Discuss
wont agitate after filling
 in
Washer Repair
I have a whirlpool washer less than 10 years old. MY problem, the washer will fill to desired level, quits
Appliance Repair Forum > Appliance Repair Help > Washer Repair » wont agitate after filling
  #1 (permalink)
Old 02-07-2013, 05:36 PM
Junior Member
larry1059 is on a distinguished road
Default wont agitate after filling
Model Number: lsb6200kq1   Brand: Whirlpool   Age: 5 - 10 years
I have a whirlpool washer less than 10 years old. MY problem, the washer will fill to desired level, quits filling. Then nothing. No humming from the timer or the drive motor. Timer will not advance it just sits there. I checked all connections for tightness and corrosion. No leaks found. All appears to be good. Suggestions would be very much appreciated.
Ads By Google
Related Models
Whirlpool LSB6200KQ1 Automatic Washer
Whirlpool LSB6200PQ0 Automatic Washer
Whirlpool LSB6200PQ1 Automatic Washer
Whirlpool LSB6200PQ2 Automatic Washer
Whirlpool LSB6300LQ0
Whirlpool LSB6300LW0
Whirlpool LSB6300LW1 Automatic Washer
Whirlpool LSB6300LW2 Automatic Washer
Whirlpool LSB6300LW3 Automatic Washer
Whirlpool LSB6300PW0 Automatic Washer
Whirlpool LSB6300PW1 Automatic Washer
Whirlpool LSB6300PW3 Automatic Washer
Whirlpool LSB6300PW4 Automatic Washer
Whirlpool LSB6400KQ0
Whirlpool LSB6400KQ1
Whirlpool LSB6400LW0
Whirlpool LSB6400LW1 Automatic Washer
Whirlpool LSB6500PW0 Automatic Washer
Whirlpool LSB6500PW1 Automatic Washer
Whirlpool LSB6500PW2 Automatic Washer
Whirlpool LSB6500PW3 Automatic Washer
Whirlpool LSB6500PW4 Automatic Washer
Whirlpool LSC5000PQ0 Automatic Washer
Whirlpool LSC5000PQ1 Automatic Washer
Whirlpool LSC5000PQ2 Automatic Washer
Whirlpool LSC6244AN0
Whirlpool LSC6244AQ0
Whirlpool LSC6244AW0
Whirlpool LSC6244AZ0
Whirlpool LSC6244BN0
Whirlpool LSC6244BQ0
Whirlpool LSC6244BW0
Whirlpool LSC6244BZ0
Whirlpool LSC8244BG0
Whirlpool LSC8244BG1
Whirlpool LSC8244BN0
Whirlpool LSC8244BN1
Whirlpool LSC8244BQ0
Whirlpool LSC8244BQ1
Whirlpool LSC8244BW0
Whirlpool LSC8244BW1
Whirlpool LSC8244BZ0
Whirlpool LSC8244BZ1
Whirlpool LSC8244DQ0
Whirlpool LSC8244DZ0
Whirlpool LSC8244EQ0
Whirlpool LSC8244EQ1
Whirlpool LSC8244EZ0
Whirlpool LSC8244EZ1
Whirlpool LSC8245AN0
Whirlpool LSC8245AQ0
Whirlpool LSC8245AW0
Whirlpool LSC8245BN0
Whirlpool LSC8245BW0
Whirlpool LSC9000PW0 Automatic Washer
Whirlpool LSC9000PW1 Automatic Washer
Whirlpool LSC9000PW2 Automatic Washer
Whirlpool LSC9245BN0
Whirlpool LSC9245BN1
Whirlpool LSC9245BQ0
Whirlpool LSC9245BQ1
Whirlpool LSC9245BW0
Whirlpool LSC9245BW1
Whirlpool LSC9245BZ0
Whirlpool LSC9245BZ1
Whirlpool LSC9355AG0
Whirlpool LSC9355AN0
Whirlpool LSC9355AW0
Whirlpool LSC9355BN0
Whirlpool LSC9355BN1
Whirlpool LSC9355BQ0
Whirlpool LSC9355BQ1
Whirlpool LSC9355BW0
Whirlpool LSC9355BW1
Whirlpool LSC9355BZ0
Whirlpool LSC9355BZ1
Whirlpool LSC9355DQ0
Whirlpool LSC9355DZ0
Whirlpool LSC9355EQ0
Whirlpool LSC9355EQ1
Whirlpool LSC9355EZ0
Whirlpool LSC9355EZ1
Admiral LSD2615HEB Ref - SXS/I&W
Admiral LSD2615HEW Ref - SXS/I&W
Admiral LSD2615HEZ Ref - SXS/I&W
Maytag LSE1000 Stacked Laundry - Ele
Maytag LSE1000T Stacked Laundry - Ele
Jenn-Air LSE2700W Stacked Laundry - Ele
Jenn-Air LSE2700W-8 Stacked Laundry - Ele
Jenn-Air LSE2700W-C Stacked Laundry - Ele
Jenn-Air LSE2704W Stacked Laundry - Ele
Jenn-Air LSE2704W-8 Stacked Laundry - Ele
Maytag LSE7800 Stacked Laundry - Ele
Maytag LSE7800ACE Stacked Laundry - Ele
Maytag LSE7800ACL Stacked Laundry - Ele
Maytag LSE7800ACW Stacked Laundry - Ele
Maytag LSE7800ADE Stacked Laundry - Ele
Maytag LSE7800ADL Stacked Laundry - Ele
Maytag LSE7800ADW Stacked Laundry - Ele
Maytag LSE7800AEE Stacked Laundry - Ele
Maytag LSE7800AEL Stacked Laundry - Ele
Maytag LSE7800AEW Stacked Laundry - Ele
International LSE7800AGE Stacked Laundry - Ele
International LSE7800AGL Stacked Laundry - Ele
Maytag LSE7804ACE Stacked Laundry - Ele
Maytag LSE7804ACL Stacked Laundry - Ele
Maytag LSE7804ACM Stacked Laundry - Ele
Maytag LSE7804ADE Stacked Laundry - Ele
Maytag LSE7804ADL Stacked Laundry - Ele
Maytag LSE7804ADM Stacked Laundry - Ele
Maytag LSE7804AEE Stacked Laundry - Ele
International LSE7804AGE Stacked Laundry - Ele
International LSE7804AGL Stacked Laundry - Ele
International LSE7804AGM Stacked Laundry - Ele
Maytag LSE7806ACE Stacked Laundry - Ele
Maytag LSE7806ACM Stacked Laundry - Ele
Maytag LSE7806ACQ Stacked Laundry - Ele
Maytag LSE7806ADE Stacked Laundry - Ele
Maytag LSE7806ADM Stacked Laundry - Ele
Maytag LSE7806ADQ Stacked Laundry - Ele
  #2 (permalink)
Old 02-07-2013, 06:27 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Probably a bad lid switch. Advance the timer to see if it will drain or spin. If nothing, it's most likely the lid switch. If it does drain/spin, the lid switch is ok and it's most likely the water level pressure switch. If it's the lid switch, you can bypass it temporarily til you get a new one. See this video, your switch type is the second one in the video.
Eric
  #3 (permalink)
Old 02-07-2013, 07:03 PM
Junior Member
Default washer wont aggitate
Thanks for the additional input, I forgot to mention that advancing the timer does nothing. when I advance the timer the only activity I get is when I hit the points in the cycle that require water.( rinse cycles ).It will fill but wont drain. No aggitation, No spin, no humming, no nothing.
Thanks For your help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Agitates when filling, wont agitate at all??? DavidOstrower Washer Repair 2 08-31-2012 01:43 PM
washer wont spin, than wont stop filling lizzard Washer Repair 1 11-30-2011 06:07 PM
washer wont stop filling or begin to agitate sherryLynn313 Washer Repair 0 08-08-2011 08:28 PM
Washer wont stop filling/wont agitate khart26 Washer Repair 1 08-05-2008 11:58 AM
won't stop filling and won't agitate brokenshoe Washer Repair 4 03-12-2008 03:02 PM
