Discuss
GE Front Loader Waher No Cold Water
 in
Washer Repair
My GE washer will not dispense any cold water. I verified that I have good water pressure at the unit,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Front Loader Waher No Cold Water
  #1 (permalink)
Old 02-04-2013, 06:56 AM
Junior Member
Brokenwashe is on a distinguished road
Default GE Front Loader Waher No Cold Water
Model Number: WSXH208F1WW   Brand: GE   Age: 5 - 10 years
My GE washer will not dispense any cold water. I verified that I have good water pressure at the unit, checked intake screens and tested the fill valve with an ohm meter, which tested out fine. I them put a multimeter on the leads going to the fill valve and moved the selector to hot and cold. I found 120V on the hot leads and only 12v on the cold leads. I have found conflicting information at this point. Some sources lead me to believe that the motor board could be the problem (which seems logical to me), and another source believes that it is the wash timer that is failing. Any insight is greatly appreciated.
Related Models
General Electric WSXH208F1WW Washer
General Electric WSXH208H0WW Washer
General Electric WSXH208H1WW WASHER
General Electric WSXH208H2WW WASHER
General Electric WSXH208H3WW WASHER
General Electric WSXH208T0WB Washer
General Electric WSXH208V0WW Washer
General Electric WSXH208V1WW Washer
Bosch WTA3500 UC/04
Bosch WTA3500 UC/08
Bosch WTA3500 UC/10
Bosch WTA3500 UC/13
Bosch WTA3510 UC/13 (FD 8111-)
Bosch WTA3510 UC/13 (FD 8201-)
White Westinghouse WTF330HS0 WASHER
White Westinghouse WTF330HS1 WASHER
White Westinghouse WTF330HS2 WASHER
Bosch WTL5400 UC/04
Bosch WTL5400 UC/08
Bosch WTL5400 UC/10
Bosch WTL5410 UC/10 (FD 8111-)
Bosch WTL5410 UC/10 (FD 8201-)
White Westinghouse WTR1240AQ0 Frtld Wshr - W.west - Grupo Famsa
White Westinghouse WTR1240AS0 Frtld Wshr - W.west - Grupo Famsa
White Westinghouse WTR430ES0 White Westinghouse/washer
White Westinghouse WTR430ES1 White Westinghouse/washer
White Westinghouse WTR430FS0 White Westinghouse/washer
General Electric WTRE6260F0GG Washer
General Electric WTRE6260F2GG Washer
General Electric WTSE4210A0WW Washer
Whirlpool WTW4750YQ0 AUTOMATIC WASHER
Whirlpool WTW4750YQ1 WASHER
Whirlpool WTW4800XQ0 AUTOMATIC WASHER
Whirlpool WTW4800XQ1 AUTOMATIC WASHER
Whirlpool WTW4800XQ2 AUTOMATIC WASHER
Whirlpool WTW4820XQ0 AUTOMATIC WASHER
Whirlpool WTW4850XQ0 WASHER
Whirlpool WTW4910XQ0 AUTOMATIC WASHER
Whirlpool WTW4910XQ1 AUTOMATIC WASHER
Whirlpool WTW4930XW0 AUTOMATIC WASHER
Whirlpool WTW4930XW1 WASHER
Whirlpool WTW4950XW0 AUTOMATIC WASHER
Whirlpool WTW4950XW1 AUTOMATIC WASHER
Whirlpool WTW4950XW2 WASHER
Whirlpool WTW5100SQ0 AUTOMATIC WASHER
Whirlpool WTW5100VQ0 AUTOMATIC WASHER
Whirlpool WTW5100VQ1 AUTOMATIC WASHER
Whirlpool WTW5100VQ2 AUTOMATIC WASHER
Whirlpool WTW5200SQ0 AUTOMATIC WASHER
Whirlpool WTW5200VQ0 AUTOMATIC WASHER
Whirlpool WTW5200VQ1 AUTOMATIC WASHER
Whirlpool WTW5200VQ2 AUTOMATIC WASHER
Whirlpool WTW5300SQ0 AUTOMATIC WASHER
Whirlpool WTW5300SQ2 AUTOMATIC WASHER
Whirlpool WTW5300SQ3 AUTOMATIC WASHER
Whirlpool WTW5300VW0 AUTOMATIC WASHER
Whirlpool WTW5300VW1 AUTOMATIC WASHER
Whirlpool WTW5300VW2 AUTOMATIC WASHER
Whirlpool WTW5300VW3 AUTOMATIC WASHER
Whirlpool WTW5310SQ0 AUTOMATIC WASHER
Whirlpool WTW5310VQ0 AUTOMATIC WASHER
Whirlpool WTW5320SQ0 AUTOMATIC WASHER
Whirlpool WTW5321SQ0 AUTOMATIC WASHER
Whirlpool WTW5400TQ0 AUTOMATIC WASHER
Whirlpool WTW5500SQ0 AUTOMATIC WASHER
Whirlpool WTW5500SQ2 AUTOMATIC WASHER
Whirlpool WTW5500ST0 AUTOMATIC WASHER
Whirlpool WTW5500ST2 AUTOMATIC WASHER
Whirlpool WTW5500XL0 AUTOMATIC WASHER
Whirlpool WTW5500XL1 AUTOMATIC WASHER
Whirlpool WTW5500XL2 WASHER
Whirlpool WTW5500XW0 AUTOMATIC WASHER
Whirlpool WTW5500XW1 AUTOMATIC WASHER
Whirlpool WTW5500XW2 WASHER
Whirlpool WTW5505SQ0 AUTOMATIC WASHER
Whirlpool WTW5505SQ1 AUTOMATIC WASHER
Whirlpool WTW5505VQ0 AUTOMATIC WASHER
Whirlpool WTW5505VQ1 AUTOMATIC WASHER
Whirlpool WTW5510VQ0 AUTOMATIC WASHER
Whirlpool WTW5520SQ0 AUTOMATIC WASHER
Whirlpool WTW5521SQ0 AUTOMATIC WASHER
Whirlpool WTW5530SQ0 AUTOMATIC WASHER
Whirlpool WTW5540SQ0 AUTOMATIC WASHER
Whirlpool WTW5540ST0 AUTOMATIC WASHER
Whirlpool WTW5550SQ0 AUTOMATIC WASHER
Whirlpool WTW5550ST0 AUTOMATIC WASHER
Whirlpool WTW5550XW0 AUTOMATIC WASHER
Whirlpool WTW5550XW1 AUTOMATIC WASHER
Whirlpool WTW5550XW2 WASHER
Whirlpool WTW5560SQ0 AUTOMATIC WASHER
Whirlpool WTW5590SQ0 AUTOMATIC WASHER
Whirlpool WTW5590SQ2 AUTOMATIC WASHER
Whirlpool WTW5590ST0 AUTOMATIC WASHER
Whirlpool WTW5590ST2 AUTOMATIC WASHER
Whirlpool WTW5590VQ0 AUTOMATIC WASHER
Whirlpool WTW5590VQ1 AUTOMATIC WASHER
Whirlpool WTW5600SQ0 AUTOMATIC WASHER
Whirlpool WTW5600VQ0 AUTOMATIC WASHER
Whirlpool WTW5600XW0 AUTOMATIC WASHER
Whirlpool WTW5600XW1 AUTOMATIC WASHER
Whirlpool WTW5600XW2 WASHER
Whirlpool WTW5610XW0 AUTOMATIC WASHER
Whirlpool WTW5610XW1 AUTOMATIC WASHER
Whirlpool WTW5610XW2 WASHER
Whirlpool WTW5640XW0 AUTOMATIC WASHER
Whirlpool WTW5640XW1 AUTOMATIC WASHER
Whirlpool WTW5640XW2 WASHER
Whirlpool WTW5700SW0 AUTOMATIC WASHER
Whirlpool WTW5700XL0 AUTOMATIC WASHER
Whirlpool WTW5700XL1 AUTOMATIC WASHER
Whirlpool WTW5700XL2 WASHER
Whirlpool WTW5700XW0 AUTOMATIC WASHER
Whirlpool WTW5700XW1 AUTOMATIC WASHER
Whirlpool WTW5700XW2 WASHER
Whirlpool WTW5790SQ0 AUTOMATIC WASHER
Whirlpool WTW5790SQ2 AUTOMATIC WASHER
Whirlpool WTW5790ST0 AUTOMATIC WASHER
Whirlpool WTW5790ST2 AUTOMATIC WASHER
Whirlpool WTW5790VQ0 AUTOMATIC WASHER
Whirlpool WTW5790VQ1 AUTOMATIC WASHER
  #2 (permalink)
Old 02-04-2013, 10:25 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Unplug the washer, remove the top, locate the temperature switch behind the control panel, with the switch set for C/C install the jumper wire between contacts 1-5 of the above mentioned switch. Plug the unit in and start.
If the cold water stars getting in - replace the temperature selector switch Part number: WH12X10057
If not - replace the timer Part number: WH12X10152
Here are the breakdown diagrams and Control Panel parts for GE WSXH208F1WW - AppliancePartsPros.com
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 02-05-2013, 05:53 AM
Junior Member
Default Jumer wire
I hooked the Jumper wire up and the cold water valve opened up.. I orederd the switch shown in the thread. Thanks so much for the help!
  #4 (permalink)
Old 02-05-2013, 09:57 AM
Expert
Default
You are welcome.
Post the results.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Front loader no water coming in tammyjen Washer Repair 2 10-02-2012 02:48 PM
front loader leaves water but will let it be respun out kay711 Washer Repair 4 12-07-2011 06:20 AM
Frigidaire front loader -- no water, no spinning wiired Washer Repair 1 07-25-2010 02:31 PM
Adjust water volume in front loader kbinafrica Washer Repair 1 01-22-2010 11:51 AM
front loader fills with water TRACIE18 Washer Repair 0 12-30-2008 09:30 AM
