| » Admiral Top Load Washer - loud banging during spin cycle |
Model Number: ATW4475VQO Brand: Admiral Age: 5 - 10 years
I have an Admiral Top Load Washer (ATW4475VQO) that works great except when it spins during the rinse cycle high speed, it makes a loud banging noise against the front of the washer. I've already replaced the ring balancer and all (3) suspension springs, but this did not fix the problem. I've also checked to make sure the washer is level with the floor.
When I remove the washer cover, I do see that the washer tub leans forward a bit and even if I try to push it back, it tends to favor the front end. Not sure how to fix this and would appreciate any help on this issue. Thanks in advance! Ads By Google Related Models |
It does sound like something is wrong with the suspension, but first try changing out the pads and make sure the tub structure is placed properly on the support frame.
There could be a thin crack in the support structure which you cannot see.
__________________
Can I get the part number for the pads and/or the link to the actual products on the app website? Thanks! |
Here is the link to the exploded view of the base. You will see the pads and where they go.
05-Machine Base Parts parts for Maytag ATW4475VQ0 - AppliancePartsPros.com Good luck, hope this helps.
__________________
| Display Modes | |
| Whirlpool top load loud whining/banging noises on spin cycle | DavidD05 | Washer Repair | 3 | 08-18-2011 03:24 PM |
| Loud Banging at END of EVERY Spin Cycle | TheGD | Washer Repair | 3 | 11-04-2010 07:06 AM |
| Whirlpool Duet HT Washer - loud banging during spin cycle | Tamala | Washer Repair | 0 | 08-13-2010 05:59 PM |
| Kenmore front load washer banging on spin cycle | gkarr | Washer Repair | 2 | 08-07-2010 08:30 AM |
| loud banging on spin cycle | twowanda | Washer Repair | 3 | 11-21-2008 02:25 AM |
