Discuss
Kenmore not draining
 in
Washer Repair
Can you upload a clear photo of the wiring diagram and timer chart? According to the sears parts website, your
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore not draining
  #11 (permalink)
Old 03-03-2013, 08:25 AM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Can you upload a clear photo of the wiring diagram and timer chart? According to the sears parts website, your washer has a 3-speed motor which would have the extra connector with wht/vio and wht/orn wires. The water level switch only places the machine in agitation mode and provides power to the timer motor during agitate. At the end of agitate mode, a set of timer contacts (#2)(pressure switch bypass) close to provide power to the timer motor and main drive motor. This is in series with the lid switch, so it appears to be either a bad lid switch, timer, or faulty wire connector/connection.
Eric
Ads By Google
  #12 (permalink)
Old 03-05-2013, 05:22 PM
Junior Member
capnrobi is on a distinguished road
Default
It is working.
Thank you Gene, Thank you Eric
It was either a lid switch problem right at the connector,
or fixed while moving things around for tests.
>Eric your washer has a 3-speed motor which would have ...
Yes, a separate connector 4.5 ohms.
  #13 (permalink)
Old 03-05-2013, 05:39 PM
Junior Member
RKF22 is on a distinguished road
Default
I'd check the lid switch. unplug it an then jump the two colored wires with a jumper wire. Not the green wire. That's the ground.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 80 - Doesn't spin when draining BenjaminA Washer Repair 1 01-04-2012 01:45 PM
Kenmore 110 Dishwasher-Not Draining Rick Nyman Dishwasher Repair 0 10-12-2010 09:58 AM
Kenmore not draining completely csohio Washer Repair 1 12-23-2008 01:36 PM
Kenmore not draining or spinning Alicornat Washer Repair 2 07-20-2008 08:45 AM
Kenmore Dishwasher not draining hspotts Dishwasher Repair 0 01-19-2008 02:19 PM
