Ultimate Care II large capacity top load; 5-7 yrs old turned it up on its side and underneath can see the small gear assembly is shattered (in between the motor and pump box or whatever you call it). Is repair as easy as getting replacement part and installing?
thanks for any help!
Can you post a full model number and then we can probably give some advice.
