Discuss
GE Front Loading Washer Won't Drain or Spin
 in
Washer Repair
My GE front-loader washer advances through the cycles, but will not drain or spin at the end. During the spin
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Front Loading Washer Won't Drain or Spin
  #1 (permalink)
Old 02-08-2013, 09:23 PM
Junior Member
gblotter is on a distinguished road
Default GE Front Loading Washer Won't Drain or Spin
Model Number: WSXH208V1WW   Brand: GE   Age: More than 10 years
My GE front-loader washer advances through the cycles, but will not drain or spin at the end. During the spin cycle, I sometimes see it agitating as it does during the wash cycle.
I have read other threads here about similar problem with the Frigidaire version of this washer.
Recommended solution was check/replace door lock - see frigidare washer front loader fills with water no spin
Recommended solution was check/replace motor/speed control unit - see washer wont spin
Recommended solution was check/replace pump - see frigidaire front loader won't spin
Any help appreciated - thanks.
Ads By Google
Related Models
General Electric WSXH208V1WW Washer
Bosch WTA3500 UC/04
Bosch WTA3500 UC/08
Bosch WTA3500 UC/10
Bosch WTA3500 UC/13
Bosch WTA3510 UC/13 (FD 8111-)
Bosch WTA3510 UC/13 (FD 8201-)
Bosch WTL5400 UC/04
Bosch WTL5400 UC/08
Bosch WTL5400 UC/10
Bosch WTL5410 UC/10 (FD 8111-)
Bosch WTL5410 UC/10 (FD 8201-)
White Westinghouse WTR1240AQ0 Frtld Wshr - W.west - Grupo Famsa
White Westinghouse WTR1240AS0 Frtld Wshr - W.west - Grupo Famsa
White Westinghouse WTR430ES0 White Westinghouse/washer
White Westinghouse WTR430ES1 White Westinghouse/washer
White Westinghouse WTR430FS0 White Westinghouse/washer
General Electric WTRE6260F0GG Washer
General Electric WTRE6260F2GG Washer
General Electric WTSE4210A0WW Washer
Whirlpool WTW5100SQ0 Automatic Washer
Whirlpool WTW5200SQ0 Automatic Washer
Whirlpool WTW5300SQ0 Automatic Washer
Whirlpool WTW5310SQ0 Automatic Washer
Whirlpool WTW5320SQ0 Automatic Washer
Whirlpool WTW5321SQ0 Automatic Washer
Whirlpool WTW5400TQ0 Automatic Washer
Whirlpool WTW5500SQ0 Automatic Washer
Whirlpool WTW5500SQ2 Automatic Washer
Whirlpool WTW5500ST0 Automatic Washer
Whirlpool WTW5500ST2 Automatic Washer
Whirlpool WTW5505SQ0 Automatic Washer
Whirlpool WTW5505SQ1 Automatic Washer
Whirlpool WTW5520SQ0 Automatic Washer
Whirlpool WTW5521SQ0 Automatic Washer
Whirlpool WTW5540SQ0 Automatic Washer
Whirlpool WTW5540ST0 Automatic Washer
Whirlpool WTW5550SQ0 Automatic Washer
Whirlpool WTW5550ST0 Automatic Washer
Whirlpool WTW5560SQ0 Automatic Washer
Whirlpool WTW5590SQ0 Automatic Washer
Whirlpool WTW5590SQ2 Automatic Washer
Whirlpool WTW5590ST0 Automatic Washer
Whirlpool WTW5590ST2 Automatic Washer
Whirlpool WTW5600SQ0 Automatic Washer
Whirlpool WTW5700SW0 Automatic Washer
Whirlpool WTW5790SQ0 Automatic Washer
Whirlpool WTW5790ST0 Automatic Washer
Whirlpool WTW5800SG0 Automatic Washer
Whirlpool WTW5800SW0 Automatic Washer
Whirlpool WTW5810SW0 Automatic Washer
Whirlpool WTW5820SW0 Automatic Washer
Whirlpool WTW5821SW0 Automatic Washer
Whirlpool WTW5830SW0 Automatic Washer
Whirlpool WTW5840SG0 Automatic Washer
Whirlpool WTW5840SW0 Automatic Washer
Whirlpool WTW5850SG0 Automatic Washer
Whirlpool WTW5850SW0 Automatic Washer
Whirlpool WTW5860SG0 Automatic Washer
Whirlpool WTW5860SW0 Automatic Washer
Whirlpool WTW5900SB0 Automatic Washer
Whirlpool WTW5900SW0 Automatic Washer
Whirlpool WTW5900TB0 Automatic Washer
Whirlpool WTW5900TW0 Automatic Washer
Whirlpool WTW6200SW0 Automatic Washer
Whirlpool WTW6200SW1 Automatic Washer
Whirlpool WTW6200SW2 Automatic Washer
Whirlpool WTW6200SW3 Automatic Washer
Whirlpool WTW6300SB0 Automatic Washer
Whirlpool WTW6300SB1 Automatic Washer
Whirlpool WTW6300SB2 Automatic Washer
Whirlpool WTW6300SG0 Automatic Washer
Whirlpool WTW6300SG1 Automatic Washer
Whirlpool WTW6300SG2 Automatic Washer
Whirlpool WTW6300SW0 Automatic Washer
Whirlpool WTW6300SW1 Automatic Washer
Whirlpool WTW6300SW2 Automatic Washer
Whirlpool WTW6400SW0 Automatic Washer
Whirlpool WTW6400SW1 Automatic Washer
Whirlpool WTW6400SW2 Automatic Washer
Whirlpool WTW6400SW3 Automatic Washer
Whirlpool WTW6600SB0 Automatic Washer
Whirlpool WTW6600SB1 Automatic Washer
Whirlpool WTW6600SB2 Automatic Washer
Whirlpool WTW6600SB3 Automatic Washer
Whirlpool WTW6600SG0 Automatic Washer
Whirlpool WTW6600SG1 Automatic Washer
Whirlpool WTW6600SG2 Automatic Washer
Whirlpool WTW6600SG3 Automatic Washer
Whirlpool WTW6600SW0 Automatic Washer
Whirlpool WTW6600SW1 Automatic Washer
Whirlpool WTW6600SW2 Automatic Washer
Whirlpool WTW6600SW3 Automatic Washer
Whirlpool WTW6700TW0 Automatic Washer
Bosch WTZ1170
Bosch WTZ1210
Whirlpool WU0800B
Whirlpool WU0800XX0
Whirlpool WU0800XX1
Maytag WU100 Dishwasher - Undercounter
Maytag WU1000 Dishwasher - Undercounter
Whirlpool WU1000X0
Whirlpool WU1000X1
Whirlpool WU1000X4
Whirlpool WU1000X5
Whirlpool WU1000X6
Whirlpool WU1000X7
Whirlpool WU1000X8
Whirlpool WU1000Y0
Whirlpool WU1000Y1
Maytag WU1004 Dishwasher - Undercounter
Maytag WU1005 Dishwasher - Undercounter
Maytag WU101 Dishwasher - Undercounter
Maytag WU103 Dishwasher - Undercounter
Maytag WU104 Dishwasher - Undercounter
Maytag WU180 Dishwasher - Undercounter
Whirlpool WU1800XX0
Frigidaire WU180T1BLACK Wwh(v5) / 18 " Dishwasher
Frigidaire WU180TF1 Wwh(v3) / 18 " Dishwasher
Frigidaire WU180TH1 Wwh(v2) / 18 " Dishwasher
  #2 (permalink)
Old 02-08-2013, 10:24 PM
Junior Member
Default problem fixed - see solution
Problem fixed - see solution below.
Apparently the washer will not enter the spin cycle unless/until the water has drained from the drum.
I removed the lower panel to check the drain line and the pump. The drain line was clear, but the pump was clogged with a fabric softener dryer sheet (I could feel it when sticking my finger up inside the pump). After dislodging and removing the dryer sheet, everything seems to function normally now. Wahoo!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Front Loading Washer Won't Drain MariaD Washer Repair 5 10-01-2012 05:32 PM
front loading washer won't drain jesseservin Washer Repair 2 03-21-2011 08:19 PM
Front Loading washer wouldn't drain cweller1 Washer Repair 1 10-26-2010 05:18 AM
Kenmore front loading washer won't drain vince123 Washer Repair 5 05-14-2009 12:04 PM
GE Profile Front Loading Washer won't spin drhender Washer Repair 1 11-29-2008 02:06 PM
