| » Washer fills, agitates, drains, spins, won't fill to go on to rinse cycle. |
Model Number: 119.2982 Brand: Kenmore Age: 1 - 5 years
Kenmore washer will fill, agitate, drain, then spin through the first cycle. Then it stops and will not go on to fill again to rinse. If it is turned off and back on it will usually jump straight into the spin cycle, but does not fill first. It is the same for all wash settings. Fill, agitate, drain, spin, then does not move on. Any suggestions?
Since it will go through the wash and first spin cycle ok, that suggests the mechanics of the machine are ok, and that you should try changing out the timer to see if that fixes things.
__________________
| Display Modes | |
| Washer Fills, Drains, Agitates but WON'T SPIN | livebird | Washer Repair | 0 | 10-12-2010 05:12 PM |
| Fills? Yes. Agitates? No. Rinses, spins, drains? Yes. | chicagokb1 | Washer Repair | 1 | 10-11-2010 10:16 AM |
| Machine fills and agitates, but won't enter into rinse cycle | javajunkie | Washer Repair | 1 | 08-19-2010 02:29 PM |
| washer fills on rinse cycle but drains simultaneously | ranjangretchen@gmail.com | Washer Repair | 3 | 11-20-2009 03:13 PM |
| washer fills & drains at same time when gets to rinse cycle | wheelsx5 | Washer Repair | 1 | 04-07-2009 12:59 PM |
