Discuss
Whirlpool Imperial spin problem
 in
Washer Repair
Hello all, I apologise if there is already a post on this washer issue but I did a search for
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Imperial spin problem
  #1 (permalink)
Old 02-05-2013, 01:58 PM
Junior Member
washman512 is on a distinguished road
Question Whirlpool Imperial spin problem
Model Number: LSP9245BWO   Brand: Whirlpool   Age: 5 - 10 years
Hello all,
I apologise if there is already a post on this washer issue but I did a search for the model and no posts were returned. On to the problem, I have an Whirlpool Imperial washer which I purchased used. This washer has had no problems except when it goes to spin. It will go though all cycles no problem but when it spins the water will pump out but will not actually spin except when I lift the lid I hear a click and lower the lid it will start to spin. I am thinking it might be one of two things either the clutch is not working correctly or it could be the brake. I have even toyed with the notion it could be the transmission. Not really sure. The machine has worked well for the age but I would like to repair this unit but I don't really have the funds to pay for service. If there is anyone out there that has a solution to this problem I would greatly appreciate any input thanks in advance!
Ads By Google
Related Models
Whirlpool LSP9355AG0
Whirlpool LSP9355AN0
Whirlpool LSP9355AW0
Whirlpool LSP9355BN0
Whirlpool LSP9355BN1
Whirlpool LSP9355BW0
Whirlpool LSP9355BW1
Whirlpool LSQ7030KQ0
Whirlpool LSQ7030LQ0
Whirlpool LSQ7030LT0
Whirlpool LSQ7030MQ0 Automatic Washer
Whirlpool LSQ7533JQ0
Whirlpool LSQ7533JQ1
Whirlpool LSQ7533JT0
Whirlpool LSQ7533JT1
Whirlpool LSQ8000HQ0
Whirlpool LSQ8000JQ0
Whirlpool LSQ8000JQ1
Whirlpool LSQ8000LQ0
Whirlpool LSQ8000LQ1 Automatic Washer
Whirlpool LSQ8000LQ2 Automatic Washer
Whirlpool LSQ8000LQ3 Automatic Washer
Whirlpool LSQ8200HQ0
Whirlpool LSQ8200HZ0
Whirlpool LSQ8220HQ0
Whirlpool LSQ8243HQ0
Whirlpool LSQ8243HZ0
Whirlpool LSQ8500JQ0
Whirlpool LSQ8500JQ1
Whirlpool LSQ8500JQ2
Whirlpool LSQ8500JT0
Whirlpool LSQ8500JT1
Whirlpool LSQ8500JT2
Whirlpool LSQ8500LQ0 Automatic Washer
Whirlpool LSQ8510LQ0 Automatic Washer
Whirlpool LSQ8511KQ0
Whirlpool LSQ8511KT0
Whirlpool LSQ8512KQ0
Whirlpool LSQ8512KT0
Whirlpool LSQ8520JQ0
Whirlpool LSQ8520JQ1
Whirlpool LSQ8543JQ0
Whirlpool LSQ8543JQ1
Whirlpool LSQ8543JT0
Whirlpool LSQ8543JT1
Whirlpool LSQ8543JZ0
Whirlpool LSQ8543JZ1
Whirlpool LSQ9010KQ0
Whirlpool LSQ9010KT0
Whirlpool LSQ9010LG0
Whirlpool LSQ9010LG1 Automatic Washer
Whirlpool LSQ9010LG2 Automatic Washer
Whirlpool LSQ9010LG3 Automatic Washer
Whirlpool LSQ9010LQ0
Whirlpool LSQ9010LQ1 Automatic Washer
Whirlpool LSQ9010LQ2 Automatic Washer
Whirlpool LSQ9010LW0
Whirlpool LSQ9010LW1 Automatic Washer
Whirlpool LSQ9010LW2 Automatic Washer
Whirlpool LSQ9010LW3 Automatic Washer
Whirlpool LSQ9010PG0 Automatic Washer
Whirlpool LSQ9010PG1 Automatic Washer
Whirlpool LSQ9010PG2 Automatic Washer
Whirlpool LSQ9010PG3 Automatic Washer
Whirlpool LSQ9010PG5 Automatic Washer
Whirlpool LSQ9010PG6 Automatic Washer
Whirlpool LSQ9010PW0 Automatic Washer
Whirlpool LSQ9010PW1 Automatic Washer
Whirlpool LSQ9010PW2 Automatic Washer
Whirlpool LSQ9010PW3 Automatic Washer
Whirlpool LSQ9010PW5 Automatic Washer
Whirlpool LSQ9010PW6 Automatic Washer
Whirlpool LSQ9030PQ0 Automatic Washer
Whirlpool LSQ9030PQ1 Automatic Washer
Whirlpool LSQ9030PQ2 Automatic Washer
Whirlpool LSQ9030PQ4 Automatic Washer
Whirlpool LSQ9030PQ5 Automatic Washer
Whirlpool LSQ9110KQ0
Whirlpool LSQ9110KQ1
Whirlpool LSQ9110LG0
Whirlpool LSQ9110LG1 Automatic Washer
Whirlpool LSQ9110LW0
Whirlpool LSQ9110LW1 Automatic Washer
Whirlpool LSQ9110PW0 Automatic Washer
Whirlpool LSQ9110PW1 Automatic Washer
Whirlpool LSQ9110PW2 Automatic Washer
Whirlpool LSQ9110PW3 Automatic Washer
Whirlpool LSQ9110PW4 Automatic Washer
Whirlpool LSQ9200KQ0
Whirlpool LSQ9200KT0
Whirlpool LSQ9200LQ0
Whirlpool LSQ9200LQ1 Automatic Washer
Whirlpool LSQ9200LQ2 Automatic Washer
Whirlpool LSQ9200LQ3 Automatic Washer
Whirlpool LSQ9200LT0
Whirlpool LSQ9200LT1 Automatic Washer
Whirlpool LSQ9200LT2 Automatic Washer
Whirlpool LSQ9200LT3 Automatic Washer
Whirlpool LSQ9200PQ0 Automatic Washer
Whirlpool LSQ9200PQ1 Automatic Washer
Whirlpool LSQ9200PQ3 Automatic Washer
Whirlpool LSQ9200PQ4 Automatic Washer
Whirlpool LSQ9200PT0 Automatic Washer
Whirlpool LSQ9200PT1 Automatic Washer
Whirlpool LSQ9200PT3 Automatic Washer
Whirlpool LSQ9200PT4 Automatic Washer
Whirlpool LSQ9210HQ0
Whirlpool LSQ9210HZ0
Whirlpool LSQ9211KQ0
Whirlpool LSQ9211KQ1
Whirlpool LSQ9211KT0
Whirlpool LSQ9211KT1
Whirlpool LSQ9244EQ0
Whirlpool LSQ9244EZ0
Whirlpool LSQ9264HQ0
Whirlpool LSQ9264HZ0
Whirlpool LSQ9500LQ0
Whirlpool LSQ9500LT0
Whirlpool LSQ9510JQ0
Whirlpool LSQ9510JQ1
  #2 (permalink)
Old 02-05-2013, 06:59 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
It is supposed to drain initially without spinning. It should drain for a minute or two and then the motor should pause for a few seconds and then start up again and spin while continuing to drain. When you lift the lid, you are pausing the motor. If the motor doesn't pause after drain, that's a timer issue.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Imperial washer doesnt not agetate/spin or completely drain water roket77 Washer Repair 3 08-27-2012 01:26 PM
Whirlpool Imperial Loud Noise on Spin & Agitator Turns rock2 Washer Repair 2 12-24-2011 05:12 PM
whirlpool 7 cycles imperial series problem bucket won't turn nimster64 Dryer Repair 3 08-14-2011 06:38 PM
Whirlpool Imperial Washer cbolton61 Washer Repair 1 03-10-2009 03:19 PM
Whirlpool Imperial 70 Spin cycle cek347 Washer Repair 1 12-29-2008 02:04 PM
