| » Position of keyway holding pulley on bottom of washer |
Model Number: LAT9416AAQ Brand: Maytag Age: More than 10 years
I took off the large pulley that is on the bottom of the washer to put on a new belt and there is a keyway that is screwed on with a phillips screw to hold it. It appears that you can put the keyway on in 360 degrees as far as positions. Is there a procedure to follow when putting it back on to make sure it is in the right position?
I am not sure which part you are talking about. Here is the diagram,
03-Clutch, Brake & Belts (9416) parts for Maytag LAT9416AAQ - AppliancePartsPros.com I don't know of any specific way the pulley has to go back on.
__________________
| Display Modes | |
| maytag front load washer/holding water | bmetsa | Washer Repair | 1 | 12-26-2011 06:43 PM |
| Pulley is grinding on the bottom of cabinet | RyanR | Washer Repair | 1 | 01-08-2011 04:27 PM |
| GE Washer Holding Water | Lonely Repairman | Dishwasher Repair | 0 | 12-24-2009 09:53 AM |
| Washer Does not Start in any Position | pulveray | Washer Repair | 0 | 08-25-2009 12:20 PM |
| raise the washer top to the service position | hundeby | Washer Repair | 2 | 04-05-2008 05:37 PM |
