Discuss
need to keep using the reset to get washer going
 in
Washer Repair
washer requires using the reset to start after it fills then works fine, have only used it for 10 loads
Appliance Repair Forum > Appliance Repair Help > Washer Repair » need to keep using the reset to get washer going
  #1 (permalink)
Old 02-03-2013, 02:20 PM
Junior Member
LeoF is on a distinguished road
Default need to keep using the reset to get washer going
Model Number: LSQ9010PW6   Brand: Whirlpool   Age: 5 - 10 years
washer requires using the reset to start after it fills then works fine, have only used it for 10 loads worked fine for first 6 now needing reset more often ( purchased used and used hard for first 7 loads,1 day, was a repair with new timer )
Ads By Google
Related Models
Whirlpool LSQ9010PW6 Automatic Washer
Whirlpool LSQ9030PQ0 Automatic Washer
Whirlpool LSQ9030PQ1 Automatic Washer
Whirlpool LSQ9030PQ2 Automatic Washer
Whirlpool LSQ9030PQ4 Automatic Washer
Whirlpool LSQ9030PQ5 Automatic Washer
Whirlpool LSQ9110KQ0
Whirlpool LSQ9110KQ1
Whirlpool LSQ9110LG0
Whirlpool LSQ9110LG1 Automatic Washer
Whirlpool LSQ9110LW0
Whirlpool LSQ9110LW1 Automatic Washer
Whirlpool LSQ9110PW0 Automatic Washer
Whirlpool LSQ9110PW1 Automatic Washer
Whirlpool LSQ9110PW2 Automatic Washer
Whirlpool LSQ9110PW3 Automatic Washer
Whirlpool LSQ9110PW4 Automatic Washer
Whirlpool LSQ9200KQ0
Whirlpool LSQ9200KT0
Whirlpool LSQ9200LQ0
Whirlpool LSQ9200LQ1 Automatic Washer
Whirlpool LSQ9200LQ2 Automatic Washer
Whirlpool LSQ9200LQ3 Automatic Washer
Whirlpool LSQ9200LT0
Whirlpool LSQ9200LT1 Automatic Washer
Whirlpool LSQ9200LT2 Automatic Washer
Whirlpool LSQ9200LT3 Automatic Washer
Whirlpool LSQ9200PQ0 Automatic Washer
Whirlpool LSQ9200PQ1 Automatic Washer
Whirlpool LSQ9200PQ3 Automatic Washer
Whirlpool LSQ9200PQ4 Automatic Washer
Whirlpool LSQ9200PT0 Automatic Washer
Whirlpool LSQ9200PT1 Automatic Washer
Whirlpool LSQ9200PT3 Automatic Washer
Whirlpool LSQ9200PT4 Automatic Washer
Whirlpool LSQ9210HQ0
Whirlpool LSQ9210HZ0
Whirlpool LSQ9211KQ0
Whirlpool LSQ9211KQ1
Whirlpool LSQ9211KT0
Whirlpool LSQ9211KT1
Whirlpool LSQ9244EQ0
Whirlpool LSQ9244EZ0
Whirlpool LSQ9264HQ0
Whirlpool LSQ9264HZ0
Whirlpool LSQ9500LQ0
Whirlpool LSQ9500LT0
Whirlpool LSQ9510JQ0
Whirlpool LSQ9510JQ1
Whirlpool LSQ9510LQ0
Whirlpool LSQ9510LT0
Whirlpool LSQ9520LQ0
Whirlpool LSQ9520LT0
Whirlpool LSQ9544KQ0
Whirlpool LSQ9544KT0
Whirlpool LSQ9549LG0
Whirlpool LSQ9549LG1 Automatic Washer
Whirlpool LSQ9549LG2 Automatic Washer
Whirlpool LSQ9549LG3 Automatic Washer
Whirlpool LSQ9549LQ0
Whirlpool LSQ9549LQ1 Automatic Washer
Whirlpool LSQ9549LQ2 Automatic Washer
Whirlpool LSQ9549LQ3 Automatic Washer
Whirlpool LSQ9549LW0
Whirlpool LSQ9549LW1 Automatic Washer
Whirlpool LSQ9549LW2 Automatic Washer
Whirlpool LSQ9549LW3 Automatic Washer
Whirlpool LSQ9549PG0 Automatic Washer
Whirlpool LSQ9549PG1 Automatic Washer
Whirlpool LSQ9549PG2 Automatic Washer
Whirlpool LSQ9549PG3 Automatic Washer
Whirlpool LSQ9549PG5 Automatic Washer
Whirlpool LSQ9549PG6 Automatic Washer
Whirlpool LSQ9549PW0 Automatic Washer
Whirlpool LSQ9549PW1 Automatic Washer
Whirlpool LSQ9549PW2 Automatic Washer
Whirlpool LSQ9549PW3 Automatic Washer
Whirlpool LSQ9549PW5 Automatic Washer
Whirlpool LSQ9549PW6 Automatic Washer
Whirlpool LSQ9550PW0 Automatic Washer
Whirlpool LSQ9550PW1 Automatic Washer
Whirlpool LSQ9550PW2 Automatic Washer
Whirlpool LSQ9550PW3 Automatic Washer
Whirlpool LSQ9550PW4 Automatic Washer
Whirlpool LSQ9560PW0 Automatic Washer
Whirlpool LSQ9560PW1 Automatic Washer
Whirlpool LSQ9560PW3 Automatic Washer
Whirlpool LSQ9560PW4 Automatic Washer
Whirlpool LSQ9564JQ0
Whirlpool LSQ9564JQ1
Whirlpool LSQ9564JT0
Whirlpool LSQ9564JT1
Whirlpool LSQ9564JZ0
Whirlpool LSQ9564MQ0 Automatic Washer
Whirlpool LSQ9600JQ0
Whirlpool LSQ9600JQ1
Whirlpool LSQ9600JT0
Whirlpool LSQ9600JT1
Whirlpool LSQ9600LG0
Whirlpool LSQ9600LG1 Automatic Washer
Whirlpool LSQ9600LW0
Whirlpool LSQ9600LW1 Automatic Washer
Whirlpool LSQ9610JQ0
Whirlpool LSQ9610JQ1
Whirlpool LSQ9610JT0
Whirlpool LSQ9610JT1
Whirlpool LSQ9610LG0 Automatic Washer
Whirlpool LSQ9610LW0 Automatic Washer
Whirlpool LSQ9620LG0
Whirlpool LSQ9620LG1 Automatic Washer
Whirlpool LSQ9620LW0
Whirlpool LSQ9620LW1 Automatic Washer
Whirlpool LSQ9645KQ0
Whirlpool LSQ9645KQ1
Whirlpool LSQ9645KT0
Whirlpool LSQ9645KT1
Whirlpool LSQ9650PG0 Automatic Washer
Whirlpool LSQ9650PG1 Automatic Washer
Whirlpool LSQ9650PG2 Automatic Washer
Whirlpool LSQ9650PG3 Automatic Washer
  #2 (permalink)
Old 02-04-2013, 01:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
How did you reset it?
Here are the breakdown diagrams and Parts for Whirlpool LSQ9010PW6 Washer - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-04-2013, 03:34 PM
Junior Member
Default
on the left,load size after large & super plus it says reset, if you turn there, spring loaded, it sounds like you trip a breaker and the washer starts ? coincidence ? is there a thermal switch getting weak?
  #4 (permalink)
Old 02-04-2013, 05:09 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Sounds like you need a new pressure switch. The load size knob directly controls the pressure switch. The reset selection allows you to change the water level after the washer has started. Say you set the load size to low and after the washer starts, you realize the water level is too low for the amount of clothes you have in there. Simply moving the knob to the next level won't do anything. You must go to reset first, the washer will stop agitating and start filling again to the new level you have selected. Normally, when the pressure switch is tripped, the washer stops filling and starts agitating. Yours stops filling but doesn't start agitating probably due to bad contacts in the switch. When you mess with the knob it starts making contact and the washer starts agitating.
Eric
  #5 (permalink)
Old 02-04-2013, 06:01 PM
Junior Member
Default
Thank's (fairbank56) Eric, did not get a users manual with it,Makes perfect sense.thanks again
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE dishwasher Reset light blinking will not reset when pressed and unit is not workin Caesar100 Dishwasher Repair 0 01-07-2012 12:04 PM
need help finding code f29 to reset washer kacat2007@yahoo.com Washer Repair 1 07-26-2011 06:57 PM
how to reset a frigidaire washer bok Washer Repair 1 10-05-2010 05:54 PM
reset washer so motor will work jv4692 Washer Repair 0 03-23-2010 02:23 PM
Kitchenaid Washer Reset RCarey Dishwasher Repair 0 01-01-2009 08:14 AM
