| » Cabrio ul/f51 code |
Model Number: wtw6600sb2 Brand: Whirlpool Age: 1 - 5 years
I would first like to give a little service history ; three years ago the control board was replaced,two years ago the drum and a year ago the drain pump was replaced. Recently started receiving the UL code so I replaced the suspension rod kit, once I did that it started showing the F51 code as well.I double checked for obstructions with the tub and checked the center bolt of the cover to the RPS,which was loose. I tightened that and the F51 code was corrected.I still however have the UL issue. The drum does not seem to spin perfectly centered at higher speed.The only stored code is F51. Not sure what to do next, RPS,stator or both? Possibly something else ? Any help/advice would be very appriciated.
Thanks in advance Ads By Google Related Models |
| Display Modes | |
| F50 Code on Cabrio | manwithplan46151 | Washer Repair | 2 | 09-28-2011 06:05 AM |
| f1 code on cabrio washer | susanv | Washer Repair | 4 | 08-09-2011 09:29 AM |
| whirlpool cabrio ol code | tatt2blvd | Washer Repair | 1 | 04-06-2011 06:02 PM |
| Whirlpool Cabrio F code | bdbbrown | Washer Repair | 5 | 07-14-2010 08:33 AM |
| Whirlpool Cabrio dU code | tarbarr | Washer Repair | 3 | 09-22-2009 12:30 PM |
