Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Leak from Frigidaire front load washer tub (http://forum.appliancepartspros.com/washer-repair/516912-leak-frigidaire-front-load-washer-tub.html)
laser_doc 01-30-2013 10:58 PM
I have a Frigidaire front load washer modelnumber LTF2940FE0. There is water running out of what appears to be a drain holeat the front of the tub all the way down at the bottom. I removed the front clamp from the doorgasket so I could inspect beneath the gasket but it is completely dry. The water starts to leak from the drain holewhen the water level in the drum reaches about 2 inches. Where is that water coming from?
Gene 01-31-2013 04:49 PM
Hello,
Open the door and carefully inspect the bellows for any cracks.
Remove the bottom access panel and observe everything while the washer is running a load.
Post the results.
Here are the breakdown diagrams and Parts for Frigidaire LTF2940FE0 Washer - AppliancePartsPros.com
laser_doc 02-01-2013 12:04 AM
Thank you for the quick reply Gene. With the access panel removed and the washer running through a cycle, the water is running out the drain hole I described in my post, at the extreme front and the extreme bottom of the tub. I inspected the bellows for cracks or tears, and I removed the front bellows clamp and peeled the bellows away from the front panel.. dry as a bone underneath. Unfortunately there isn't enough detail in the parts diagram to see the drain hole in the tub that I am talking about.
Gene 02-01-2013 02:03 PM
Did you mean the hole in the outer tub where the drain hose (#41 at the diagram) is connected to?
laser_doc 02-01-2013 10:20 PM
No, the hole for the drain hose is off to the right and set back a few inches. This is bottom dead center, at the extreme front of the tub. And there is what appears to be a channel molded into the bottom of the tub, running along its centerline from rear to front and terminating at this hole.
Gene 02-05-2013 04:01 PM
Can you post a picture of it? It might help.
laser_doc 02-08-2013 01:43 AM
3 Attachment(s)
Here are three shots, Gene. In No 1, I am pointing at the hole that the water is coming out of. The other two shots show the hole at different angles and also the channel leading up to the hole.
Gene 02-08-2013 03:45 PM
Looks like the front half of the outer tub is leaking. The correction is to replace the front shell.
- The front shell Part number: 134362000
laser_doc 02-10-2013 09:49 PM
Groannnn.. that does look like more fun than I was hoping to have with this. I do appreciate your help Gene,
Gene 02-11-2013 03:17 PM
You are welcome. Yes, this repair is not a simple one.
