| » Lubricant leak |
Model Number: 110.27632600 Brand: Kenmore Age: 5 - 10 years
Lady friend who bought washer new says it has leaked transmission oil since new. Washer works good other than leak. Thinking I'll put in used transmission. Question, can shaft seals be replaced without trans disassembly? Can lubricant be added without opening trans? Thanks.
The input shaft seal can be replaced without opening the gearcase and oil can be added here with the seal removed. The problem is, you don't know how much has leaked out and you don't want to overfill it. It normally holds 15oz of oil. If it's leaking at the output shafts or around the perimeter of the cover, you must remove the cover.
Eric |
| Display Modes | |
| Dryer Drum Support rollers and lubricant? | Methodical | Dryer Repair | 6 | 11-13-2011 02:53 PM |
| 1950 Tappan oven - lubricant | ZZV | Oven Repair (including Ranges and Cooktops) | 0 | 04-27-2010 09:25 AM |
| Maytag leaking lubricant | ddscz | Washer Repair | 1 | 05-30-2009 05:07 PM |
| Lubricant | james walley | Dryer Repair | 2 | 05-25-2009 06:19 PM |
| it have some lubricant? | dennisfloress@yahoo.com | Washer Repair | 1 | 03-26-2008 03:44 PM |
