Discuss
motor smoking during rinse cycle
 in
Washer Repair
I am trying to troubleshoot an issue with my Maytag washing machine. First, when on the rinse cycle I noticed
Appliance Repair Forum > Appliance Repair Help > Washer Repair » motor smoking during rinse cycle
  #1 (permalink)
Old 02-14-2013, 08:26 PM
Junior Member
kwokojance is on a distinguished road
Default motor smoking during rinse cycle
Model Number: A608   Brand: Maytag   Age: More than 10 years
I am trying to troubleshoot an issue with my Maytag washing machine. First, when on the rinse cycle I noticed a loud squealing belt sound. I was on my way out, and let it run. Two days later the machine would not spin when on the rinse cycle. It would only hum and smell burnt. I turned it over and found the drive belt had broken. I had hoped that the burnt smell was only the belt. I replaced it with a cheap auto parts belt of the same length. I tested the motor with the belts off in the spin cycle and it spins freely and without problem (no smoking). I tested it with the washer pump belt attached (which I also replaced as it was quite loose), and again, no problem. Then I tested it with the drive belt on in the rinse cycle again, and it starts, but appears to do so with some hesitation. It picks up speed to about 1/5 normal speed and then stops after 3 seconds. It may be that the thermal protector trips. (However, it is not even warm to the touch) If repeated it starts smoking. I'm afraid I fried the motor, but I would like to rule out possible power supply or other issues. I'm hoping that there is no problem with the transmission causing greater than normal torque requirement, but it does spin freely when turned by hand; the tub that is. Is it apparent I'm a novice at this?
Ads By Google
Related Models
Maytag A608 Washer - Top Loading
Maytag A608S Washer - Top Loading
Maytag A610 Washer - Top Loading
Maytag A612 Washer - Top Loading
Maytag A612S Washer - Top Loading
Maytag A612ST Washer - Top Loading
Maytag A612T Washer - Top Loading
Maytag A613 Washer - Top Loading
Maytag A613T Washer - Top Loading
Admiral A6257XRS Range - S/i Cont Clean Gas
Jenn-Air A626 Misc / Accessory
Jenn-Air A626B Misc / Accessory
Jenn-Air A626W Misc / Accessory
Jenn-Air A627B Misc / Accessory
Jenn-Air A627W Misc / Accessory
Admiral A6498VRV Range - S/c S/i Gas
Admiral A6498XRS Range - S/c S/i Gas
Admiral A64HN-4TKVW-R Range - S/c S/i Gas
Admiral A6892XRS Range - S/c S/i Ele
Admiral A6898VRV Range - S/c S/i Ele
Admiral A6898XRB Range - S/c S/i Ele
Admiral A68HK-6TXW-R Range - S/c S/i Ele
Maytag A6910 Washer - Top Loading
Frigidaire A6LECC2 Frg(v5) / Room Air Conditioner
Frigidaire A6LECC3 Frg(v1) / Room Air Conditioner
Frigidaire A6LECD2 Frg(v15) / Room Air Conditioner
Frigidaire A6LECDC2 Frg(v13) / Room Air Conditioner
Frigidaire A6LECDC3 Frg(v14) / Room Air Conditioner
Frigidaire A6LECDD2 Frg(v16) / Room Air Conditioner
Frigidaire A6LECUD2 Frg(v17) / Room Air Conditioner
Frigidaire A6LECUSD2 Frg(v18) / Room Air Conditioner
Maytag A700 Washer - Top Loading
Maytag A700S Washer - Top Loading
Maytag A702 Washer - Top Loading
Maytag A702S Washer - Top Loading
Maytag A710 Washer - Top Loading
Maytag A710S Washer - Top Loading
Maytag A712 Washer - Top Loading
Maytag A712T Washer - Top Loading
Maytag A7300 Washer - Top Loading
Maytag A7400 Washer - Top Loading
Maytag A7500 Washer - Top Loading
Maytag A7500S Washer - Top Loading
Maytag A7500W Washer - Top Loading
Maytag A7800 Washer - Top Loading
Admiral A79E-5CXW Walloven - S/c Ele
Admiral A79F-5EXW-R Walloven - S/c Ele
Admiral A79FN-5EVW-R Walloven - S/c Ele
Frigidaire A7LECUD2 Frg(v19) / Room Air Conditioner
Maytag A806 Washer - Top Loading
Maytag A806S Washer - Top Loading
Maytag A810 Washer - Top Loading
Maytag A8100 Washer - Top Loading
Maytag A8120 Washer - Top Loading
Maytag A8140 Washer - Top Loading
Maytag A8200 Washer - Top Loading
Maytag A8210 Washer - Top Loading
Admiral A8210PA Surface Unit - Gas
Admiral A8210PA-L Surface Unit - Gas
Admiral A8210PT-L Surface Unit - Gas
Admiral A8210PW Surface Unit - Gas
Admiral A8210PW-L Surface Unit - Gas
Admiral A8211PA Surface Unit - Gas
Admiral A8211PS Surface Unit - Gas
Admiral A8211PW Surface Unit - Gas
Maytag A8240 Washer - Top Loading
Admiral A8241RA Surface Unit - Gas
Admiral A8241RA-L Surface Unit - Gas
Admiral A8241RS Surface Unit - Gas
Admiral A8241RT-L Surface Unit - Gas
Admiral A8241RV Surface Unit - Gas
Admiral A8241RW Surface Unit - Gas
Admiral A8241RW-L Surface Unit - Gas
Admiral A8261RB Surface Unit - Gas
Admiral A8261RV Surface Unit - Gas
Admiral A82LK-3K-R Surface Unit - Gas
Admiral A82LN-3K-R Surface Unit - Gas
Admiral A82LW-2K-R Surface Unit - Gas
Admiral A82R1RV Surface Unit - Gas
Admiral A8321PA Surface Unit - Gas
Admiral A8321PS Surface Unit - Gas
Admiral A8321PW Surface Unit - Gas
Admiral A8321TA-L Surface Unit - Gas
Admiral A8321TW-L Surface Unit - Gas
Maytag A8340 Washer - Top Loading
Maytag A8420 Washer - Top Loading
Maytag A8440 Washer - Top Loading
Maytag A8500 Washer - Top Loading
Maytag A8520 Washer - Top Loading
Maytag A8600 Washer - Top Loading
Admiral A8610PA Surface Unit - Ele
Admiral A8610PS Surface Unit - Ele
Admiral A8610PV Surface Unit - Ele
Maytag A8640 Washer - Top Loading
Maytag A8650 Washer - Top Loading
Admiral A8670PB Surface Unit - Ele
Admiral A8670PV Surface Unit - Ele
Admiral A86LW-1-R Surface Unit - Ele
Maytag A8700 Washer - Top Loading
Admiral A8720PA Surface Unit - Ele
Admiral A8720PW Surface Unit - Ele
Maytag A8740 Washer - Top Loading
Maytag A8800 Washer - Top Loading
Maytag A882 Washer - Top Loading
Maytag A8820 Washer - Top Loading
Maytag A882T Washer - Top Loading
Maytag A883 Washer - Top Loading
Maytag A883T Washer - Top Loading
Maytag A884 Washer - Top Loading
Maytag A8840 Washer - Top Loading
Maytag A884T Washer - Top Loading
Admiral A88FK-1 Surface Unit - Ele
Admiral A88FK-2-R Surface Unit - Ele
Admiral A88FK-6-R Surface Unit - Ele
Admiral A88FN-2-R Surface Unit - Ele
Admiral A88FN-2R Surface Unit - Ele
Admiral A88LK-6-R Surface Unit - Ele
Admiral A88LN-6-R Surface Unit - Ele
Admiral A89L-4-R Surface Unit - Ele
Frigidaire A8LECUD2 Frg(v20) / Room Air Conditioner
  #2 (permalink)
Old 02-15-2013, 04:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
The first thing I would do is replace both belts with OEM parts. Then adjust the pump belt tension as described in the attached file and give it a try.
- The belts kit Part number: 12112425
Here are the breakdown diagrams and Parts for Maytag A608 - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-23-2013, 06:45 PM
Junior Member
Default
Bingo! I replaced both belts with OEM parts and it did the trick. It goes through the rinse cycle just fine and with no smoking motor. Thanks a lot!
  #4 (permalink)
Old 02-26-2013, 08:58 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You are welcome. I'm glad it's up and running.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Smoking belts on spin cycle Kevco Washer Repair 2 10-11-2010 06:53 AM
Motor smoking Bernardo Rangel Washer Repair 0 11-24-2009 04:23 PM
Trying to install dryer motor, but it started smoking mel113 Dryer Repair 1 11-21-2009 09:20 AM
dishwasher only hums on rinse cycle, does'nt rinse chris67 Dishwasher Repair 1 10-25-2009 05:01 AM
Washer goes to rinse cycle then spin back to rinse, stuck in this mod Pat66 Washer Repair 1 05-08-2009 07:44 AM
