Discuss
Drain blockage code F 02
 in
Washer Repair
The code on our washer says drain blockage (F 02). I cleaned out all tubes from the drain pump assembly
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Drain blockage code F 02
  #1 (permalink)
Old 02-17-2013, 09:33 PM
Junior Member
Matts67ken is on a distinguished road
Default Drain blockage code F 02
Model Number: 110.42822200   Brand: Kenmore   Age: 5 - 10 years
The code on our washer says drain blockage (F 02). I cleaned out all tubes from the drain pump assembly to the house wall drain with no luck. The pump runs but sounds like it is pushing as much air as water. Each time I take the hoses apart, to check for blockage, the water level is up to the highest point in the drain lines before it would drain by gravity into the house drain. I took the drain pump assembly apart to see if the impeller was broken. It looks small for the area it spins in, but it is not missing any blades. I looked online to see if I could get a picture of the impeller to compare, but no luck. Any Ideas
Matt
Ads By Google
Related Models
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42836201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42922200  WASHER
Kenmore 110.42924200  WASHER
Kenmore 110.42926200  WASHER
Kenmore 110.42932200  WASHER
Kenmore 110.42934200  WASHER
Kenmore 110.42936200  WASHER
Kenmore 110.4319351  BURNER ASSEMBLY
Kenmore 110.4319410  GAS DRYER BURNER
Kenmore 110.44832200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44834200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44836200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44932200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44934200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44936200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.4760294  WASHER
Kenmore 110.4766195  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.4766295  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.48182790  AUTOMATIC WASHER
Kenmore 110.48182791  AUTOMATIC WASHER
Kenmore 110.48184790  AUTOMATIC WASHER
Kenmore 110.48184791  AUTOMATIC WASHER
Kenmore 110.48722790  COMPACT AUTOMATIC WASHER
Kenmore 110.48722791  COMPACT AUTOMATIC WASHER
Kenmore 110.48724790  COMPACT AUTOMATIC WASHER
Kenmore 110.48724791  COMPACT AUTOMATIC WASHER
Kenmore 110.49182990  AUTOMATIC WASHER
Kenmore 110.49182991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.49740  STACK STAND KIT
Kenmore 110.508802  KENMORE ELECTRIC DRYER
Kenmore 110.5807100  KENMORE GAS DRYER
Kenmore 110.5807300  KENMORE GAS DRYER
Kenmore 110.5807410  KENMORE GAS DRYER
Kenmore 110.5807500  KENMORE GAS DRYER
Kenmore 110.5807501  KENMORE GAS DRYER
Kenmore 110.5807700  KENMORE GAS DRYER
Kenmore 110.5807701  KENMORE GAS DRYER
Kenmore 110.5807800  KENMORE GAS DRYER
Kenmore 110.5807801  GAS DRYER
Kenmore 110.5807810  KENMORE GAS DRYER
Kenmore 110.5807811  KENMORE GAS DRYER
Kenmore 110.5807850  KENMORE GAS DRYER
Kenmore 110.5807851  GAS DRYER
Kenmore 110.5807860  KENMORE GAS DRYER
Kenmore 110.5807861  KENMORE GAS DRYER
Kenmore 110.5807950  KENMORE GAS DRYER
Kenmore 110.5807951  GAS DRYER
Kenmore 110.5807960  KENMORE GAS DRYER
Kenmore 110.5807961  KENMORE GAS DRYER
Kenmore 110.5808000  KENMORE ELECTRIC DRYER
Kenmore 110.5808010  KENMORE ELECTRIC DRYER
Kenmore 110.5808100  KENMORE ELECTRIC DRYER
Kenmore 110.5808300  KENMORE ELECTRIC DRYER
Kenmore 110.5808500  KENMORE ELECTRIC DRYER
Kenmore 110.5808700  KENMORE ELECTRIC DRYER
Kenmore 110.5808800  KENMORE ELECTRIC DRYER
Kenmore 110.5808810  KENMORE ELECTRIC DRYER
Kenmore 110.5808850  KENMORE ELECTRIC DRYER
Kenmore 110.5808860  KENMORE ELECTRIC DRYER
Kenmore 110.5808950  KENMORE ELECTRIC DRYER
Kenmore 110.5808960  KENMORE ELECTRIC DRYER
Kenmore 110.5817500  KENMORE GAS DRYER
Kenmore 110.5817501  KENMORE GAS DRYER
Kenmore 110.5817800  KENMORE GAS DRYER
Kenmore 110.5817801  KENMORE GAS DRYER
Kenmore 110.5817811  KENMORE GAS DRYER
Kenmore 110.5817820  KENMORE GAS DRYER
Kenmore 110.5817830  KENMORE GAS DRYER
Kenmore 110.5818500  KENMORE ELECTRIC DRYER
Kenmore 110.5818800  KENMORE ELECTRIC DRYER
Kenmore 110.5818810  KENMORE ELECTRIC DRYER
Kenmore 110.5818820  KENMORE ELECTRIC DRYER
Kenmore 110.5907000  KENMORE GAS DRYER
Kenmore 110.5907100  KENMORE GAS DRYER
Kenmore 110.5907300  KENMORE GAS DRYER
Kenmore 110.60012000  COMMERCIAL ELECTRIC DRYER
Kenmore 110.60012001  COMMERCIAL ELECTRIC DRYER
Kenmore 110.60172000  KENMORE COMMERCIAL DRYER
Kenmore 110.60172001  COMMERCIAL ELECTRIC DRYER
Kenmore 110.60182000  COMMERCIAL ELECTRIC DRYER
Kenmore 110.60232000  COMMERCIAL ELECTRIC DRYER
Kenmore 110.60232001  COMMERCIAL ELECTRIC DRYER
Kenmore 110.6117202  KENMORE COIN-OPERATED GAS DRYER
Kenmore 110.6117203  KENMORE COIN OPERATED GAS DRYER
Kenmore 110.6117213  KENMORE COIN OPERATED GAS DRYER
Kenmore 110.6117233  KENMORE COIN-OPERATED GAS DRYERS
Kenmore 110.6117234  KENMORE COIN-OPERATED GAS DRYER
Kenmore 110.6117235  KENMORE COIN-OPERATED GAS DRYERS
Kenmore 110.6117243  KENMORE COIN-OPERATED GAS DRYERS
Kenmore 110.6117244  KENMORE COIN-OPERATED GAS DRYER
Kenmore 110.6117245  KENMORE COIN-OPERATED GAS DRYERS
Kenmore 110.6117253  KENMORE COIN-OPERATED GAS DRYERS
Kenmore 110.6117254  KENMORE COIN-OPERATED GAS DRYER
Kenmore 110.6117255  KENMORE COIN-OPERATED GAS DRYERS
Kenmore 110.6118202  KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 110.6118233  KENMORE COIN-OPERATED ELECTRIC DRYERS
Kenmore 110.6118234  KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 110.6118235  KENMORE COIN-OPERATED ELECTRIC DRYERS
Kenmore 110.6118243  KENMORE COIN-OPERATED ELECTRIC DRYERS
Kenmore 110.6118244  KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 110.6118245  KENMORE COIN-OPERATED ELECTRIC DRYERS
Kenmore 110.6118253  KENMORE COIN-OPERATED ELECTRIC DRYERS
Kenmore 110.6118254  KENMORE COIN-OPERATED ELECTRIC DRYER
Kenmore 110.6118255  KENMORE COIN-OPERATED ELECTRIC DRYERS
Kenmore 110.62182100  COMMERCIAL ELECTRIC DRYER
Kenmore 110.62182102  ELECTRIC DRYER
Kenmore 110.66051690  COMMERICAL ELECTRIC DRYER
Kenmore 110.66058690  COMMERICAL ELECTRIC DRYER
Kenmore 110.66071690  COMMERCIAL DRYER
  #2 (permalink)
Old 02-19-2013, 04:28 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
This does sound like a pump problem, that it is failing to 'prime' in some way.
Try replacing it and see if that fixes your problem. If you buy from this site and don't need a new pump you can return it.
__________________
  #3 (permalink)
Old 02-22-2013, 07:59 PM
Junior Member
Default
I received the pump last night from this site, installed it with no change. It does the exact same thing. The washer will run half way through the cycle and comes up with the code F 02. Drain blockage. Any other suggestions.
Thanks Matt
  #4 (permalink)
Old 02-23-2013, 05:32 AM
Senior Expert
APP Volunteer
Default
Darn, had hoped that would work.
The next set of suspects are the circuit boards. See if you can test them using the techniques on the tech sheets you should have found under the top or inside the lower service panel. Unfortunately you may have to just replace them one by one to see if that fixes things.
Again, if you buy from this site you can return the parts you don't need. Yes, I know this doesn't sound very scientific, but that's how they repair these models these days.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Bravo will not drain (Long drain code F32) tjemery Washer Repair 0 10-06-2012 02:42 PM
GE Artica ice blockage issue kleverkn Refrigerator & Freezer Repair 1 10-16-2010 09:02 AM
Water blockage on GSD2200D03 72and86 Dishwasher Repair 1 07-30-2010 06:41 PM
ice maker blockage in door damgecontrolman1 Refrigerator & Freezer Repair 1 06-28-2010 10:15 AM
Gets Hot, Tumbles, No Blockage - Doesn't Dry chinahorse Dryer Repair 1 03-08-2010 03:03 AM
