Discuss
still no s[pin
 in
Washer Repair
Installed my new wax motor and new control board (yes old one had r-11 burned) but machine still does everything
Appliance Repair Forum > Appliance Repair Help > Washer Repair » still no s[pin
  #1 (permalink)
Old 02-15-2013, 10:50 AM
Junior Member
blackshoe is on a distinguished road
Default still no s[pin
Model Number: MAH4000AWW   Brand: Maytag   Age: 5 - 10 years
Installed my new wax motor and new control board (yes old one had r-11 burned) but machine still does everything but spin. door lock does indeed work now just no spin. belt looks fine.
Ads By Google
Related Models
Maytag MAH4000AWW Washer - Horizontal Axis
Maytag MAH4000BWQ Washer - Horizontal Axis
Maytag MAH4000BWW Washer - Horizontal Axis
Maytag MAH5500AWQ Washer - Horizontal Axis
Maytag MAH5500AWW Washer - Horizontal Axis
Maytag MAH5500BWQ Washer - Horizontal Axis
Maytag MAH5500BWW Washer - Horizontal Axis
Maytag MAH55FLBWQ Washer - Horizontal Axis
Maytag MAH55FLBWW Washer - Horizontal Axis
Maytag MAH6500AWQ Washer - Horizontal Axis
Maytag MAH6500AWW Washer - Horizontal Axis
Maytag MAH6700AWM Washer - Horizontal Axis
Maytag MAH6700AWW Washer - Horizontal Axis
Maytag MAH7500AWQ Washer - Horizontal Axis
Maytag MAH7500AWW Washer - Horizontal Axis
International MAH7550AAW Washer - Horizontal Axis
Maytag MAH7550AGW Washer - Horizontal Axis
International MAH7550AGW Washer - Horizontal Axis
Maytag MAH8700AWM Washer - Horizontal Axis
Maytag MAH8700AWW Washer - Horizontal Axis
Maytag MAH9700AWM Washer - Horizontal Axis
Maytag MAH9700AWQ Washer - Horizontal Axis
Maytag MAH9700AWW Washer - Horizontal Axis
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM Misc / Accessory
Maytag MAL1800AXQ Misc / Accessory
Maytag MAL1800AXW Misc / Accessory
Maytag MAL2000AXQ Misc / Accessory
Maytag MAL2000AXW Misc / Accessory
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL Washer - Top Loading
Maytag MAT10CSAAW Washer - Top Loading
Maytag MAT10CSAGL Washer - Top Loading
Maytag MAT10CSAGW Washer - Top Loading
Maytag MAT10CSBKL Washer - Top Loading
Maytag MAT10CSEGL Washer - Top Loading
Maytag MAT10CSEGW Washer - Top Loading
Maytag MAT10DAAAL Washer - Top Loading
Maytag MAT10DAAAW Washer - Top Loading
Maytag MAT10DAABL Washer - Top Loading
Maytag MAT10DAABW Washer - Top Loading
Maytag MAT10PDAAL Washer - Top Loading
Maytag MAT10PDAAW Washer - Top Loading
Maytag MAT10PDABL Washer - Top Loading
Maytag MAT10PDABW Washer - Top Loading
Maytag MAT10PDEGW Washer - Top Loading
Maytag MAT10PSAAL Washer - Top Loading
Maytag MAT10PSAAW Washer - Top Loading
Maytag MAT10PSAGL Washer - Top Loading
Maytag MAT10PSAGW Washer - Top Loading
Maytag MAT11CSBKL Washer - Top Loading
Maytag MAT11MNAAW Washer - Top Loading
Maytag MAT11MNAGW Washer - Top Loading
Maytag MAT11MNEGW Washer - Top Loading
Maytag MAT11PDAAL Washer - Top Loading
Maytag MAT11PDAAW Washer - Top Loading
Maytag MAT11PDABL Washer - Top Loading
Maytag MAT11PDABW Washer - Top Loading
Maytag MAT12CSAAL Washer - Top Loading
Maytag MAT12CSAAQ Washer - Top Loading
Maytag MAT12CSAAW Washer - Top Loading
Maytag MAT12CSAGW Washer - Top Loading
Maytag MAT12CSAKL Washer - Top Loading
Maytag MAT12CSAKQ Washer - Top Loading
Maytag MAT12CSDAQ Washer - Top Loading
Maytag MAT12CSDAW Washer - Top Loading
Maytag MAT12CSDGW Washer - Top Loading
Maytag MAT12CSEGW Washer - Top Loading
Maytag MAT12CSFWQ Washer - Top Loading
Maytag MAT12CSFWW Washer - Top Loading
Maytag MAT12PDAAL Washer - Top Loading
Maytag MAT12PDAAW Washer - Top Loading
Maytag MAT12PDABL Washer - Top Loading
Maytag MAT12PDABW Washer - Top Loading
Maytag MAT12PDAGW Washer - Top Loading
Maytag MAT12PDBAL Washer - Top Loading
Maytag MAT12PDBAQ Washer - Top Loading
Maytag MAT12PDBAW Washer - Top Loading
Maytag MAT12PDBBL Washer - Top Loading
Maytag MAT12PDBBQ Washer - Top Loading
Maytag MAT12PDBBW Washer - Top Loading
Maytag MAT12PDCBL Washer - Top Loading
Maytag MAT12PDCBQ Washer - Top Loading
Maytag MAT12PDCBW Washer - Top Loading
Maytag MAT12PDDAQ Washer - Top Loading
Maytag MAT12PDDAW Washer - Top Loading
Maytag MAT12PDDBW Washer - Top Loading
Maytag MAT12PDDGW Washer - Top Loading
Maytag MAT12PDEGW Washer - Top Loading
Maytag MAT12PDLAQ Washer - Top Loading
Maytag MAT12PDLAW Washer - Top Loading
Maytag MAT12PDLGW Washer - Top Loading
Maytag MAT12PDSAW Washer - Top Loading
Maytag MAT12PRAAW Washer - Top Loading
Maytag MAT12PRAEW Washer - Top Loading
Maytag MAT12PRBAW Washer - Top Loading
Maytag MAT12PRDAW Washer - Top Loading
Maytag MAT12PRSAW Washer - Top Loading
Maytag MAT12PSAAW Washer - Top Loading
Maytag MAT12PSAGW Washer - Top Loading
Maytag MAT12PSBAW Washer - Top Loading
Maytag MAT12PSDAW Washer - Top Loading
Maytag MAT12PSLWQ Washer - Top Loading
Maytag MAT12PSLWW Washer - Top Loading
Maytag MAT13MNAAW Washer - Top Loading
Maytag MAT13MNAGW Washer - Top Loading
Maytag MAT13MNDAW Washer - Top Loading
Maytag MAT13MNDGW Washer - Top Loading
Maytag MAT13MNEGW Washer - Top Loading
Maytag MAT13PDAAW Washer - Top Loading
Maytag MAT13PDBAW Washer - Top Loading
Maytag MAT13PNAEW Washer - Top Loading
Maytag MAT13PNDEW Washer - Top Loading
Maytag MAT13PRBWW Washer - Top Loading
Maytag MAT230CAAG Washer - Top Loading
Maytag MAT23PCAAC Washer - Top Loading
Maytag MAT23PCAAG Washer - Top Loading
Maytag MAT23PCAAL Washer - Top Loading
Maytag MAT23PCAAW Washer - Top Loading
Maytag MAT23PCABG Washer - Top Loading
  #2 (permalink)
Old 02-15-2013, 02:26 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Blackshoe, You'll need to check the spin enable switch
Part number: AP4028524
(the micro switch farthest to the right on the door latch assembly, with the red and yellow wires) it has to have a "closed" circuit when the door lock is energized and has extended to the left.
You'll also need to check the off balance switches and wiring harness for "closed" circuits as well.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 02-15-2013, 11:40 PM
Junior Member
Thank you Joe for helping. Would a bad spin enable switch have caused that R-11 resistor on my old board to burn up?
  #4 (permalink)
Old 02-16-2013, 11:18 AM
Junior Member
Default
Spin enable switch I guess I will just replace, don't really know how to check the off balance switches.
  #5 (permalink)
Old 02-18-2013, 06:40 AM
Senior Expert
Default
Blackshoe, No, The R11 resistor is strictly related to the door lock wax motor, the spin enable switch wouldn't have been affected, or affected the wax motor circuits.
The easiest and best way to test circuits, on a Neptune washer, is at the control board. All components have a path out of the control board, go to/through the switch or component and back to the control board. You'll need to use the wiring diagram, and trace the pins on the connector, unplug the connector from the board, and test for resistance, or voltages.
In your case at the control board, disconnect the P2 Connector and the P3 connector.With your meter you should read a "closed" circuit between P2pin4 Orange wire, to P3pin7 yellow wire when the door is locked. This will tell you that the wires and spin enable switch are working proper. The Off balnace switches can be teste the same way. Connector P3pin1 red wire to P2pin4 orange, should have a "closed" circuit. This will varify that the wiring and all three Off Balance switches are operable. You can also conduct a low 24 DC voltage check on the circuit as well, using The black wire on the relay board of the conmtrol and checking each wire for 24VDC out of th board and back to the board, on the same wires.
__________________
Joe M. APP TEAM
  #6 (permalink)
Old 02-21-2013, 08:55 AM
Junior Member
Default working again
The spring that pushes wax motor into place just wasn't pushing it far enough to engage new spring did the trick.
  #7 (permalink)
Old 02-21-2013, 11:16 AM
Senior Expert
Default
Great, We're glad it wasn't anything that would need replacement, just an adjustment.
Thanks for the update.
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
