Discuss
rince water level
 in
Washer Repair
Hey guy's I have a question, My washer is not HE but the water level on the rinse cycle is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » rince water level
  #1 (permalink)
Old 01-30-2013, 05:27 PM
Junior Member
ssergel03 is on a distinguished road
Smile rince water level
Model Number: etw4400xq0   Brand: Estate   Age: 1 - 5 years
My washer is not HE but the water level on the rinse cycle is very low, it does vary when you select a different load size so I believe it is working properly but this must be a watersaving feature. So I was looking at the wiring diagram to try and figure out how I could jump the rinse water level to be the same as the wash water level? But the diagram is not labeled to clearly so I was looking for some help on how to do this.
Scott
Ads By Google
Related Models
 ETW4400XQ0 AUTOMATIC WASHER
 ETW4450TQ0 AUTOMATIC WASHER
Bosch EU010-000
Amana EU12F FREEZER- VERTICAL
Amana EU13K FREEZER- VERTICAL
Amana EU13K-A FREEZER- VERTICAL
Amana EU13K-AG FREEZER- VERTICAL
Amana EU13K-C FREEZER- VERTICAL
Amana EU13K-L FREEZER- VERTICAL
Amana EU15F FREEZER- VERTICAL
Amana EU16K FREEZER- VERTICAL
Amana EU16K-A FREEZER- VERTICAL
Amana EU16K-AG FREEZER- VERTICAL
Amana EU16K-C FREEZER- VERTICAL
Amana EU16K-L FREEZER- VERTICAL
Amana EU18F FREEZER- VERTICAL
Amana EU18K FREEZER- VERTICAL
Amana EU18K-A FREEZER- VERTICAL
Amana EU18K-AG FREEZER- VERTICAL
Amana EU18K-C FREEZER- VERTICAL
Amana EU18K-L FREEZER- VERTICAL
Amana EU80/46.B00 COMMERCIAL MICROWAVES
Amana EU80/55.302 COMMERCIAL MICROWAVES
Amana EU80/55.B00 COMMERCIAL MICROWAVES
Amana EU80/55.B01 COMMERCIAL MICROWAVES
Amana EU80/56.300 COMMERCIAL MICROWAVES
Amana EU80/56.301 COMMERCIAL MICROWAVES
Amana EU80/56.302 COMMERCIAL MICROWAVES
Whirlpool EUC050A1
Amana EUT1B1 COMMERCIAL MICROWAVES
Whirlpool EV040FXAW0 Freezers*
Whirlpool EV040FXAW00 FREEZER
Whirlpool EV040FXDW00 FREEZERS
Whirlpool EV040FXHW FREEZER
Whirlpool EV040FXHW00 VERTICAL FREEZER
Whirlpool EV060FXTN00 Freezers*
Whirlpool EV070FXRQ00 VERTICAL FREEZER
Whirlpool EV070FXRQ01 VERTICAL FREEZER
Whirlpool EV090FXKN2 Freezers*
Whirlpool EV090FXKN3 Freezers*
Whirlpool EV090FXKN5 Freezers*
Whirlpool EV090FXPN5 Freezers*
Whirlpool EV090FXSN00 Freezers*
Whirlpool EV110CXRW0 Freezers*
Whirlpool EV110CXRW1 Freezers*
Whirlpool EV110CXSW00 Freezers*
Whirlpool EV110CXWW00 Freezers*
Whirlpool EV110FXVN00
Whirlpool EV110FXVW00 Freezers*
Whirlpool EV120FXAN00 Freezers*
Whirlpool EV120FXDN00 UPRIGHT FREEZER
Whirlpool EV120FXDN01 UPRIGHT FREEZER
Whirlpool EV120FXEN00 UPRIGHT FREEZER
Whirlpool EV120FXEN01 UPRIGHT FREEZER
Whirlpool EV120FXEN02 VERTICAL FREEZER
Whirlpool EV120FXG06 VERTICAL FREEZER
Whirlpool EV120FXGW00 VERTICAL FREEZER
Whirlpool EV120FXGW01 VERTICAL FREEZER
Whirlpool EV120FXGW02 VERTICAL FREEZER
Whirlpool EV120FXGW03 VERTICAL FREEZER
Whirlpool EV120FXGW04 VERTICAL FREEZER
Whirlpool EV120FXGW05 VERTICAL FREEZER
Whirlpool EV120FXGW06 VERTICAL FREEZER
Whirlpool EV120FXGW07 VERTICAL FREEZER
Whirlpool EV120FXKQ00 UPRIGHT FREEZER
Whirlpool EV120FXKQ01 UPRIGHT FREEZER
Whirlpool EV120FXKQ02 UPRIGHT FREEZER
Whirlpool EV120FXKQ03 VERTICAL FREEZER
Whirlpool EV120FXKQ04 VERTICAL FREEZER
Whirlpool EV120FXKQ05 VERTICAL FREEZER
Whirlpool EV120FXKQ06 VERTICAL FREEZER
Whirlpool EV120FXKQ07 VERTICAL FREEZER
Whirlpool EV120FXMQ00 VERTICAL FREEZER
Whirlpool EV120FXMQ01 VERTICAL FREEZER
Whirlpool EV120FXMQ02 VERTICAL FREEZER
Whirlpool EV120FXMQ03 VERTICAL FREEZER
Whirlpool EV120FXMQ04 VERTICAL FREEZER
Whirlpool EV120FXMQ05 VERTICAL FREEZER
Whirlpool EV120FXMQ06 VERTICAL FREEZER
Whirlpool EV120FXXN00 Freezers*
Whirlpool EV120NXRQ00 VERTICAL FREEZER
Whirlpool EV120NXRQ03 VERTICAL FREEZER
Whirlpool EV130CXRW0 Freezers*
Whirlpool EV130CXSW00 Freezers*
Whirlpool EV130EXPW0 Freezers*
Whirlpool EV130EXSW00 Freezers*
  #2 (permalink)
Old 01-30-2013, 05:38 PM
Junior Member
Default Idea
Well I just realised there are two water level switches the one not connected to the level selector switch I assume is for the rinse if I jumper that one to the one on the selector switch this should give me the same water level for both cycles right?
  #3 (permalink)
Old 01-30-2013, 07:14 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
If you do that, your going to screw up the water temperature selection. The rinse cycle uses cold water only and you'll see that the rinse level pressure switch only operates the cold water valve. The wash level pressure switch powers the automatic temperature control. Also, if you jump them together the rinse level pressure switch is going to close first if you've selected other than low level and it's going to start agitating while still filling to the level you've selected for the wash cycle.
Your not the only one complaining about this, welcome to the world of new washers. It's only going to get worse. New energy standards including water use go into effect in 2015.
Eric
  #4 (permalink)
Old 01-31-2013, 09:46 AM
Junior Member
ssergel is on a distinguished road
Default
Ok thanks. what if I replace the rinse water level swicth with the same model as the wash level switch? then i would just have to select the water level on the second switch for the rinse cycle right?
  #5 (permalink)
Old 01-31-2013, 11:11 AM
Expert
APP Volunteer
Default
Yes, I suppose you could do that. The switch comes as an assembly that includes both switches, hoses and tee connection.
Eric
  #6 (permalink)
Old 01-31-2013, 04:39 PM
Junior Member
Talking
O.k thanks Thats what I'll do.
Thanks for the help. Now my wife will get off my back.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Rinse - low water level - 2 Water Level Switches... Aleste Washer Repair 3 01-25-2013 08:27 AM
Washer not filling during rince cycle. Dominic863 Washer Repair 0 01-04-2013 05:54 AM
Rince cycle won't work ginger5 Washer Repair 0 07-09-2010 04:36 PM
will not rince ashleyspigs Washer Repair 1 09-30-2009 07:35 AM
