| » No Hot Water in Washer |
Model Number: LSQ8243HQ0 Brand: Whirlpool Age: 5 - 10 years
Hot water does not dispense into the washer on any of the water temp settings.
If I switch the water lines, hot water will fill up via the cold water setting. I already checked the hoses, water supply, and power. Note: I replaced the Water Inlet Valve yesterday with a brand new unit and the problem remains. All other functions on the washer are okay. Any suggestions are appreciated. Thank you. Chris Ads By Google Related Models |
Bad water temp selector switch. Could also be a bad connection/wire between water temp switch and timer/water inlet valves. Inspect those first and check with meter if you have one.
Eric |
I appreciate the suggestion - I should have first checked the connection/wire between water temp switch and timer/water inlet valves.
It just may be the switch. I went for the cheaper part replacement first. Thanks again. |
| Display Modes | |
| Washer puts water in drum does not turn only hums and water does not drain | vsquared | Washer Repair | 1 | 07-04-2012 10:49 AM |
| washer is filling with hot water but no COLD water is coming through | rocky777 | Washer Repair | 1 | 06-18-2012 02:41 PM |
| Water leaking inside of washer- Water Inlet Valve? | bhb1991 | Washer Repair | 1 | 04-05-2012 06:03 PM |
| Washer only fills with hot water, no water during rinse cycle | rcmedrec1 | Washer Repair | 1 | 08-05-2011 06:28 PM |
| maytag washer/dyer combo washer no water | lindavanzandt | Washer Repair | 0 | 11-30-2008 08:35 AM |
