Discuss
Kenmore -One Direction Agitation
 in
Washer Repair
We have an older, but wonderful, Kenmore washer in need of some "help". The symptoms: Fills and drains normally Timer
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore -One Direction Agitation
  #1 (permalink)
Old 02-03-2013, 11:37 AM
Junior Member
mommysews is on a distinguished road
Default Kenmore -One Direction Agitation
Model Number: 110.C26832692   Brand: Kenmore   Age: More than 10 years
The symptoms:
  • Fills and drains normally
  • Timer moves through cycles normally
  • Fill and temp settings work normally
  • Lid switch works normally
  • Top agitator moves normally, feed-dogs appear to function as intended.
  • Lower agitator makes loud "grinding" noise and will only move in a clock-wise direction under load. Any number of pairs of adult pants or towels will cause failure. When load resistance is too heavy and agitator moves in one direction only, clothes become wrapped around agitator. Unwrapping/detangling of load allows agitation to occur normally for 6-9 seconds (yup, I timed it) before one direction movement resumes. If the load is ultra-light (4-5 t-shirts & few prs underwear in full tub of water) the agitation moves normally in both directions and cycle will complete without incident. Basket does not move with agitator in either situation.
  • On spin - agitator spins with basket. Slow speed spin functions relatively normally. High speed spin operates normally sometimes. More frequently, the spin will "Grab and Clunk" and the agitator shaft will stop momentarily during the spin. The agitator then immediately resumes spinning before the "Grab and Clunk" occurs again. We did remove the plastic agitator, ran a dry run spin and saw that the agitator shaft will "Grab and Clunk" on a spin even with nothing in the machine.
  • When the spin cycle is experiencing agitator "Grab and Clunk", bypassing the lid switch and holding the agitator still during the spin cycle completely stops the "Grab and Clunk" action. No downward pressure or upward pulling of the agitator is required to stop the "Grab and Clunk". The agitator presents no resistance whatsoever at these times and all that is required is a hand on top to keep it from spinning with the basket.
  • I assume that this is NOT a Neutral-Drain machine as the rinse cycle drain and spin occur simultaneously. Or, perhaps this IS a problem. It isn't something that I paid any attention to prior to this trouble.
  • The interior of the machine cabinet does NOT show oil leakage.
  • The floor under the machine does NOT show any oil leakage or black sooty/plastic bits.
  • Spraying the exterior of the clutch assembly with water does not show any signs of overheating (no sizzling or steaming). This was something that we read to test.
  • The load does ocassionally become unbalanced, but I assume that this is due to the high-water, low clothing load required for current functioning and is easily remedied.
Any help and advice is most appreciated. With much thanks in advance, we will patiently await a reply.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 02-03-2013, 12:25 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
What is the serial number of the machine? and/or, do you know the exact age of the machine?
It's sounding like a gearcase issue. During spin, the agitator shaft is not "driven" by the gearcase, however it is free to rotate so stopping the agitator by hand during spin is normal on this model. The agitator will spin during spin mode simply due to friction of the bearings in the spin tube. The bearings are pressed into the spin tube and the agitator shaft goes up through the bearings in the spin tube.
With the agitator removed, in agitate mode, can you stop the agitator shaft from going CCW by hand?
Eric
  #3 (permalink)
Old 02-03-2013, 01:26 PM
Junior Member
Default
Thanks Eric for your quick reply,
I will go and take the agitator off and try. In the meantime, the serial number is #CJ1507552
I will report back as soon as I get an answer to your other question (just have to find that socket set).
Julia
  #4 (permalink)
Old 02-03-2013, 02:21 PM
Junior Member
Default
Okay - here we go ...
In regards to your question about stoping CCW motion during agitation: Yes and No
I couldn't figure out how to grasp the agitator post with the agitator off to give resistance only for the CCW motion and not the CW motion. So, I tried with the agitator on. I know - not the best idea to stick one's hands in a moving washer. But, I do still have all ten fingers after this "experiment".
I was unable to get the agitator to stop the CCW motion for a bit and then it suddenly seemed to slip and it took only minimal force to stop the motion. The agitator tried to move CCW, but without much force. Then it would "catch" again and I could not stop it. However, the longer I stopped it from CCW motion, the less likely it was to "catch" again until I stopped resisting- i.e. it wouldn't "catch" back again easily if I kept up resistance. If I held it from even moving slightly CCW when it was resisting weakly, it would "click" and there was a faint "whirring" noise (I know noises are hard to accurately convey). When it did "catch", I was completely unable to stop it moving CCW. At all times, I was not able to stop the CW movement.
Does this help? Or is there a "trick" to grabbing the agitator for only the CCW movement with the agitator off?
Also, for what it is worth - I just remembered that the agitator shaft/base does not sit totally straight. There is a small difference in the distance that one side of the agitator bottom sits from the tub bottom. I can run my fingers around under the agitator in one area, but it is just a little too tight in the other areas. But, it has been that was for as long as I can remember with this machine.
Thanks again for your help.
Julia
  #5 (permalink)
Old 02-03-2013, 02:42 PM
Expert
APP Volunteer
Default
Your washer was manufactured in 1999, so it does have a neutral drain gearcase. The neutral drain mechanism gets set during the first few seconds of agitate mode. After agitate, the motor should pause, then start again in the reverse direction and the washer should drain only. The motor should then pause again causing neutral drain to release, then start again continuing to drain and spin.
I was trying to eliminate the agitator from the equation. Check the splines up inside the agitator. When they strip out, it usually causes slippage in both directions so I really don't think that's the problem. It's looking like the gearcase. Apparently, the neutral drain isn't working. Sometimes, parts of it can break or come loose and float around in the gearcase causing intermittent problems.
Eric
  #6 (permalink)
Old 02-03-2013, 02:55 PM
Junior Member
Default
Thanks Eric,
Well, from what you have described, it sounds like the neutral drain _is_ working exactly as it should. I was just seeing that it didn't drain _completely_ and then pause before the spin begins. I thought that all the water was to be gone before it began the spin out. At least that is one thing off the "fix it" list.
The splines inside the agitator are in fine shape. The whole thing is actually quite clean and "gunk-free". Nothing appears broken or missing.
So - the gearcase, eh? Is there a way that I can positively identify it as such before I buy parts? I suppose that I need to do some research to see how this works.
Thanks again Eric.
Julia
  #7 (permalink)
Old 02-03-2013, 03:17 PM
Expert
APP Volunteer
Default
Well, the agitator shaft is one solid piece of metal. The top is splined to mate with the splines of the agitator. Near the bottom, inside the gearcase, it is also splined to mate with the agitator gear. The gearcase appears to be the most likely culprit. I would pull your gearcase before ordering anything. If the shaft is bent (crooked agitator?), it might not come out. I'm not sure on the gearcase part number, yours is a Canadian model?
Eric
  #8 (permalink)
Old 05-05-2014, 01:18 PM
Junior Member
cnrrobles is on a distinguished road
Default
Quote:
Eric
Did u resolve your problem?? What part was the culprit? My washer is a roper and doing the same thing
  #9 (permalink)
Old 05-05-2014, 01:24 PM
Junior Member
Default
Eric
I was wondering if you fixed your appliance? My roper washer is doing the same thing. What part was the culprit?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Agitation Problem dfyfe Washer Repair 4 07-16-2012 04:52 PM
Washer spins one direction during agitation stejon12 Washer Repair 3 01-24-2012 08:26 AM
Old Kenmore Agitation Issues krich Washer Repair 10 12-24-2011 01:40 AM
Kenmore - ONLY spin one direction slowly and won't progress cycle jonsuh Washer Repair 0 12-29-2008 06:46 AM
Kenmore 90 Series - No agitation jastek Washer Repair 3 02-20-2008 02:54 PM
