Use a meter to see if the bleach reservoir is getting power when it should. If it is, the problem is a clog or the valve assembly is bad. If it is not, the control unit is likely the issue, it is not sending power to open the valve when it should. 2. Go ahead and replace the valve assembly. If you buy the part from this site and it is not needed or does not fix the problem you can return it.
__________________
| Display Modes | |
| maytag bravos | Panterin | Washer Repair | 0 | 06-07-2012 01:17 PM |
| Maytag bravos drain pump sucked in dish rag | petitmathieu | Washer Repair | 3 | 04-12-2012 12:26 PM |
| Maytag Bravos | Dan boudreau | Washer Repair | 0 | 12-11-2011 10:55 AM |
| maytag bravos | Daradale | Washer Repair | 0 | 09-15-2011 04:13 PM |
| maytag bravos washer | wrenchbender1 | Washer Repair | 1 | 08-10-2009 08:12 AM |
