Discuss
door lock on washer
 in
Washer Repair
I had the repairman to clean the filter on the maytag maxima washer. He had to take the washer apart
Appliance Repair Forum > Appliance Repair Help > Washer Repair » door lock on washer
  #1 (permalink)
Old 02-11-2013, 05:51 AM
Junior Member
Ann126 is on a distinguished road
Angry door lock on washer
Brand: Maytag   Age: 1 - 5 years
I had the repairman to clean the filter on the maytag maxima washer. He had to take the washer apart to get to it. When he put it back together he couldn't get the door lock to work. Now he says I need a $245. new door lock mechanism. He took the top off and got it to open but washer won't work. Any ideas?
  #2 (permalink)
Old 02-12-2013, 06:04 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Yes, tell the company that sent out the repair person that they need to fix this at no charge.
If they resist contact the BBB and/or consumer protection agencies in your area and state. If the door lock mechanism was ok before the repair person arrived then they need to fix it at their expense, and you need to insist on your consumer rights.
__________________
  #3 (permalink)
Old 02-12-2013, 09:38 PM
Junior Member
Default door lock on washer
Thanks for your response. He is independent. I should have called the Maytag service.
  #4 (permalink)
Junior Member
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer door will not lock Rosa Mattei Washer Repair 1 05-13-2011 04:48 AM
Washer door won't lock shawahs Washer Repair 1 10-24-2009 06:58 PM
frigidaire washer door will not lock cfornash Washer Repair 1 02-26-2009 09:21 AM
Washer door will not lock boatman Washer Repair 1 02-13-2009 02:29 PM
Washer door lock only jefflisa2 Washer Repair 0 08-26-2007 08:31 PM
