Discuss
Kenmore 90 Series no spin
 in
Washer Repair
I have a Kenmore 90 Series washer dryer set and the washer has gone caput.. A year ago i changed
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 90 Series no spin
  #1 (permalink)
Old 10-01-2009, 08:13 PM
Junior Member
mfalkevitz is on a distinguished road
Default Kenmore 90 Series no spin
Brand: Kenmore   Age: 5 - 10 years
A year ago i changed the coupling on the motor and now after a year of no problems the washer will not drain. since it will not drain it won't spin. i have drained it manually and have replaced the timer mechanism as all signs pointed to it as the culprit.
however it still will agitate, and then stops before the drain cycle. the pump is free of debris and rotates, the motor is fine when agitating and it appears that no power is going to the motor as thier is no cycle hum when it is supposed to be draining.
any help would be appreciated.
  #2 (permalink)
Old 10-02-2009, 03:35 AM
Senior Expert
APP Volunteer
richappy is a splendid one to behold
Default
Check your lid switch. Need model # to help further.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
70 series kenmore wont spin nikko Washer Repair 3 09-11-2009 09:52 AM
Kenmore 80 series won't spin Mike Ganoe Washer Repair 1 05-17-2009 11:28 AM
kenmore 80 series spin problem jk85692 Washer Repair 1 01-25-2009 06:41 PM
kenmore series 80 will not spin tlgeirna Washer Repair 1 06-04-2008 02:51 AM
Kenmore 80 series won't spin kenmorecrazy Washer Repair 0 03-15-2008 05:59 PM
