Discuss
Won't go into high speed
 in
Washer Repair
I am the unfortunate owner of the worst POS washing machine ever. Frigidaire front load .. I will NEVER own
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Won't go into high speed
  #1 (permalink)
Old 02-07-2013, 11:51 AM
Junior Member
kdiver58 is on a distinguished road
Default Won't go into high speed
Model Number: LFT2140ES   Brand: Frigidaire   Age: 5 - 10 years
I will NEVER own one again. But until I can get my wife to dump this nightmare I
will try and fix it.
I am on my 3rd door switch and now have a new problem. Like before it will not go into high speed spin. I replaced the door switch and it still won't go into high speed , medium speed or low speed spin.
I sat and watched this piece of garbage and it pumps out all of the water . Switches direction CW then CCW over and over and over and over.
Until the pump starts making a horrible racket. The pump is draining all of the visible water from the tub ..
Any ideas .. is the pump running dry and that's the cause of the noise?
Is there some switch I'm missing ..? Thanks .. K
Ads By Google
Related Models
Frigidaire LFW201EW0
Amana LG1009W Dryer - Gas
Amana LG1101 Dryer - Gas
Amana LG1112 Washer - Top Loading
Whirlpool LG2001XSW0
Amana LG2112L Dryer - Gas
Amana LG2112W Dryer - Gas
Amana LG2401 Dryer - Gas
Amana LG2412 Dryer - Gas
Amana LG2501 Dryer - Gas
Amana LG2512 Dryer - Gas
Amana LG2811 Dryer - Gas
Amana LG2812 Dryer - Gas
Amana LG2902 Washer - Top Loading
Amana LG2911 Dryer - Gas
Amana LG2912 Dryer - Gas
Whirlpool LG3001XKW0
Whirlpool LG3001XMW0
Whirlpool LG3001XMW1
Whirlpool LG3001XMW2
Whirlpool LG3001XPW0
Whirlpool LG3001XSW0
Whirlpool LG3006XPW0
Amana LG3412G Dryer - Gas
Amana LG3412L Dryer - Gas
Amana LG3412W Dryer - Gas
Amana LG3512L Dryer - Gas
Amana LG3512W Dryer - Gas
Amana LG3812L Dryer - Gas
Amana LG3812W Dryer - Gas
Amana LG3912L Dryer - Gas
Amana LG3912W Dryer - Gas
Frigidaire LG400AXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400AXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LG400MXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400MXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LG400SXD1 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXD2 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXD3 Wwh(v1) / Laundry Center
Frigidaire LG400SXW1 Wwh(v1) / 27 " Gas Laundry Center
Frigidaire LG400SXW2 Wwh(v2) / 27 " Gas Laundry Center
Frigidaire LG400SXW3 Wwh(v2) / Laundry Center
Amana LG4209L Dryer - Gas
Amana LG4209L2 Dryer - Gas
Amana LG4209W Dryer - Gas
Amana LG4209W2 Dryer - Gas
Amana LG4219L2 Dryer - Gas
Amana LG4219W2 Dryer - Gas
Amana LG4309L Dryer - Gas
Amana LG4309W Dryer - Gas
Amana LG4319L2 Dryer - Gas
Amana LG4319W2 Dryer - Gas
Amana LG4409L Dryer - Gas
Amana LG4409W Dryer - Gas
Amana LG4429L Dryer - Gas
Amana LG4429W Dryer - Gas
Whirlpool LG4441XWW0
Whirlpool LG4441XWW1
Amana LG4509L Dryer - Gas
Amana LG4509W Dryer - Gas
Amana LG4609L Dryer - Gas
Amana LG4609W Dryer - Gas
Amana LG4809L Dryer - Gas
Amana LG4809W Dryer - Gas
Amana LG4909L Dryer - Gas
Amana LG4909W Dryer - Gas
Whirlpool LG4931XMW0
Whirlpool LG4931XSW0
Whirlpool LG4931XTF0
Whirlpool LG4931XTG0
Whirlpool LG4931XTM0
Whirlpool LG4931XTN0
Whirlpool LG4931XTN1
Whirlpool LG4931XTW0
Whirlpool LG4931XTW1
Whirlpool LG4931XTW2
Whirlpool LG4936XMW0
Whirlpool LG4936XMW1
Whirlpool LG5201XTF0
Whirlpool LG5201XTG0
Whirlpool LG5201XTM0
Whirlpool LG5201XTN0
Whirlpool LG5201XTN1
Whirlpool LG5201XTW0
Whirlpool LG5201XTW1
Whirlpool LG5321XTF0
Whirlpool LG5321XTG0
Whirlpool LG5321XTM0
Whirlpool LG5321XTN0
Whirlpool LG5321XTW0
Whirlpool LG5531XKW0
Whirlpool LG5531XKW1
Whirlpool LG5531XMG2
Whirlpool LG5531XMN2
Whirlpool LG5531XMW0
Whirlpool LG5531XMW1
Whirlpool LG5531XMW2
Whirlpool LG5531XPW0
Whirlpool LG5531XSW0
Whirlpool LG5531XSW1
Whirlpool LG5536XPW0
Whirlpool LG5551XTG0
Whirlpool LG5551XTN0
Whirlpool LG5551XTW0
Whirlpool LG5601XKW0
Whirlpool LG5601XMW0
Whirlpool LG5601XPW0
Whirlpool LG5601XSW0
Whirlpool LG5601XSW1
Whirlpool LG5606XPW0
Whirlpool LG5651XKW0
Whirlpool LG5651XKW1
Whirlpool LG5651XMW0
  #2 (permalink)
Old 02-08-2013, 12:18 PM
Jerry / APP Team's Avatar
Expert
Jerry / APP Team is on a distinguished road
Default
Hello Kdiver,
If the drain pump is making a horrible racket, it is going to either have debris in it or the impeller has separated from the drain pump motor shaft. Even when the pump runs out of water to pump, it should not make this sort of noise. As far as the unit not going into spin, these are notorious for the speed controllers failing. The speed controller is the motor control board.
Since the model number didn't pull up as listed you need to verify the model number off of the units' I.D. tag. This way you make sure that the parts you order will be compatible with the machine.
  #3 (permalink)
Old 02-09-2013, 02:12 AM
Junior Member
Default Ltf2140es3
Sorry I took the model number off of the original receipt and it was mixed up
Model # LTF2140ES3
Serial # XC62206124
Purchased 08/2006
  #4 (permalink)
Old 02-09-2013, 05:15 AM
Expert
Default
Model # LTF2140ES3
Serial # XC62206124
Purchased 08/2006
Hello Kdiver,
You should first run the diagnostic test as laid out in the units' tech sheet. The diagnostic test is performed by using the Program Knob. To START THE TEST:
• On non-digital display models, turn the Program Knob to start position, Drain/Spin.
• On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that can be rotated 360°, turn the Program Knob to start position, Drain/Spin).
• Press Pause Cancel to turn off LEDs.
• Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons.
1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality.
2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment.
3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment.
4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment.
5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened.
7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble.
8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test).
9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating.
10. Turn the program knob (9) clicks from the start position. The control will signal the last error code.
Exiting Diagnostic Mode
There are two options for exiting the Diagnostic Test mode and returning the washer to normal operation:
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Pause Cancel buttons together for a few seconds until wash cycle LEDs appear.
If a situation arises where you cannot exit the Diagnostic mode as described above and the bank of 5 LED’s on the right end remain ON regardless of Program Knob position, a combination of pushed buttons may have caused the control to enter a special factory test mode. Disconnect power to reset the control to return washer to normal operation is this occurs.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
• Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation .
Once you have completed the diagnostic test, the unit should display a code that can be deciphered by use of the fault code list on the same tech sheet. If you cannot find your tech sheet or would like some illustrated service literature on this model specifically, you can list an e-mail address and we can sent it to you since it cannot be listed in this format. I still believe the drain pump either has something in it or the impeller has separated from the drain pump motor shaft. Part number: AP4359998
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
no high speed spin jaceo Washer Repair 0 06-07-2012 11:48 AM
GE 2 speed washer won't spin in high speed buzzybucks Washer Repair 1 12-16-2011 05:53 PM
No high speed spin Blake1111 Washer Repair 1 06-25-2010 11:49 AM
No high speed spin surferfletch Washer Repair 1 01-15-2010 05:27 PM
no high speed spin DEEDEEGOGO Washer Repair 2 10-16-2009 01:35 PM
