Discuss
Top Load Washer Noise
 in
Washer Repair
Recently my top load washer is making extremely loud noises during the spin cycles mostly. The noise is a combination
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Top Load Washer Noise
  #1 (permalink)
Old 02-16-2013, 08:36 AM
Junior Member
Katrina2009 is on a distinguished road
Default Top Load Washer Noise
Brand: GE   Age: 1 - 5 years
Recently my top load washer is making extremely loud noises during the spin cycles mostly. The noise is a combination of what could be described as a scratching/scraping, high pitched noise with the basket while also a second noise that is louder more thud-ish like sound. It's just the noise right now, but didn't want the problem to increase. The washer is still cleaning, so we're continuing to use it, but just very loud and annoying. I would greatly appreciate any help! Thanks!
Ads By Google
  #2 (permalink)
Old 02-17-2013, 04:33 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hard to say without a model number, post one and lets see what your machine looks like.
The problem might be as simply as something caught between the basket and tub or something in the pump.
__________________
  #3 (permalink)
Old 02-19-2013, 08:29 PM
Junior Member
Default Model Number
Sorry... Here it is! WHDSR316G2WW
  #4 (permalink)
Old 02-20-2013, 06:27 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Remove the front panel of the washer by inserting a putty knife into the top groove of the panel in line with the lid opening on each side to release the clips. Pull slightly on the front panel when inserting the putty knife. After releasing the clips, tilt the panel outward and lift off from the cabinet. Look closely with flashlight at the bottom of the tub assembly to see if the main drive pulley or motor shaft are hitting the bottom of the washer while in spin mode.
Eric
  #5 (permalink)
Old 03-10-2013, 10:12 AM
Junior Member
Default
I removed the front panel and found during a cycle the pulley is scrapping at the bottom on the frame so it's metal scrapping metal... And possibly the front metal pieces under the motor are scrapping as well.
  #6 (permalink)
Old 03-10-2013, 11:12 AM
Expert
APP Volunteer
Default
Could be a sagging front apron, which is a known issue with this washer. There is a kit available and if you complain to GE they should provide you one free of charge. You need to remove the top cover to see if this is the problem. You would see the top lip of the cabinet bent down causing the entire suspension assembly to lower. It could also be broken suspension rod supports. You will notice that the tub assembly is supported by four suspension rods hanging from the top front and rear aprons. The rod supports are the little "cups" that the rods hang from. Worn out suspension rods can also cause this problem but I think it is most likely a sagging apron.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
High pitched noise Whirlpool top load washer veralynn Washer Repair 1 02-27-2010 05:33 PM
GE washer making load noise M. Campbell Washer Repair 0 02-25-2010 03:26 PM
Load Thumping Noise & Unbalanced Condition On GE front load washer Luke Vincent Washer Repair 2 08-06-2009 05:43 PM
Washer makes load noise during spin driley Washer Repair 7 11-10-2008 11:53 AM
Washer noise on spin cycle...not unbalanced load marykelly7 Washer Repair 3 08-12-2007 08:50 AM
