| » GE washing machine will not fill |
Model Number: wdsr2080d5ww Brand: -brand- Age: Less than 1 year
If we leave it on Cold and the Large setting it will work for a few loads and then back to the filling problem.
I have replaced the timer, level control and checked for a clog in the float tube. What next? Replace rotary for size option? Ads By Google Related Models |
Disconnect the water supply hoses at the back of the washer and check the screens inside the washer inlet valve assembly for debris. Verify that you have hot water by directing the hot water hose directly into the tub. If these are ok, you may have a faulty water temperature switch or a faulty hot water valve solenoid which would require replacement of the valve assembly.
Eric |
| Display Modes | |
| Water does not fill washing machine | BrentN. | Washer Repair | 0 | 10-13-2012 06:05 AM |
| Washing machine will not fill with water | KimPyles | Washer Repair | 6 | 05-03-2011 01:33 PM |
| Washing Machine wont fill up | jedenco | Washer Repair | 0 | 03-17-2010 06:53 AM |
| Washing machine does not fill up with water | Eddiedean | Washer Repair | 1 | 01-29-2010 11:14 AM |
| washing machine won't fill up | Diana Banana | Washer Repair | 1 | 01-03-2009 06:01 PM |
