Discuss
Tub contacts top panel
 in
Washer Repair
Has anybody else had experience with a tub so high that it contacts the top panel of the washer? The
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Tub contacts top panel
  #1 (permalink)
Old 02-08-2013, 11:27 PM
Junior Member
hotspur is on a distinguished road
Default Tub contacts top panel
Model Number: A106   Brand: Maytag   Age: More than 10 years
The tub in my washer is now touching the underside of the top panel of the washer; causing the washer to trip off during spin cycle. It looks like if I shim the front of the top panel upward by about a quarter of an inch, the tub will clear the underside of the top panel during spin cycles.
I know that the excessive height of the tub is at least partly a direct result of my replacing the damper pads this week. At the time of the repair, I did not think I was using too much adhesive (RTV) in attaching the replacement damper pads. I used high temp RTV silicone adhesive, on the recommendation of the actual repair man at my local appliance repair parts store (instead of the expensive Maytag branded adhesive). I did let the RTV cure for 36-hr before I re-assembled the washer.
Even so, please note that:
The rubber seal that should be between the top panel of the washer and the tub has been absent the entire time I've owned and used the washer - that is for at least the last six years. I can see fastener locations where apparently a rubber seal used to be attached there long ago. (The absence of a seal has never caused any problem.) Even with no rubber seal present, before I replaced the damper pads the tub was already almost in contact with the top panel - with no room whatsoever for a rubber seal between the top panel and the tub.
Ads By Google
Related Models
Maytag A106 WASHER-TOP LOADING
Jenn-Air A106B ELE CARTRIDGE
Maytag A106S WASHER-TOP LOADING
Jenn-Air A106W ELE CARTRIDGE
Maytag A107 WASHER-TOP LOADING
Maytag A107S WASHER-TOP LOADING
Maytag A108 WASHER-TOP LOADING
Hoover A1089
Maytag A108S WASHER-TOP LOADING
Maytag A110 WASHER-TOP LOADING
Jenn-Air A110-8 MISC / ACCESSORY
Admiral A1100PRA RANGE- F/S STD GAS
Admiral A1100PRA-K RANGE- F/S STD GAS
Admiral A1100PRW RANGE- F/S STD GAS
Admiral A1100PRW-K RANGE- F/S STD GAS
Jenn-Air A111 MISC / ACCESSORY
Jenn-Air A111-8 MISC / ACCESSORY
Maytag A112 WASHER-TOP LOADING
Frigidaire A11ME5E1 Frg(v1) / Room Air Conditioner
Frigidaire A11ME5F1 Frg(v1) / Room Air Conditioner
Frigidaire A11ME5L2 Frg(v1) / Room Air Conditioner
Frigidaire A11ME8E1 Frg(v1) / Room Air Conditioner
Frigidaire A11ME8E2 Frg(v2) / Room Air Conditioner
Frigidaire A11ME8E3 Frg(v1) / Room Air Conditioner
Frigidaire A11MEDC2 Frg(v1) / Room Air Conditioner
Frigidaire A11MEDSD3 Frg(v1) / Room Air Conditioner
Frigidaire A11MEDTC2 Frg(v2) / Room Air Conditioner
Frigidaire A11MEUC2 Frg(v3) / Room Air Conditioner
Frigidaire A11MEUSD2 Frg(v2) / Room Air Conditioner
Frigidaire A11MEUTSD2 Frg(v3) / Room Air Conditioner
Jenn-Air A120 MISC / ACCESSORY
Jenn-Air A120-8 MISC / ACCESSORY
Amana A1200S COMMERCIAL MICROWAVES
Jenn-Air A121B ELE CARTRIDGE
Jenn-Air A121B-8 ELE CARTRIDGE
Jenn-Air A121W ELE CARTRIDGE
Jenn-Air A121W-8 ELE CARTRIDGE
Amana A1225S COMMERCIAL MICROWAVES
Jenn-Air A122B ELE CARTRIDGE
Maytag A122B14 RADIANT ELEMENT CARTRIDGE
Jenn-Air A122W ELE CARTRIDGE
Maytag A122W13 RADIANT ELEMENT CARTRIDGE
Frigidaire A1238EC2 Frg(v4) / Room Air Conditioner
Jenn-Air A125B ELE CARTRIDGE
Jenn-Air A126B ELE CARTRIDGE
Jenn-Air A126W ELE CARTRIDGE
Jenn-Air A130F INDUCTION CARTRIDGE
Jenn-Air A130R INDUCTION CARTRIDGE
Jenn-Air A135F INDUCTION CARTRIDGE
Jenn-Air A135R INDUCTION CARTRIDGE
Frigidaire A13MUC2 Frg(v5) / Room Air Conditioner
Frigidaire A13MUD2 Frg(v4) / Room Air Conditioner
Jenn-Air A140 MISC / ACCESSORY
Hoover A1408 WASHER-TOP LOADING
Hoover A1408010 WASHER-TOP LOADING
Jenn-Air A141-C MISC / ACCESSORY
Hoover A1410 WASHER-TOP LOADING
Hoover A1410010 WASHER-TOP LOADING
Hoover A1410B WASHER-TOP LOADING
Jenn-Air A145 MISC / ACCESSORY
Jenn-Air A150 MISC / ACCESSORY
Jenn-Air A150-8 MISC / ACCESSORY
Admiral A1500PRA RANGE- F/S STD ELE
Admiral A1500PRW RANGE- F/S STD ELE
Jenn-Air A151 MISC / ACCESSORY
Jenn-Air A151-8 MISC / ACCESSORY
Frigidaire A1538EC2 Frg(v6) / Room Air Conditioner
Frigidaire A1538UD2 Frg(v5) / Room Air Conditioner
Jenn-Air A158 MISC / ACCESSORY
Jenn-Air A158-8 MISC / ACCESSORY
Maytag A15CA MANUAL, PARTS (WASHER)
Maytag A15CM MANUAL, PARTS (WASHER)
Maytag A15CT MANUAL, PARTS (WASHER)
Maytag A16CA MANUAL, PARTS (WASHER)
Maytag A16CM MANUAL, PARTS (WASHER)
Maytag A16CT MANUAL, PARTS (WASHER)
Maytag A17CA MANUAL, PARTS (WASHER)
Maytag A17CM MANUAL, PARTS (WASHER)
Maytag A17CT MANUAL, PARTS (WASHER)
Maytag A180 WASHER-TOP LOADING
Maytag A181 WASHER-TOP LOADING
Maytag A182 WASHER-TOP LOADING
Maytag A183 WASHER-TOP LOADING
Frigidaire A1838C2 Frg(v7) / Room Air Conditioner
Frigidaire A1838D2 Frg(v6) / Room Air Conditioner
Frigidaire A1838EC2 Frg(v1) / Room Air Conditioner
Frigidaire A1838ED2 Frg(v7) / Room Air Conditioner
Frigidaire A1838UC2 Frg(v8) / Room Air Conditioner
Frigidaire A1838UD2 Frg(v8) / Room Air Conditioner
Maytag A18CA MANUAL, PARTS (WASHER)
Maytag A18CM MANUAL, PARTS (WASHER)
Maytag A18CT MANUAL, PARTS (WASHER)
Frigidaire A18NE2E1 Frg(v1) / Room Air Conditioner
Frigidaire A18NE2E2 Frg(v2) / Room Air Conditioner
Maytag A190 WASHER-TOP LOADING
Maytag A1910 WASHER-TOP LOADING
Maytag A200 WASHER-TOP LOADING
Maytag A200S WASHER-TOP LOADING
Maytag A202 WASHER-TOP LOADING
Maytag A202S WASHER-TOP LOADING
Maytag A203 WASHER-TOP LOADING
Maytag A203S WASHER-TOP LOADING
Maytag A206 WASHER-TOP LOADING
Maytag A206S WASHER-TOP LOADING
Maytag A207 WASHER-TOP LOADING
Maytag A207S WASHER-TOP LOADING
Maytag A208 WASHER-TOP LOADING
Maytag A208S WASHER-TOP LOADING
Maytag A209 WASHER-TOP LOADING
Maytag A209S WASHER-TOP LOADING
Maytag A210 WASHER-TOP LOADING
Maytag A210S WASHER-TOP LOADING
Maytag A211 WASHER-TOP LOADING
Maytag A211S WASHER-TOP LOADING
Maytag A212 WASHER-TOP LOADING
Maytag A212S WASHER-TOP LOADING
Maytag A21CA MANUAL, PARTS (WASHER)
Maytag A21CM MANUAL, PARTS (WASHER)
Maytag A21CT MANUAL, PARTS (WASHER)
Frigidaire A2238C2 Frg(v9) / Room Air Conditioner
  #2 (permalink)
Old 02-10-2013, 06:15 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
This is one of the most unusual problems I have come across. I would say the problem was probably created during the repair you did, but I cannot say what to do to fix it.
I know it is not an elegant solution, but if putting shins or spacers in to raise the top panel enough to stop the contact works, then do it. This is an older model and you have more than received your money's worth, so whatever works, go for it.
__________________
  #3 (permalink)
Old 02-11-2013, 04:38 PM
Junior Member
Default
Many thanks for your encouragement!
The washing machine is now running fine with about 1/4" of washers as shims/spacers between the side panels and the front edge of the top panel.
Unfortunately, as a result of raising up the top panel, the holes for the two screws for securing the front panel near the bases of the side panels don't line up now - and consequently the front panel is hanging (and hinging) from the spring clips at its top edge.
Also, it seems strange to me that there is room whatsoever for a rubber seal between the tub and the top panel (and there never has been since I acquired the washing machine, second hand).
Is it feasible that some other repair done before I acquired the washing machine resulted in a higher position of the tub, or even that the original tub was replaced with a slightly taller one, or something else like that?
Last edited by hotspur : 02-12-2013 at 12:16 PM. Reason: clarification of language used
  #4 (permalink)
Old 02-11-2013, 04:50 PM
Senior Expert
APP Volunteer
Default
I don't know if something was wrong before, but since you have it working I would do whatever you need to secure the front panel (or even run it without the front panel (what the heck!), just so long as it works you are ahead of the game.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
door switch contacts kpkells Dryer Repair 1 11-21-2010 10:48 PM
Power Contacts Burnned and Melted On My Dryer babridges0205 Dryer Repair 4 10-27-2009 05:52 PM
Oven light has bad contacts jjhome Oven Repair (including Ranges and Cooktops) 0 02-05-2009 02:06 PM
Tissue Paper Contacts in Receptacle scott123 Oven Repair (including Ranges and Cooktops) 0 10-17-2007 04:13 AM
