Discuss
Kenmore Series 80 won't drain
 in
Washer Repair
Our 28 year old washer just died, so since I am out of work and old, we only had a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Series 80 won't drain
  #1 (permalink)
Old 02-06-2013, 06:46 AM
Junior Member
govtdog is on a distinguished road
Default Kenmore Series 80 won't drain
Brand: Kenmore   Age: 5 - 10 years
Our 28 year old washer just died, so since I am out of work and old, we only had a little money to buy a washer. We ended up buying a used Kenmore Series 80 washer for $100 from a guy who said that he had to replace the dogs in the auger part of the agitator but now it works fine.
Well, it doesn't... because the washer does not empty/drain.
During the time it is supposed to be draining, the agitator is spinning and so is the drum but no water is draining out the drain hose.
If I lower the open part of the drain hose to lower than the water level in the tub, water pours out of the hose so I know that the line is not plugged.
My guess is that the water pump is shot or stuck? I have seen the video on replacing the pump and it looks simple enough and the pump is relatively inexpensive (<$40), but my concern is that I go and spend $40 that we can't afford and it turns out to be something other than the pump and we now have spent $140 on a washer instead of going to the laundromat to clean our huge pile of dirty laundry.
Based on what I described, can the problem be something other than the water pump?
Thanks for your help and advice!
John
  #2 (permalink)
Old 02-06-2013, 08:46 AM
Junior Member
Default Update
I've found that if I turn it off via the dial, and let it sit for a bit, that when I pull the dial back out again to turn it on it begins to drain but then stops draining while it continues to spin.
What would cause the pump to work briefly but then stop after 30 seconds or so?
Would lint/debris cause the pump impellor to work initially but then get clogged and stop working. Is there an internal lint screen of some sort which might be partially clogged and then gets reclogged when water is being pushed/sucked through it?
Thanks for the help!
  #3 (permalink)
Old 02-06-2013, 07:18 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
When the washer finished washing (agitating) it should pause and start to drain without spinning. If it does drain and spin at the same time right after it's done with wash then the problem most likely is a bad timer. If you need the correct part numbers, post the complete model number of the washer.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 90 Series won't drain LenK Washer Repair 8 10-25-2014 05:17 PM
Kenmore 70 Series Washer wont drain English638 Washer Repair 2 08-09-2012 08:36 AM
Kenmore 70 series won't drain or spin hokuao Washer Repair 1 02-07-2012 07:57 PM
kenmore 80 series washer won't drain! valeria Washer Repair 1 10-11-2011 07:38 AM
Kenmore 70 Series sometimes won't drain or spin PamMortensen Washer Repair 1 02-11-2010 07:47 PM
