| » Hub lock nut seized |
You could try penetrating oil.
Keep it wet and give it a couple hiurs to work it's way into the treads. Do you have the correct hub nut tool. It should let you put more force on the nut. If all else fails you could try splitting the nut. Some folks just use a cold chisel on it. I do not like this as it usually takes a lot of banging to split it. I prefer to cut it using a rotary tool/dremel. Juts be careful that you cut just the nut. Then a couple taps with a chisel and hammer should split it.
__________________
| Display Modes | |
| Seized evaporator fan | pelagikos | Refrigerator & Freezer Repair | 1 | 05-26-2010 08:50 AM |
| Seized washer | dgpwk | Washer Repair | 7 | 02-23-2010 01:37 PM |
| Thermador venturis seized up | repair it rick | Oven Repair (including Ranges and Cooktops) | 0 | 02-08-2010 05:58 AM |
| Seized | mcomer | Washer Repair | 8 | 11-18-2009 06:08 PM |
| Agitator seems to be seized to drum. | kennewickman | Washer Repair | 18 | 06-01-2009 10:48 AM |
