| » Water doesn't turn off |
Model Number: WCSR2080B2WW Brand: GE Age: 5 - 10 years
Water overflowed as wouldn't stop. I turned off the water supply. I then triggered the cycles to drain water from the tub. I turned water back on. I turned the washer back on and now tub will not fill. Help!
Ads By Google Related Models Last edited by Roddess : 02-17-2013 at 08:30 AM. |
I did fully drain all the water...help!
Remove the front panel and check the air dome and hose on the lower left side of the tub for gunk. Pull hose off air dome to clean out any gunk and use a turkey baster with hot water to flush out the air dome. Be careful you don't break the nipple off the air dome, the air dome is not removable/replaceable.
Eric |
| Display Modes | |
| Washer puts water in drum does not turn only hums and water does not drain | vsquared | Washer Repair | 1 | 07-04-2012 10:49 AM |
| Water but Wash Arm Does Not Turn | jimbmor | Dishwasher Repair | 3 | 04-25-2012 11:09 AM |
| Water will not turn off | KRidgill | Refrigerator & Freezer Repair | 1 | 08-03-2009 01:22 PM |
| Water fill won't turn off | kirkfogy | Washer Repair | 1 | 07-04-2009 06:57 AM |
| Spray arm has water, but does not turn | LLS | Dishwasher Repair | 2 | 03-23-2008 12:41 PM |
