Discuss
front load washer communication error
 in
Washer Repair
I have a Frigidaire gallery series Front load washing machine that will not run. Error code indicates a a communication
Appliance Repair Forum > Appliance Repair Help > Washer Repair » front load washer communication error
  #1 (permalink)
Old 02-07-2013, 09:29 AM
Junior Member
cheetah72 is on a distinguished road
Default front load washer communication error
Brand: Frigidaire   Age: 5 - 10 years
I have a Frigidaire gallery series Front load washing machine that will not run. Error code indicates a a communication error. I recently replaced the door latch assembly because of an E41 error code. In checking the wire harness' I discovered the gray wire on the harness from the motor to the control board was pinched and stresed in a spot. I assume this could be the problem. Do I replace the entire harness or can I just fix the faulty wire?
Can I test to make sure it is working properly?
Any help would be greatly appreciated.
Ads By Google
  #2 (permalink)
Old 02-09-2013, 06:23 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I would splice in a new wire, check the two ends for continuity and see if that fixes things.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
E5E error code on sears front load washer garyham1@comcast.net Washer Repair 0 12-02-2012 11:12 AM
LG Front Load Washer Error Codes ApplianceJunk Washer Repair 0 12-17-2011 09:26 AM
GE Front Load Washer Gets Stuck in Cycle - Error Code E22 loganer Washer Repair 0 08-14-2011 05:44 PM
GE Front Load - E48 Error spavao Washer Repair 2 07-24-2011 06:29 PM
front load washer f3 error code bo_okie1 Washer Repair 3 07-15-2011 08:34 AM
